Old Dec 21, 2006, 11:21 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Idea
40" Depron Dynamite, Kline fogleman Depron build
I liked Craigs so much- I thought I would proceed.
6mm depron sanded to an airfoil-
I will not have the Fogleman airfoil fully scaled but will act as a CF backing with a sanded in airfoil. I will install the CF in an ARC from tip to tip with a CF angle braces on each side of the CF threaded and glued. This will hold 3.25" of total dihedral in aileron wing.
Here is what I have so far:
This is the bottom of the Wing
My Target weight is 5.5 ounces.
.pdfs are on post #26, on this page-
http://www.rcgroups.com/forums/showt...=614246&page=2
Doug
Dusk video is on page 2, post 18
dougmontgomery is offline Find More Posts by dougmontgomery
Old Dec 22, 2006, 12:40 AM
Solarsail is offline
Find More Posts by Solarsail
New Pilot
Solarsail's Avatar
United States, CA, Santa Monica
Joined Feb 2006
Oh man, I haven't heard reference to a Klein Fogelman step since a paper airplane book that I had as a kid. This idea was supposed to show up on full-size planes but that obviously didn't happen. Isn't it supposed to reduce stall speeds and increase overall effeciency?
Solarsail is offline Find More Posts by Solarsail
Old Dec 22, 2006, 01:26 AM
Glendale,Az.
Spar center designed and glued, Link to Klein-Fogleman
After building in foamies for a few years I will be hacking this airfoil similar to the foamie based versions. I think it will provide the support I need and hopefully some lifting qualities. I did not want to use an undercamber because of the speed at launch and I wanted minimal drag.
Link here to check out the research:
http://www.rexresearch.com/klinfogl/klinfogl.htm#ultim
I used some CF cut to wafer each side of the flatstock with the dihedral preset. I just have to spiderwire and CA now.
Doug
Old Dec 22, 2006, 02:42 AM
Glendale,Az.
Wing assemble but not glued, Tail surfaces made
Wing assembled, unglued, unsanded with spar- 2.1 ounces
6mm depron tail surfaces, Lightning holes not cut yet or covered- 7 grams
Dihedral turned out pretty good, still contemplating if I use rudder or not.
Night,Night
Doug
Old Dec 22, 2006, 06:28 AM
FredM is offline
Find More Posts by FredM
powered by caffine
FredM's Avatar
Akron, New York
Joined May 2004
doug
there is a thread on the kf airfoil in the foamies scratchbuilt section.they seemed to have very good luck using it. fred
FredM is offline Find More Posts by FredM
Old Dec 22, 2006, 11:00 AM
Phiber Optik is offline
Find More Posts by Phiber Optik
Womb Drifter
Phiber Optik's Avatar
NC, USA
Joined Dec 2004
Doug
WOW!, Looking good Doug!
I like the shape and smooth sweep of your wing. Did you freehand draw it?
I think you should make your Target Weight 4.5oz
Phiber Optik is offline Find More Posts by Phiber Optik
Old Dec 22, 2006, 02:44 PM
Glendale,Az.
FredM- Thats where I got the Info, link and seen the idea is the foamy forum.
Craig- Your on, 4.5 sounds good. Will it even penetrate with that weight???
The smooth Sweep came from a template that I drew from the Apogee set of plans. I buy 1" square graph paper from Officemax that is for doing lectures or presentations. Then I just scaled it 1:1 from the plans. I think it is close. I manually plotted it and then freehand draw, cut then sand.
I ordered some dymond 4.3g servos today and some D47s, I will try to finish it tonight to Maiden tomorrow or Sunday(its Raining the first day this winter here in Glendale,AZ.)
I will probably have to rob some 4.7s from another model.
Battery will be a 6v 1/3 AA battery for a camera-
Wing will be mounted on boom forward or aft to obtain CG.
Doug
Old Dec 22, 2006, 05:01 PM
Glendale,Az.
Spar brace spider wired, Wing 90%
I drilled the CF plates and threaded the spider wire and Ca'd.
Attached the CF to one wing panel at a time with 5minute epoxy
sanded wing, still have to cut ailerons, suprisingly strong at this point.
Auw of wing glued 2.2 ounces
Doug
Old Dec 22, 2006, 06:00 PM
Womb Drifter
NC, USA
Joined Dec 2004
Nice. Your dihedral joint looks strong.
Hows about a PDF with that wing template?
When I finally do a R/E only dihedral wing I was thinking about these plastic kite dihedral braces:
http://www.goodwindskites.com/merch/...tors.dihedrals
No foam in the mail today
Hopefully I'll get it tomorrow. We're having rain for the next couple days, so wouldnt be able to fly anyway.
Old Dec 23, 2006, 12:04 AM
Glendale,Az.
Depron Build 99% Complete
Craig- Check the scale out.........................4.2 ounces!!!!I made this pod about a month ago out of a kids water rocket. It could use a layer of kevlar or 1 more layer of 2 Ounce F-glass. It will work for now. Things all went smooth and I even figured out how to use a mix in my radio for a 4 channel receiver with two aileron servos, I do not have a rudder. Will test tomorrow. Wish me luck! Doug
Here is the link where I get all my info, PDF and everything mid way down:
http://www.charlesriverrc.org/articl...#Molded%20Wing
Old Dec 23, 2006, 02:11 AM
Glendale,Az.
Paint job and battery change out
The battery I made for this model must have low voltage because it could not handle three servos without twitching. I installed my 150mah 4 cell for tomorrow. Balances better with the added 5 grams.
AUW with Paint job- 4.7 grams
Doug
Old Dec 23, 2006, 09:43 AM
Womb Drifter
NC, USA
Joined Dec 2004
WOW! Looking great! You've been busy little beaver! Now go out and chuck it!
Did you use a launch peg? Any close ups of it?
How about wing flex or twist? Is it much?
Old Dec 23, 2006, 07:02 PM
Glendale,Az.
Launch Peg
Craig, I have installed the peg, .125" CF with a CF plate on each side of the wing the size of a dime. This is installed right behind the Spar with epoxy.
There is not much wing flex, I managed to throw it twice today before my elevator servo failed on me.
It was kind of nose heavy so I was having to use quite of bit of back stick. So I am not sure of how well it glides. Hopefully more tomorrow.
I will take pictures of the launch peg later.
Doug
Last edited by dougmontgomery; Dec 24, 2006 at 12:34 AM. Reason: add picture of launch peg
Old Dec 25, 2006, 02:52 PM
Glendale,Az.
Everyone,
I have A few flights in today, It floats nice but on launch it trys to do a loop. I thought it was negative built into the horizontal but I checked that, and It was zeroed out to the main wing.
I ended up putting in a Launch mix into my spring loaded trainer switch with 20 increments of down elevator with switch on, worked much better.
I will be doing some fine tuning before video.
Doug
Old Dec 26, 2006, 12:36 PM
wingnutt is offline
Find More Posts by wingnutt
Will work for foam
wingnutt's Avatar
United States, WI, Muskego
Joined Apr 2005
dm- are you getting decent height and flight times with that airfoil? i was one of the guys on the foamy thread and liked the KF in powered flight, but found the glide to be very lacking due to drag. i am watching with interest to see if you can get more out of it than i did. Good luck!!
wingnutt is offline Find More Posts by wingnutt
Idea 50 WS Kline Fogleman bagged(Depron) dougmontgomery Foamies (Scratchbuilt) 0 Apr 10, 2007 07:42 AM
.40 size Ziroli P47 build thread. RyanPSU21 Scale Kit/Scratch Built 130 May 09, 2005 08:03 PM
kyle's mini kestral 40" dlg design/build mothflyer Hand Launch 42 Apr 26, 2005 11:24 AM
Mig 17 paper to 1mm depron build Dmerino Electric Ducted Fan Jet Talk 114 Apr 18, 2005 11:49 PM
P-38 Depron build Wing Wong Foamies (Kits) 38 Mar 27, 2004 07:23 AM
