This thread is privately moderated by mnowell129, who may elect to delete unwanted replies.
Old Jan 15, 2009, 04:32 PM
mnowell129 is offline
Find More Posts by mnowell129
Mickey from Orlando. Really.
Joined Nov 2004
Originally Posted by yak55x
So you are usually at 0 degrees.
Geometrically they look negative, but aerodynamically they are around 0.
Do your rotors autostart ?
Nope, they take a hand spin at the minimum. Most of mine have pre-rotators because I hate the appearance of having to hand spin and I can taxi out at my field and take off like any other kind of aircraft, rather than having to stand in the runway.
Are your blades very rigid?
Not like my carbon heli blades, but the CG's are correct. I tried without and got goofy flight.
mnowell129 is offline Find More Posts by mnowell129
Old Jan 15, 2009, 05:33 PM
yak55x is offline
Find More Posts by yak55x
yak55x's Avatar
Chandler Arizona
Joined Feb 2004
[QUOTE=mnowell129]Geometrically they look negative, but aerodynamically they are around 0.
I define pitch as in relation to the plane of rotation, I'm pretty sure I'm on the same page there. In maintenance they refer to the pitch rigging which to me is just setting up the min - max travels. I complety get the difference between AOA and pitch. What do you mean by geometically and aerodynamically? Do you have washout in the blades? How do they look negative?
yak55x is offline Find More Posts by yak55x
Old Jan 15, 2009, 06:50 PM
Joined Nov 2004
Most non-engineers consider the angle of attack measured from the chord line, the line drawn between the leading edge and trailing edge. But the angle of attack is against the zero lift line, the line where if parallel to the relative wind, the airfoil makes no lift. My blades look negative on the model but are close to 0 aerodynamically.
Old Jan 15, 2009, 07:15 PM
yak55x is offline
yak55x's Avatar
Chandler Arizona
Joined Feb 2004
My blades look negative on the model but are close to 0 aerodynamically.[/QUOTE]
Mmmmm. I've never noticed the zero lift angle being used like that, just a zero lift line or zero lift axis. So for a cambered airfoil would be a negative angle from the chord line to the axis of rotation. Ok, will mill that over - feels like I'm getting somewhere.
But the angle of attack will change quite a bit during flight. And I don't have a problem with AOA being positive - I'm looking specifically at the chord line in relation to the axis of rotation. If it looks negative on your model then what would a measurment of the chord line be in relation to the plane of rotation? A guess is ok.
If I were to say a rotor or propeller is at a particilar rpm, and pitch, how would you know which direction the propwash or rotor wash was going? The pitch? It still seems like the pitch determines the direction of flow through the rotor disk to me. Unless in some extreme sitiuation of decelleration.
So it still seems like to me you decide a few factors such as pitch, rpm and blade dimentions and the arrows get figured out from that.
It seems like the popular explanation is getting the answer it want's by arbitrarily drawing the RW vector from below even though the pitch is positive. I just seems to go agains the grain - or airflow in this case. But I'll keep working on it...........
Old Jan 15, 2009, 08:13 PM
Joined Nov 2004
It looks negative relative to the plane of rotation. How it looks to the model or the ground, I don't care.
No, you have pick the flight condition you want to analyze. Say you have a rotor rigged at +1 degrees and you want to know how much power is required to hover. Then figure that the lift required per blade, etc, then given the rotor rpm and drag you can compute the power input required.
If you pick a 1500 fpm descent, then recompute based on a upflow of 1500 fpm, figure out the rpm, drag, etc and compute the power required is negative, meaning you can take power from the rotor. Or at a different sink rate you get power required = 0, i.e. autorotation, etc.
You can't just look at the pitch and RPM in a vacuum, you have to establish other conditions that you are evaluating for, then you get to draw vectors for that situation.
You're trying to make it simpler than it can be.
Old Jan 15, 2009, 08:27 PM
yak55x is offline
yak55x's Avatar
Chandler Arizona
Joined Feb 2004
[QUOTE=mnowell129]It looks negative relative to the plane of rotation.
So what would a guess be as to what that negative angle is on your particular gyro?
Thanks, this is what is important to me.
Old Jan 15, 2009, 09:37 PM
Joined Nov 2004
[QUOTE=yak55x]
-4 -6 degrees with no pre-rotator, I've run -1 to -2 with.
Old Jan 17, 2009, 09:40 PM
yak55x is offline
yak55x's Avatar
Chandler Arizona
Joined Feb 2004
Thank you BTW Good info
Old Jan 18, 2009, 08:11 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Following rate formula
writing down the explanations for the metric version of the following rate formula as a normal post was too complicated for me. I put it all in a Word document (Word 97 to 2003) and attached it to this post.
Jochen
JochenK is offline Find More Posts by JochenK
Last edited by JochenK; Jan 20, 2009 at 04:49 AM. Reason: new formula for factor a
Old Jan 18, 2009, 11:21 AM
Hephaistos is offline
Find More Posts by Hephaistos
Tannenzäpfle-Terminator
Hephaistos's Avatar
Baden-Baden, Germany
Joined Dec 2008
A Copy of Jochens word document (just copy & paste) first, to have it somewhere else then in an attachment:
<< START QUOTE JOCHEN_K >>
According to John Drake the formula for the following rate N of the main rotor of a model helicopter is:
N = ω • a • c • ρ • R4 / (16 • I)
Simple parts of the formula:
ω is the angular velocity of the rotor in s-1. You can calculate the rotor’s angular velocity using the following formula:
ω = n / 60 • 2 • π (corrected according to JOCHEN_K)
With n being the rotor’s number of rotations per minute (which, in the formula, is divided by 60 to get the number of rotations per second).
c is the length of the blade chord in m.
ρ is the density of the air in kg/m³
R is the tip radius of the rotor in m.
The difficult parts of the formula:
a = δ CL / δ α
The δ in this formula denotes a difference. You have a graph, in this case the polar graph of your profile, and you want to know how steep this graph is at a certain point. On the graph you mark two points, one a bit to the left and one a bit to the right of your point if interest. From those two points draw vertical lines down to the x-axis (that’s where α is) and horizontal lines to the y-axis (that’s where you find CL). Now take a reading of the difference between the two CL-values (δ CL) and the two α-values (δ α). Before you divide δ CL by δ α, you have to convert the δ α value which is normally given in degrees, into radians. This is about the same as converting rpms to ω. Use the formula
δ α [radians] = δ α [degrees] • 2 • π / 360
to do this. Now calculate a.
I’ve had a look at the polars of the SG 6042 profile we’re often using. For a Reynolds number of 40000 (that’s the region the Micromum’s rotor is working in) I get something like a = 5.7, for the rotor of the RPG with a Reynolds number of about 120000, I get a = 6.9.
I is the blade’s flapping moment of inertia in kgm². The basic formula for the moment of inertia is:
I = ∫ r2 • dm
With dm being the mass (in kg) of a very, very, very thin slice of the profile at a distance of r (in m) from the rotor axis. The ∫ is the sign for an integral, which is a mathematical expression for summing up something, in this case the masses of the thin slices multiplied by the squares of their distances to the rotor axis. We can express dm in another way:
dm = m / R • dr
The thin slice of the rotor blade has a thickness of dr (in m). If we divide the total mass m (in kg) of the blade by the blade length R (in m), we get something like the specific weight of the blade’s cross section, and when we multiply this specific weight with the thickness of the cross section we again get the mass of the slice. The formula for I now looks like
I = m / R • ∫ r2 • dr
We now integrate this expression from the blade root (r = 0) to the outer blade radius r = R (we are summing up all the tiny (r2 • dr) values) and get:
I = m / R • R³ / 3 = m / 3 • R²
That’s it.
<< END QUOTE JOCHEN_K >>
Hello Jochen……….
Now I understand this thing with the following rate. You made a very good job with explaining this. The integration of the inertia of mass assumes a constant density of the blade. If we use some tip weights, the resulting moment of inertia will be higher, because the radius is going quadratic to the equation!
Or in other words: For showing the influence of the tip weights on the following rate, we will need a formula, which will calculate the moment of inertia with respect to the mass of the tip-weight and its position. There will be some integration needed, too. Or just making a CAD-model of it, the CAD calculates it automatically.
Concerning the following-rate, it will be better and more effective to make a tip-weight really concentrated in the tip than just making the blades heavier with some heavy covering on full length that’s not needed!
One question: Where did you get the dragpolars for the SG 6042 at low Reynolds numbers from? I searched for dragpolars sometime ago, only thing I found with some importance to modelism were profile-cuts and dragpolars for Fi 156 STORCH and the suction-planes (ABSAUGFLUGZEUG) AF 1 and AF 2.
The value for a, which describes the steepness of the dragpolar at a certain point, will be different for every angle of attack you extract it. It’s a curve, and not a line, this dragpolar. I assume you calculated a for some point on the curve you think it would be in the right range, but the angle of attack changes along the blade, depending on the rotor-RPM, the airspeed of the gyro, the angle of the spindle relatively to the airstream and last but not least the radius of the point on the blade you are actually looking at. I don’t even want to think about the twist of the blade. And one thing I really believe in is the following: Construction of good gyro-blades doesn’t only include shaping the right profile, it also includes having the construction in a way that makes them twist in the right way when the blades are working……..
Bye
Hephaistos is offline Find More Posts by Hephaistos
Last edited by Hephaistos; Jan 19, 2009 at 02:17 PM. Reason: corrected mistake in formula
Old Jan 18, 2009, 02:50 PM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Mike,
here's an addition to my last post. It integrates tip weights into the formula for the moment of inertia.
Polars: I got the values for C-lift from a program called Profili v2.2. It’s shareware and costs something like 10 Euros.
Jochen
Old Jan 18, 2009, 11:42 PM
Hephaistos's Avatar
Joined Dec 2008
Hello Jochen.........
Good job. If I calculate the following rate of a given rotor, one time with adding a brass wire on the whole lenght of the leading edge and the other time with the same mass concentrated on the tip, I get some significant differences.......
So i suppose that it would be best to use tungsten-wire for the tip weights. Tungsten has almost the double density of lead and more than double density than the soldering-wire commonly used.
So it will help to concentrate the mass just a little bit more on the tip.
But where to get some tungsten-wire? Go for welding electrodes from TIG-welding. Its tungsten-wire, diameter from 0.7mm up to 4.0 mm available, length about 200 mm, price: about two euros for diameter 1.5 mm.
On your first calculation or the angular velocity you wrote ω = n / 60 • 2 • π / 360.
Where does the 360 comes from? To my opinion it should be ω = n / 60 • 2 • π...........
Bye
P.S.: Have you already tried the formula-editor included in word? Its the perfect tool for writing formulas.......
Old Jan 19, 2009, 03:16 AM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Mike,
you're right. I've corrected the mistake in the original document, can you delete the '360' in the copied post?
Jochen
Old Jan 19, 2009, 03:03 PM
Hephaistos's Avatar
Joined Dec 2008
Hello Jochen..........
I changed the copy of your document.
When I use the formula for a rotorblade something like the RPG with blade weight 60 grams, tip weight 10 grams, 800 revolutions per minute, Radius 0,65 meters and a equals 6.9 like you calculated, I have the following results:
1) blade without tip-weight, mass 60 grams: J=0.00845 kg/m², N=46.7 (following rate)
2) blade with brass wire on full lenght, total mass 70 grams: J=0.00986 kg/m², N=40.0
3) blade with 60 grams, tip weight concentrated on tip with 10 grams: J=0,01268 kg/m², N=31.1
Okay, its clear: tip weights are better then a brass wire on full lenght for lowering the following rate.
But: The values I get for the following rate are much to high to control this rotor. But the RPG flies with this rotor.
Whats wrong? I checked my calculations twice, no error found.
Some mistake with the moment of inertia? I checked it with the CAD, same result.
The RPG is in the air, no doubt about this fact.........
Possible reasons: Mistake in calculation, mistake in formula, or formula is okay for helicopters, but a well designed autogyro like the RPG doesn´t care about the control rate too much.
I don´t know......
Bye
Old Jan 19, 2009, 03:59 PM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Mike,
I'm not sure what the factor a really means. John Drake had an original factor a of 5.73 which he then reduced to 3.75 and I don't know how he got this factor. That's one thing, the other one's that the formula is for helicopter blades. From what I've seen, these blades can't move 'vertically' as our gyro blades do around the flapping hinges, and that may influence the absolute values calculated. For relative calculations the formula seems good enough.
Jochen
