Also, if the job of the wing is reduced because you handed off some of its lift-making task to the canard, then you can make the wing smaller. However, you can't make it as much smaller as the amount of lift you reallocated to the canard, because you still have to make absolutely certain that the wing can never stall. Thus, your total wetted area ends up being greater, which results in more skin friction. As far as the incidence of the wing being lower, not necessarily. If the canard is making positive lift, then it is also making downwash. Because of this, there is an induced "downdraft" behind the canard that the wing must fly through, which increases the wing's required incidence angle. Quote:
If you put flaps on a canard's wing, you then have to find some way to add more lifting ability to the canard in order to hold the nose up so you can use that extra wing lift from the flaps. However, if the canard has more lifting ability, then you have to figure out how to keep the canard from being able to pull the wing up into a stall when the flaps are retracted. That's what forced such mechanical contrivances as that variable sweep canard, linked through an elaborate jackscrew actuator to the wing flaps, on the Beech Starship. |
Joined Jun 2005
Canard Power Requirements
Don, It looks like three strikes and I'm out on that last post. It seems that I read where a new canard super sonic liner was in the works which had no sonic boom and took 30% less power to fly. I just can't recall which thread or news item had the information. Maybe Airboat Flying Ship can help here. It led me to believe that canard liners were in solid for future high speed travel. As time passed, I must have let the 30% enter into slower canards. We are here to learn and your disscussions are great. Thanks and please don't go away. Charles
Seriously though, the key term in your statement above is "supersonic". The rules for that are totally different. OK, one item at a time: About the only way to not make a sonic boom is to keep your speed below Mach 1. It is possible to try to minimize shock waves, but as long as you are going to go at supersonic speeds, you're pretty much guaranteed one at least at the nose and another one at the tail. They look like giant cones being dragged along by the vehicle, like the v-shaped bow and stern waves in the surface of the water from a speedboat. About the only way to keep folks from feeling/hearing it go past them on the ground (what we call a "sonic boom") is to be so high or so far away (and we're talking a lot of miles here) that the shock wave dissipates before it gets to them. Anyplace you have a sudden change in the cross sectional area of a supersonic or transonic (i.e.: where the plane is subsonic overall, but close enough to Mach 1 that the local airspeed around bulges, high points on airfoils, etc., can exceed Mach 1) aircraft, another shock wave tends to form, adding additional "wave drag". The added cross section at the wing is one example. The idea behind "area ruling", such as a "wasp-waist" or "Coke bottle" fuselage, is to slim down the fuselage in the vicinity of the wing so that the reduced cross section of the fuselage compensates for the added cross section of the wing. This can dramatically reduce the intensity of the shock waves formed by the wing, and the resulting wave drag. Another example is the "extended upper deck" on some of the later Boeing 747's. Airliners like that are fast enough to get some local supersonic flow, and theefore they have to deal with wave drag. When they extended the upper deck, it filled in the region between the aft end of the original bulge behind the cockpit and the leading edge of the wing. This smoothed out the cross-sectional area distribution along the forward part of the airplane, which reduced the intensity of the shock waves formed by the aft end of the original bulge and the leading edge of the wing. The longer upper deck actually reduced drag in cruise. Those "speed fairings" or "Küchemann carrots" on the old Convair 990 airliner served a similar function, smoothing out the cross sectional area plot around the trailing edge of the wing, reducing the intensity of the local shock waves and reducing the plane's wave drag in cruise. There's a nice discussion of this at: http://www.aerospaceweb.org/question...cs/q0240.shtml As far as canards helping efficiency, there is some possibility there when at very high supersonic speeds. In some cases they can arrange the aircraft so that lifting surfaces on the aft portion of the aircraft can "surf" on the shock wave formed by the forward portions of the aircraft, which can help the induced drag (drag that results as a by-product of making lift). The XB-70 was one of the first designs to try to achieve this, with the big delta wing trying to surf on the shock wave from the nose and canard. They also have "waverider" aircraft undergoing study, typically a long parabolic-shaped flying wing, that does this. There are also hypersonic "aerospike" systems where a small probe on the nose creates a shock wave, and the rest of the airplane sort of hides inside of it. The Russians have a supercavitating rocket-powered torpedo in service that does something loosely conceptually related under water (in their case using a nose that uses cavitation to create a vapor pocket, and the torpedo then travels through this gaseous vapor instead of liquid water), which allows it to achieve over 200 knots submerged. However, all of this deals with shock waves and trying to minimize the massive drag that they cause, which is proportionally well in excess of the sort of drag we deal with. None of it applies to the case of a subsonic aircraft. If you don't have any supersonic flow, you don't have any shock waves, so you don't have any wave drag to try to minimize. That's also why things like swept or delta wings don't help efficiency at our typical flying speeds. |
Steven Wong has completed his maiden of his Velociraptor, here is the awesome video:
http://www.rcgroups.com/forums/showa...mentid=1362735 Johnnie |
my take on the double delta canard
Bought this plane from a friend after he won in it in a raffle yesterday and it wasn't his cup of tea. Chopped and moved the elevator and stab forward and wing further back.Not sure on power system or anything at this point but will post when I am.
Charles,your plane is what inspired me
This F-16 look alike is what I started with.http://www.nitroplanes.com/ffijeteparf.html |
Joined Jun 2005
Dixie Delta
Thanks ACE for the info. You have done a good looking job on the re-style. I am Delta crazy now and have let Randy build me his exciting Dixie Delta. This is truly an amazing piece of work. Check it out here. http://m-a-e.com/Sub_Pages/Products/...and_Videos.htm Be sure to look at the flat spins near the end of the video. Charles
Nitroplane F16 EP ARF
Sorry, gang, the F16 EP ARF from Nitroplanes is sold out ... it had been on sale at $40. Still, a beautiful conversion, Mustang Ace!
...and the video is wmv format...just right link and "save target as" to your harddrive...wish they'd edited the soundtrack so we didn't have to listen to the photographer grunting all through the video! pjw |
