Dec 23, 2006, 06:49 AM
United States, AZ, Scottsdale
Joined Jan 2005
ost,
I dont quite understand your post. except for - Yes, airflow is better through the fan with an intake ring and thrust will increase.
I wanted to know a baseline of performance, thrust, airspeed out of exhaust, and amps, With or without a intake ring in the test stand their is no practical way to test how it will operate mounted in an airframe with its own intake lenght, shape and inlet. If you were using the fan in a pod like a airliner you could get very close because the inlet would be exactly like it will be mounted on the airframe. (Does this make sense?)
Through my testing is seems that the effect of the inlet ring is nearly 0 at full throttle and higher fan speeds. I could be wrong but there is a post somewhere from the Wemo Tec person that also states this. I did find that the intake ring did increase thrust significantly at lower settings, but then again it would have to mounted in the airframe to complete an accurate test. Which right now is not practical for me.
AIR SALLY, I really like the Het fan for a few reasons - it takes less than a minute to assemble with motor from opening the box to a complete assembly. Het fan comes pre balanced, has a one piece design where spinner and fan are 1. Makes life much easier. Does it give better performance? I cant say that it does, both fans seem to perform about the same. Better durability? Yet to be seen, but the Het fan is so easy to assemble and looks to be a great design.
I will try and complete some additional testing, but all I really wanted and what most people probably want to know is how much thrust and eflux spped to expect based on Fan/motor/esc/battery combo. I think I would have a real hard time trying to figure out which fan gives the best performance becuase of all the variables and the accuracey of the test equipment. The test equipment is very good but I am not sure it can reliably detect the differences between two fans due to all the variability.
Matt
Matt
