Old Sep 14, 2002, 02:40 AM
DesertRC is offline
Find More Posts by DesertRC
DesertRC's Avatar
Tucson, AZ
Joined May 2002
What is the best power supply for a Schulze
I have a 10 amp pyramid power supply @13.8 volts
that I was planning on using for the Schulze isl 6-330.
The manual says 12v car battery only. If this
rings true than this is a bummer. What are all you Schulze
owners using with success? I would hate to ruin or shorten the
life of this really cool charger. I want to be able to use it in the home and also in the field.
Any help would be great...
Chris
DesertRC is offline Find More Posts by DesertRC
Old Sep 14, 2002, 03:12 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Schulze manuals have long said "battery only" but if you check you'll see they actually sell a power supply for use with their chargers .
10A is way too low for the maximum capacity of the charger but if you're only charging relatively small batteries, say up to 10cells, it should still allow maximum current. It certainly shouldn't damage the charger. My old 6-430d has worked fine for ages on a 13.5V 15A supply.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Sep 14, 2002, 03:20 AM
DesertRC is offline
DesertRC's Avatar
Tucson, AZ
Joined May 2002
Thanks Steve
Steve,
Thanks for clearing this up for me. I feel much better.
Now if I only would have bought a PS that rated higher
amperage....live and learn!
Chris
Old Sep 14, 2002, 04:46 AM
vette461 is offline
Find More Posts by vette461
Sweden
Joined Jul 2001
Hi.
I'm using a powersupply from an older PC computer with my isl 6-330.
Mine is rated at 200W and 8Amp at 12 volts.
It charges 10*24000 mha cells at 5.5 amp without problem.
But I would have liked a more powerfull powersupply if I would
increase cell count now I would not be able to charge at 5,5 amp
maybe only at 3 amps.
vette461 is offline Find More Posts by vette461
Old Sep 14, 2002, 03:39 PM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
DesertRC - the rated charge performance of your charger is 130W. Your power supply can output 13.8V at 10A = 138W Therefore your power supply will be just fine - no real need for a higher rated one.
GordonTarling is offline Find More Posts by GordonTarling
Old Sep 14, 2002, 04:05 PM
DesertRC is offline
DesertRC's Avatar
Tucson, AZ
Joined May 2002
Gordon,
Great info. Thank you
Old Sep 14, 2002, 10:36 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I have 17A power supply I got from Aveox several years ago. I routinely run both my schulzes (isl 6-330d and 6-636+) from it, though not at the same time, as well as the FMA SuperNova, Astro 110D, GWS MC2002 and occasionally the little Jeti. Sometimes I have two or three chargers going at once (but must watch out when charging large packs). No problems.
BEC is online now Find More Posts by BEC
Old Sep 14, 2002, 11:00 PM
DesertRC is offline
DesertRC's Avatar
Tucson, AZ
Joined May 2002
BEC
How do you like your GWS MC2002?
I was thinking of getting one for small park
packs... 370mah nihm's etc. A good back-up
and field charger type deal.
Chris
Old Sep 14, 2002, 11:41 PM
BEC is online now
BEC
BEC
BEC's Avatar
Joined Jan 2001
You must not get either R/C MicroFlight or Model Airplane News (where a short piece I wrote about it has appeared....)
Short version: 0.25 to 6A charge rate on up to 12 cells. Soft enough peak for NiMH, easy to use (old fashioned knob and analog meter for setting charge rates) and less than $40. What's not to like? I have two now..... one lives in my daily vehicle just to keep it handy for impromptu flying.
Howzat?
Old Sep 15, 2002, 01:46 AM
DesertRC is offline
DesertRC's Avatar
Tucson, AZ
Joined May 2002
...on knee's bowing
Ahem...ahh..yeah...I read it ...ahh yeah that's it.
No I didn't, but now I will, just because.
Thanks for your response!
I am not a newbie to flying but pretty new to e-flight.
Ezone rocks. I pretty much do a search daily for tips
and help. I really enjoy the freedom of e-flight etc.
Thanks again...I am off to AeroMicro to order a GWS chgr.
What Kind Of Power Supply For Isl 6-330d Dog Flyer Batteries and Chargers 9 Aug 19, 2004 12:19 AM
HElp what is the best power system for SX2 DoDriver 3D Flying 9 Feb 20, 2004 11:05 AM
Regulated Power Supply For Schulze Charger Knulp Batteries and Chargers 9 Jun 17, 2003 12:04 PM
what spec power supply for Triton charger? Astro30 Batteries and Chargers 21 Jun 13, 2003 09:39 AM
what is the best power package for Kabriolin Ali Sport Planes 6 Jun 19, 2002 06:58 AM
