Old Dec 21, 2006, 11:07 AM
Whorges is offline
Find More Posts by Whorges
United States, CO, Aurora
Joined Sep 2005
Any thoughts on the Sharpwind F3J?
I'm into flat land thermal flying and am considering the Sharpwind.
I'm wondering what people's experiences have been and how the build is.
Does it come with the needed servo extensions and connectors?
How does it fly? How does it hold up strength wise?
Whorges is offline Find More Posts by Whorges
Old Dec 21, 2006, 12:36 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
What is it? Pics and specs please...
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Dec 21, 2006, 02:55 PM
D_Ryan is offline
Find More Posts by D_Ryan
Williamsburg, VA
Joined Apr 2004
Sharp Wind
Whorges;
Try thess...
http://www.soaringusa.com/products/p...ategory_id=293
and
http://www.valentamodel.cz/#
r/
Dave
D_Ryan is offline Find More Posts by D_Ryan
Old Dec 21, 2006, 03:11 PM
Bernd Brunner is offline
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
Hi Marc,
look here: http://www.valentamodel.cz/sharp.htm
Regards,
Bernd
Bernd Brunner is offline Find More Posts by Bernd Brunner
Old Dec 21, 2006, 03:17 PM
dare to thermal
Mannheim, Germany
Joined May 2004
Hi Marc,
Regards,
Bernd
Old Dec 21, 2006, 03:28 PM
dare to thermal
Mannheim, Germany
Joined May 2004
Hi Marc,
Regards,
Bernd
Old Dec 21, 2006, 03:52 PM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
One of the guys in my club has one. It's on the heavy side. No ballast needed...ever.
mlee8249 is offline Find More Posts by mlee8249
Old Dec 22, 2006, 02:02 AM
Jurgen is offline
Find More Posts by Jurgen
Europe - Belgium
Joined Mar 2005
http://www.rcgroups.com/forums/showthread.php?t=601959
Cheers, Jurgen.
Jurgen is offline Find More Posts by Jurgen
Old Dec 22, 2006, 02:41 AM
oakman7004 is offline
Find More Posts by oakman7004
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
Well everything is relative...
Anyhow my friends weighted empty 1817g out of the box...
So it is not a floater but should work fine other days.
Good pics here fore those who doesn't understand swedish.
Del 1 = Part 1
Del 2 and 3 and 4 (part2,3,4) on the bottom is containing more pics...
sharpwind
/Jonas
oakman7004 is offline Find More Posts by oakman7004
Old Dec 22, 2006, 06:04 AM
Joined Nov 2005
Mike,
Does your guy have issues with the elevator linkage on this thing? One of the guys in FWA has the built up version and I do not like the feel of that set up. Wish it was an all flying stab.
Marc
Old Dec 22, 2006, 10:50 AM
Jurgen is offline
Europe - Belgium
Joined Mar 2005
Jonas, can you please translate the part of flight behavior of the SW?
Thanks in advance,
Jurgen.
Old Dec 22, 2006, 03:03 PM
mlee8249 is offline
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Marc,
Our guy has not had any problems with the elevator linkage, but he does wish it was all flying. His main problem with the plane has been its' allergy to trees....know what I mean?
Old Dec 22, 2006, 03:05 PM
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
OK a quick translation comes here. Please bare with me if I have some grammatic errors. It happens easily when translating a swedish sentence. It easy becomes swenglish..
Del 4 =Part 4
First paragraph: just covers that he had some up trim . He did the mounting to quick. After ensuring that the trim were neutral he tried again.
Second paragraph: Hand throw the glider and it went straight without any trim. Time to test on a high start. With a small amount of start flap the glider went straight up the line. After a few starts and some turns in the calm air it was time to check the CG. No info were given from the manufacturer for the CG and throws. Now followed some testing with CG 98,95,90 and 85 mm from LE. The supplier did A check with the manufacturer and got the recomendation to have the CG at 81mm from LE. This should mean extensive amount of lead in the nose and too forward CG, which is not up to my taste.
Third paragraph: After testing in calm and windy conditions I ended up with CG 95 mm from LE. In calm weather the CG should actually be some mm more to the rear, but in windy conditions the choosen setting works better. And it is in windy conditions I intend to use the SW over the Graphite.
Fourth paragraph: with the hook infront of the CG the starts are a walk in the park. Thermalling in steep angels is done with ease inside the thermal. One doesn't feel the big span at all. Speed increases in thermal and the glider increases altitude quickly. In windy conditions one would like to have some more speed and the possibility to add ballast should be considered.The big flap makes landing easy. The neutral setting of the flap shouls be aligned with the aileron, don't use the fuse marking. To much snapflap and the glider have tendences to come out with nose high after a turn.
fifth Paragraph: SW is a good allround glider working good from calm to windy conditions. In heavy wind one needs ballast to penetrate good.. The starts goes straight without any sideways wobbling tendencys and with correct CG and hook position the launces are good. The kit is of highest quality and installation is quick and easy. "
thats it, enjoy reading!
/Jonas
Old Dec 24, 2006, 08:59 AM
emersunn is offline
Find More Posts by emersunn
Some restrictions apply
emersunn's Avatar
USA, AZ, Tempe
Joined Feb 2003
I had a different Valenta Model Plane (TXL 4M) and the build quality was excellent, but it came out a little heavy. Strong plane.
emersunn is offline Find More Posts by emersunn
Old Dec 28, 2006, 03:49 AM
billscottuk is offline
Find More Posts by billscottuk
Bill Scott
billscottuk's Avatar
United Kingdom, Northern Ireland, Belfast
Joined Nov 2002
Qefi
There was a review of this done in QEFI a while back, by of all people "Brian Sharp"!
If you want I can probably dig the article out. PM me
billscottuk is offline Find More Posts by billscottuk
Any thoughts on the Sortakhoi ARTF SU-27 Jet funflyer Electric Ducted Fan Jet Talk 44 Dec 04, 2005 09:43 AM
Any thoughts on the Sortakhoi ARTF SU-27 Jet funflyer Electric Plane Talk 3 Jan 14, 2002 09:53 AM
Any thoughts on NSP Filip E and Krontronik 200 DannyGayhart Electric Sailplanes 6 Nov 23, 2001 09:42 AM
Any thoughts on hitec flight packs? f2racer Electric Plane Talk 5 Sep 29, 2001 08:22 AM
Any thoughts on airfoil for 400/480 stuka with scale wing kit basher Power Systems 3 May 19, 2001 11:21 AM
