| Thread Tools |
| This thread is privately moderated by mnowell129, who may elect to delete unwanted replies. |
Joined Nov 2004
0 seems unlikely. To be at 0 degrees lag, i'd think you would need the reaction to be instantaneous, i.e. completely rigid so that the bending moment applied to the shaft is immediate. To have 0 bending seems unlikely, but perhaps with a very very rigid system the phase lag gets very low. Say perhaps in a propeller. But even a "rigid" propeller is not infinitely rigid and displaces some. So even a small amount of displacement is going to cause some lag.
This is creeping up on the P-factor discussion with props..... I guess the discussion comes down to how rigid is rigid. |
Hmm. it looks like its always gonna be 90 degrees no matter how stiff or how soft the rotorblades are. Helicopter aerodynamic student toled that it will be 90 degrees no matter what kind of rotor head it is due to laws of physics. I must say it starts to make sense now. A physical evidense is my Rc helicopter that is extremely stiff and yet has exactly 90 degrees between maximum feathering and direction of travle. I can buy softer O-rings and softer rotorblades but the heli will fly the same without changing any mixing or controls. So that only can mean that the mechanical gryo precision are the deciding factor. I am not sure but I believe right now that it is 90 degrees for anything and any kind of rotor. It seems different experienced people say divided things about this
Joined Jul 2012
I just want to tell, that I'm reading this topic from beginning. I'm on page 10 atm.
Alot, alot and alot of information I require. I had no idea that rotor aerodynamics is so complicated. I am plane pilot atm, and I want to try to build autogyro from heli kit. I had the HK450 kit and I'm waiting for tail surfaces, motor mount, servos and props. Want to try 3500k/v brushless motor with 4x4 prop. mnowell129, I want to thank you for this topic. After all this years it is still needed o) P.S. Sorry for my english. |
Wallingford, Ct
Joined Sep 2001
yak55x,
I just read this thread for the first time today and noticed your post 283. I can answer the question you had regarding the first video. The camera was attached to the blade by the bolts that attach the control horn to the sleeve looking outboard a couple of inches forward and above the blade leading edge. It went through the same feathering, flapping, and hunting motions as the blade. The only blade motion visible is blade bending. At the time it was taken the tip path plane was nasty. It was a few feet thick. If the camera was mounted on the hub inboard of all hinges it would have looked very different. |
OK then Mike, here goes. I scratch built a Gyro Shtick years ago and flew it while living in Florida. Probably have 20 flights on it. Always had an issue with orientation, so I covered it in pink Monokote for visibility. I remember back then, in 2003 or 2005, that I had to put some lateral rotor tilt in it to fly level. It was common practice back then. So, setup like that, in stock configuration, my DC Gyro Shtick flew quite well, as can be seen from the photos, but again, every once in a while I would loose orientation and darn near crash the thing. It was so nerve wracking I just stopped flying her. Back in 2008 I added a Delta head from Flying Balsa that they were designing for their PT25 Gyro. At the same time I added a steerable rudder as well so I could try ROG. Moved north to NC just after doing that and never got to fly the little bugger again. So, now I want to resurrect her and in doing so I installed a DX8 radio in it and a Guardian set for on/off and 2D, for those lost orientation moments.
My problem is, I can't remember if the lateral tilt trim was left or right. Also, since I now have a delta head on her, do I need that tilt trim at all. Once I get her airborne and trimmed I am not so worried, it's just that first toss that concerns me. I read all of your Sticky's and it brought back a lot of the stuff I had learned years ago, but I saw no mention in any of those sticky post about lateral tilt trim. I have a set of 1.5" AeroBalsa blades on it and man do they spin up easy. Sure would appreciate any input from you. Tom |
