Go Back   RC Groups > Aircraft - Exotic and Special Interest > Auto Gyros
This thread is privately moderated by mnowell129, who may elect to delete unwanted replies.
Old Feb 28, 2009, 09:07 PM   #376
The Art of the Helicopter, by John Watkinson
Elsevier Butterworth-Heinemann, London, 2004
p. 349
The cyclic control requirements of the helicopter and the gyroplane are identical. As was seen in Chapter 4, the tilting hub with flapping hinges gives exactly the same cyclic control as a hingeless head with feathering hinges and a swashplate.
p. 350
The upward inflow of the gyroplane suggests a rather different rotor design to that of the helicopter. The blade twist should be reversed compared to that of the helicopter, i.e. the root should have less pitch than the tip, although the amount of twist needed is smaller. In practice, many gyroplanes are built with no twist at all, for economy.
mnowell129 is offline Find More Posts by mnowell129   Reply With Quote
Old Mar 01, 2009, 04:12 AM   #377
PeterO_UK's Avatar
Micky,
I'm not quite sure what the second quote means. For example it could mean....
1) Tip has positive pitch and the root has less positive pitch
or
2) Tip has positive pitch and the root has negative pitch
or
3) Tip has zero pitch and the root has negative pitch.
All those examples could have the same twist on the blade, so I guess it comes down to what is the average (collective?) pitch ?
PeterO_UK
PeterO_UK is offline Find More Posts by PeterO_UK   Reply With Quote
Old Mar 01, 2009, 08:29 AM   #378
The blade will generally have positive pitch with respect to the local airflow. But this is not the same as pitch with respect to the rotor shaft. A blade with negative pitch with respect to the rotor shaft can and will have positive pitch with respect to the local airflow. The point of the quote is that the blades will benefit from twist with the root being less than the tip, regardless of what the tip setting is compared to some fixed reference like the shaft.
Old May 28, 2009, 02:31 PM   #379
akelelias's Avatar
I still don't understand how forward motion keep spinning the blade and create lift.
akelelias is offline Find More Posts by akelelias   Reply With Quote
Old Jun 07, 2009, 05:07 AM   #380
delete me
bikerestorer is offline Find More Posts by bikerestorer   Reply With Quote
Bored? Want to fight?
Join the RCGroups clan!
