Old Aug 28, 2007, 11:00 AM
canard addict is offline
Find More Posts by canard addict
Joined Jun 2005
Successful D Squared Maiden
The elevator trim was set to zero with full throttle and the model pulled up to a gentle climb with back pressure on the elevator. As the elevator was returned to neutral, it nosed down and required full up trim to fly level. The fast taxi with full up trim told the story as did the chuck glider at 3.5 degrees and a nose down glide. The plans need to show 4 degrees incidence on the canard. The roll is straight line axial and quick, Magic 612, and with UP elevator, the ship just rotates around the CG. I used aileron and elevator centering to put the ailerons at 1/8" UP reflex and the elevators at 1/16"+ DOWN with the trims at neutral. The second flight went well and there were two smooth landings with a click of UP trim. Randy at www.m-a-e.com has agreed to make a video for us soon. I am pleased with the flight characteristics which are much like the Egret which was used as the base layout. It is stable with no wobble at all speeds. Loops and inverted flight looked good. The plans are in four small sheets and if anyone wants a set,I will run them off at cost. It is simple construction and a quick build. Charles
canard addict is offline Find More Posts by canard addict
Old Aug 28, 2007, 12:41 PM
magic612 is offline
Find More Posts by magic612
Bernoulli+Newton=Lift
magic612's Avatar
Somewhere south of Chicago, IL
Joined Jan 2006
Originally Posted by canard addict
The roll is straight line axial and quick, Magic 612, and with UP elevator, the ship just rotates around the CG. ...............I am pleased with the flight characteristics which are much like the Egret which was used as the base layout.
Good to hear the maiden was successful!
Charles, did you find that the controls felt any different using the linked elevons / canard set up? Any other thoughts on the handling?
The one maneuver I found that really was different was pulling out of a dive: From straight down, my J1-31 (which has that same linked setup) would snap out of a dive into horizontal flight much more quickly than any other canard or standard plane I have.
magic612 is offline Find More Posts by magic612
Old Aug 28, 2007, 05:13 PM
John235 is offline
Find More Posts by John235
John235's Avatar
Sydney, Australia
Joined Mar 2006
HI Charles, I am glad to hear it went well. How is the landing speed compared to the Egret. Can it fly at high AOA?
I am looking forward to the video.
John235 is offline Find More Posts by John235
Old Aug 28, 2007, 05:17 PM
Joined Jun 2005
Magic 612, The control is probably the best ever.I set it at 100% end points with 50% expo and I like the way it feels. I pulled UP from level and could tell the rear wing was tucking under. Also the roll is positive with ailerons on both wings. The landing approach looks great with the nose high while the main wing is level. Without your control scheme this model would just be another of the same. Thanks again! Charles
Old Aug 28, 2007, 05:23 PM
Joined Jun 2005
John235, I know from the RAMS experience that this model will just creep in at nose high attitude because of the compact wing area. Weather permitting the video could be taken tomorrow. I look forward to learning to fly this little guy much better. I was nervous today and did few tricks. Charles
Old Aug 28, 2007, 06:59 PM
magic612 is offline
magic612's Avatar
Joined Jan 2006
Awesome! Great to hear, Charles. I'm glad you like that set up - I'll definitely be employing it again myself in a stick-built J1-31, and perhaps other future canards as well. It's a bit of extra work to do it right, but I do like how well a canard flies using that configuration.
Old Aug 28, 2007, 07:31 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
Congratulations Charles! I was sure D Squared would fly great! I think I'll just have to build one now that yours has flow,. Please let me know how much the plans would cost shipped to 34474.
MustangAce17 is offline Find More Posts by MustangAce17
Old Aug 29, 2007, 02:32 PM
rcflyer11 is online now
Find More Posts by rcflyer11
rcflyer11's Avatar
Lilburn, GA, USA
Joined Dec 2000
Guys & Gals -- You can check out the video HERE.
Randy
Model Airplane Engineering
www.m-a-e.com
rcflyer11 is online now Find More Posts by rcflyer11
Old Aug 29, 2007, 03:11 PM
Joined Jun 2005
Thanks, Randy for the excellent work against the tough grey background. I promise to practice my right turns for next time. Charles
Old Aug 29, 2007, 03:20 PM
EDF Addicted
Joined Sep 2005
Randy, will you please post this video in "electric videos" also, my comp. will not allow me to view it off the desktop. Thanks
Old Aug 29, 2007, 03:33 PM
seven_up is offline
Find More Posts by seven_up
Joined Aug 2007
Info to Canard-video
Hi, I found a link to this video in this forum
http://www.ultraligero.net/Media/Videos/ulm/191.html
it shows a very stable and slow flying REAL canard. Does anyone have some information e.g where it is build etc.?
Would be great!
Tom
seven_up is offline Find More Posts by seven_up
Old Aug 29, 2007, 04:10 PM
Joined Jun 2005
It looks like the Goldwing to me. It is available as a home build or factory built. It has a sister ship named Goldduster. 25 hp Zenoah,empty 250 pounds.
Old Aug 29, 2007, 07:20 PM
John235 is offline
John235's Avatar
Sydney, Australia
Joined Mar 2006
I loved the video. The D^2 looks very stable and the controls appear to have good authority. It seems quite the opposite to the video of the Shinden that flys with more of a nose up attitude. I wonder if it might be due to the low wing loading in the case of the D^2. It was well flown by the pilot too.
Are there any videos of the Egret?
Old Aug 29, 2007, 08:02 PM
rcflyer11's Avatar
Lilburn, GA, USA
Joined Dec 2000
Sure thing! Here's a LINK
Randy
www.m-a-e.com
Old Aug 29, 2007, 08:10 PM
EDF Addicted
Joined Sep 2005
thanks a bill Randy.Charles, I'll be coming to the Electric event at Mac's Sept. 29 most likely and would like to get the Ga Goose and D Squared plans from you. Thanks
EDIT, I"m IN LOVE with D Squared! it flies excellent! great job Charles!
