Old Dec 23, 2006, 12:54 AM
BD Flyer is offline
Find More Posts by BD Flyer
BD Flyer's Avatar
United States, NJ, Monroe Township
Joined Aug 2006
Question
Receivers that work with Spektrum Radios that are not made by Spektrum
Hi, I was wondering if there are any receivers that work with the DX6 or DX7 that are not made by Spektrum. If there isn't any, then does anybody know if this will happen in the future? It would be cool if there was a cheaper receiver that would work with Spektrum radios instead of just the $50 BR6000 and the AR6000 made by Spektrum.
Bill
BD Flyer is offline Find More Posts by BD Flyer
Old Dec 23, 2006, 02:30 AM
LAN is offline
LAN
Find More Posts by LAN
LAN
LAN's Avatar
Sweden, Östergötland, Valdemarsvik
Joined Oct 2003
No, that will be very unlikely. Not impossible, but it would probably be very difficult to reverse-engineer the protocol in use.
LAN is offline Find More Posts by LAN
Old Dec 23, 2006, 05:00 AM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Its already been done for the ground Spektrum system. The Nomadio transmitter can control Spektrum receivers.
TheSteve is offline Find More Posts by TheSteve
Old Sep 14, 2009, 05:05 PM
lucasavaitor is offline
Find More Posts by lucasavaitor
Joined Aug 2008
Yes, hopefully a more affordable air version is on the way (if it works?)
Lucas
lucasavaitor is offline Find More Posts by lucasavaitor
Old Sep 14, 2009, 10:31 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Nope
don't expect to see it happen
The DSM2 is a protected system - and unlike the hoppers
IF Spektrum elects to sell rights to it -then you may see some.
the DSM ground radio protection - if it exists at all,is an unknown to me.
richard hanson is offline Find More Posts by richard hanson
Old Jul 02, 2010, 02:52 PM
Richard Cox is online now
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Hah! HK is now selling Spekrum compatible receivers.
Richard Cox is online now Find More Posts by Richard Cox
Old Jul 02, 2010, 02:57 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Yes, with cheaper electronic parts than spec, I wouldn't put one in any model I liked
tk
tkallev is offline Find More Posts by tkallev
Old Jul 02, 2010, 05:10 PM
onewasp is offline
Find More Posts by onewasp
USA
Joined Sep 2003
____________________
John Ruskin said it many, many years ago "There is hardly anything in this world that a man cannot make a little (or a lot) worse and sell for a little (or a lot) less and those who consider price alone are this man's lawful prey."
[ quote with very minor mods]
Not in any plane I own either.
"tkallev" is right on.
onewasp is offline Find More Posts by onewasp
Old Jul 02, 2010, 05:43 PM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
It's funny how 4 years after I made this thread, I still continue to use the original AR6000 receivers in all of my parkflyers. I don't trust ANY AR6100's, and now I really don't because there is a HUGE amount of chinese knock offs out there. When I made this thread, I was hoping that a big brand name company would make a cheaper Spektrum compatible receiver such as Hitec, etc. But I knew i'd see the day when the chinese finally figured out how to produce much cheaper Spektrum compatible receivers. But like said above, I would NEVER trust them in any plane that I spent more than $50 on.
Old Jul 02, 2010, 11:48 PM
fox74 is offline
Find More Posts by fox74
Salt Lake City Utah
Joined Oct 2009
BD what is the problem with AR6100e, I was thinking about getting one
fox74 is offline Find More Posts by fox74
Old Jul 03, 2010, 10:52 AM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
You made a bad choice if you could not afford expensive receivers. You are stuck with Spektrum.
Before you select a brand, check the receiver price.
There are a bunch of cheap and good quality Chinese 2.4 modules/receivers. I checked them out and all worked fine with no problem. If you have a module transmitter, switching is easy and cheap.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Jul 03, 2010, 07:24 PM
bradpaul is offline
Find More Posts by bradpaul
USA, FL, Apopka
Joined Dec 2000
That i s how I feel about using certified Spektrum (only uses DSSS on 2 ch) in any plane that I spent more then $50.00 on.
bradpaul is offline Find More Posts by bradpaul
Old Jul 04, 2010, 09:41 AM
onewasp is offline
USA
Joined Sep 2003
_________________
Let's see John: ---- Former competitors at my fields flying now simply for enjoyment. That includes me.
Set ups; Servos $100 each (median figure) x 5 = $500
Airframe, (least expensive in use) = $200.
Battery Pack (we all use A123s) $45 to $60.
----plus appropriate charger-- we all use FMA 4S; Multi4; or 10S . Price from $70 to $200.
Ground equipment beyond the charger we won't even list.
I have intentionally left out the electric fliers as their numbers are a bit higher.
Totals: low = $815
high (most of us) = $960
Rx's (not included in these figures) --- seems we all use the $100 or over types.
But YOU suggest that we risk it all with an Rx of unknown lineage which is admittedly a CHEAP copy of the real thing.
The odds you promote are at minimum 10 to 1 and at worst 12 to 1.
The numbers I've presented here are intentionally on the low side of the actual dollar amount.
In dollars you are betting that a saving of $80 justifies the risk we would assume through "going Cheap" on the Rx (which could be considered the 'brains' of the whole airborne rig).
You present faulty logic in my opinion.
Further, none of us are even interested in taking ONE flight with such an Rx ---- even if it were free.
But then, we have only been flying for fifty years plus (each)-----Perhaps time will give us a different perspective on RC and its costs.
We are late seventies to early eighties (your age group) and all began flying RC long before digital proportional made its appearance.
Along the way, most all of us have experienced losses (through crashes) of a few hundred dollars (on the low side) and over $1000 on the high end.
No jets or large Helis involved or the latter number could be many times higher.
Occupations (former) in this group range from hourly to MD's and PHD's with Corporate officers thrown in.
The complete Spektrum (couldn't resist) if you will.
The vast majority of us are also ex-military. WWII, Korea and one vet from Viet Nam, so we didn't come from pampered life styles.
Oh, BTW we are all retired living on fixed incomes so there is no big cash coming in, yet we consider our equipment choices quite reasonable.
Very reasonable when you consider that none of us have had any equipment failures whatsoever.
What do we recommend to our younger counterparts ? The very same set ups.
Simply a choice of total reliability over your suggested "unknown"-----but cheap.
I do not agree with you at all.
Old Jul 04, 2010, 09:59 AM
Gregg28 is online now
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
Originally Posted by onewasp View Post
_________________
Totals: low = $815
high (most of us) = $960...
While, of course, you are absolutely correct, but some of us have planes that we have $100 or less tied up in that will only be flying a couple of hundred yards away. I am perfectly willing to put one of those receivers in one of those planes.
On one of my first string planes, worth well more than $100, I would only use the original AR7000 or better. Like the motorcycle riders say, "a $50 helmet for a $50 head."
But there is a place for the cheap receivers, and I just ordered a couple.
Gregg28 is online now Find More Posts by Gregg28
Old Jul 04, 2010, 10:17 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Well said Onewasp,
I can't see the logic of risking even a hundred buck ARF on a no name receiver to save 20 bucks or so.
I currently fly the little Electrifry L-39 foam EDF, only a C note including the brushless motor and fan. I would not want something that fast and quiet going outta control at the field. The $59 MSRP receiver I run in it will hopefully serve me through many smaller planes.
A safe and sane 4th of July to ALL, and don't forget what it's all about
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Discussion flight sims that work with walkera tx and sim cable the grounds 2 hi Micro Helis 2 Jun 27, 2007 04:53 PM
Discussion Anyone using the digital servos that come with Spektrum 7 radio? QuietRiot Electric Heli Talk 11 Jun 25, 2007 03:52 AM
Question my li-poly charger that came with battery isit ok or not ???? helli crashed Batteries and Chargers 2 Jun 06, 2005 04:28 PM
Sims that work with Joystick port Jamo Simulators 1 Oct 11, 2003 06:04 PM
