Okay, you guys raise a bunch of interesting points.
First the other plane: All built up original design, looked sorta like a sleek 4 star 40, had about same span and area as my plane, 48" and 480 in/sq.
His batteries were 8 2400's, ( not sure if rc or cp) on an astro brushed motor. I belive his prop was a 11x7.
Mine runs a kyosho atomic force, 3.8:1 with a 12x8 apc-e on 8 cp2400's. I belive the astro brushed is not significantly more effiecient than the kyosho, certainly not enough to account for the duration and performance difference.
Clearly, with the extra speed and duration he had, his average current draw must have been much lower.
Our max climb angle and rate was quite similar, but his speed was much higher
My wing is quite thick at 18%. It was chosen last year when I knew less about this stuff but did know that a thick symetrical design would give very gentle stalls and fly the same inverted as upright. ( both true BTW ).
The potential reduction of frontal area alone should make this exercise worth the trouble.
Fuse frontal area = 12 in/sq
current wing frontal area =69 in/sq. (1.5" thick)
10 % wing frontal area = 39 in/sq
so a total of 51 in/sq frontal area down from 81 in/sq. for a reduction of 38%!
I also can see that now at lower speeds when throttled back, the entire planes angle of attack goes noticably nose high, which must create tremendous drag. This then requires that I keep the throttle at a fairly high position except for downlines, else it really slows down fast. Part throttle is therefore mostly for landings.
Part of the idea of using a semi-sym profile came from playing in motocalc. If I would subsitute almost any semi sym profile for almost any full sym, part throttle cruise duration would jump up almost 50%.
My thinking is that this is due to the plane no longer needing to go so dramatically nose high at lower speeds to stay airborn, reducing drag and therefore needing less power.
So now you guys have me in a quandry. Should I just go to a thin full sym, or would semi be a better choice? Aargh!
Dean in Milwaukee
