Old Sep 13, 2002, 03:32 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
Question
Eclipse TX with V-tail, setup?
Sorry if this is a newbie question, but I'm a newbie when it comes to HLG. Transitioning from my FocusIII to my Eclipse for a V-tail HLG (Gambler from Wright Brothers RC), no ailerons or other control surfaces. I have the two servos on CH2 and CH4 per the Eclipse instructions. With the V-tail mode enabled I have elevator control the right stick and rudder control on the left stick. I can understand this is preferable if you have a glider with ailerons as you would want them on the right stick. But how about with a simple V-tail like this? Should I try the Elevon configuration or use mixes to get the rudder-type control on the right stick so I am just using a single-stick for control?
Thanks in advance.
10Thumbs is offline Find More Posts by 10Thumbs
Old Sep 13, 2002, 03:43 PM
greg morrison is offline
Find More Posts by greg morrison
San Francisco
Joined Jul 2000
You should just be using a single stick for control on your Gambler. I don't have an Eclipse Tx but you should easily be able to do this in the V-Tail mode. I'm just guessing but maybe you should connect the servos to channels 1 & 2 rather than 2 & 4.
Greg
greg morrison is offline Find More Posts by greg morrison
Old Sep 13, 2002, 03:52 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You need to add a mix.
Need to mix ailerons to rudder at 50-100%.
That way when you move the right stick for ailerons, it'll activate the rudder part of the V-tail mix. This is SOP for setting up R/E gliders with V-tails.
ian
Daemon is offline Find More Posts by Daemon
Old Sep 13, 2002, 04:27 PM
tom_yellowblue is offline
Find More Posts by tom_yellowblue
Sunnyvale, CA
Joined May 2001
I'm not sure about the Eclipse, but on a Futaba you can control a V-tail by using using channels 1 and 2 and setting it up for elevons. This allows you to control it using the right stick. You may have to play with the servo reversing and switching which servos go to which channel, but you should be able to get it to work.
tom_yellowblue is offline Find More Posts by tom_yellowblue
Old Sep 13, 2002, 04:38 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Same thing on a Flash 5 so the Eclpise shoul be the same.
V-Tail enabled on channel 2&4 and the VT works fine, but moving the left stick will owrk the rudder too.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Sep 13, 2002, 05:53 PM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
I have the Eclipse 7 and I'm using channel 1 and 2 and elevon mixing in ACRO mode. Seems to work good.
After reading the thread, can someone comment as to whether it would be better to run in Glider mode and use the v-tail option?
Victor
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Sep 13, 2002, 06:18 PM
Paul Willenborg is online now
Find More Posts by Paul Willenborg
Registered Lifeform
Paul Willenborg's Avatar
Little Rock,AR,USA
Joined Jun 1999
Victor,
I think you are exactly right- for a rudder/elevator glider using an elevon or delta mix is the much simpler solution. There is no reason to have rudder control on two sticks, and no reason to do complicated programming for a simple glider.
Paul
Paul Willenborg is online now Find More Posts by Paul Willenborg
Old Sep 15, 2002, 07:34 PM
Allan Wright is offline
Find More Posts by Allan Wright
Gambler-AG DLG Designer
Allan Wright's Avatar
Lee, NH, USA
Joined Jun 2001
With the eclipse, you use the 'Elevon' mix for a 2-channel V-tail plane. The 'V-tail' mix puts the rudder and elevator into the mix, you really want the aileron and elevator mixed, and that is the elevon mix on the Eclipse.
Allan Wright is offline Find More Posts by Allan Wright
Old Sep 15, 2002, 09:22 PM
10Thumbs is offline
Motor Maniac
Orange County, CA
Joined Feb 2002
Many thanks to all
Thanks for all the responses. For now I have settled on using the elevon mix on channels 1 and 2. This does seem the simplest way to set up a V-tail glider with no ailerons. Flew it a bit this weekend with this setup and liked it.
Ian, your method would work, but would take one more step in the setup. Nothing really wrong with doing it that way.
Greg, the Eclipse V-tail mix requires the two servos on channels 2 and 4. Ailerons are on channel 1. I guess this is different on different computer TX's.
Allan, got my best flight so far, 45 seconds. May not sound like much to veterans, but it was a major improvement for me. There wasn't much lift, just enough to eke out a few feet of altitude once or twice, but that was enough to add 20 seconds to my average flight time.
Old Sep 17, 2002, 10:35 AM
EdSoars is offline
Find More Posts by EdSoars
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
V-Tails
I have had a Flash5X and now have an Eclipse. You're right that it is simpler to set up a rudder-elevator V-tail ship as elevon, but if you're going to move toward aileron or flaperon ships in the future, you might as well set it up right with the V-tail mixes available on the Eclipse in GLID mode.
Most importantly, when you want to use preset launch, cruise, thermal and landing trims for rudder and elevator, using the Flight Condition and Flight Mode switches (VERY POWERFUL features) you'll have the servos plugged into the correct channels. With the rudder and elevator being run as elevons, the situation will be hopelessly confused.
EdSoars is offline Find More Posts by EdSoars
Help! JR TX V-Tail Setup...help please... LexTalionis Parkflyers 7 Mar 07, 2009 03:08 PM
Help with programming Eclipse for inv V tail DiveBombDave Hitec/Multiplex USA 2 Nov 09, 2005 08:52 PM
Elevon or V-tail setup with Berg/MX Cockpit TexasJohn Radios 2 Dec 08, 2004 04:10 PM
Need help with V-tail mixing Hank Electric Plane Talk 5 Nov 28, 2001 07:38 PM
Smart V-tail setup? Hammer Electric Sailplanes 2 Oct 30, 2001 10:14 PM
