Old Aug 19, 2012, 01:29 AM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Nice link Dereck! He did a good job of the build thread.
John:
Who knows it might even be possible to make a sea-plane based on this..
I was thinking of a seaplane like that, where the lower wing of the bi-plane is replaced by sponsons. I guess that would suggest that the canard wing should be smaller, or the main wing bigger. Might work!
nickchud is offline Find More Posts by nickchud
Old Aug 19, 2012, 02:54 AM
Trevorh is online now
Find More Posts by Trevorh
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Sounds like the first model sea cucumber isn't far away!
Trevorh is online now Find More Posts by Trevorh
Old Aug 19, 2012, 12:34 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
That would be a novel model.
Idle thought, not exactly canardly... Doug was renowned for dreaming up models most of us would only have in nightmares! Imagine a diesel powered low winged semi-scale twin with engine cut-offs that would kill the running engine when one cut and a semi-scale rubber powered twin with four fuselage mounted rubber motors running into a nose end gearbox that drove the props via lots of bits of carefully bent piano/music wire. Both were built with no lathes or similar machining in sight either.
At which point, a free flight biplane canard looks very ordinary...
Looking forward to the resurgence of the Cucumber indeed.
D
Dereck is offline Find More Posts by Dereck
Old Aug 26, 2012, 05:14 PM
captarmour is offline
Find More Posts by captarmour
Joined Mar 2011
Hi All, I tested my flying wing with canard replaced by an inverted LE (flat bevel) on the wide forebody (30% of total wingspan) of the center section and got very good stability, even IGE.
captarmour is offline Find More Posts by captarmour
Old Aug 26, 2012, 06:36 PM
Don Stackhouse is offline
Find More Posts by Don Stackhouse
Don Stackhouse's Avatar
United States, OH, Bradford
Joined Jun 2005
If I interpret you correctly, that results in a reflexed airfoil, with the reflexed portion being about the last 95% of the chord. Noot terribly efficient, but it does result in an concave-upwards camber line, and a positive aerodynamic pitching moment.
Don Stackhouse is offline Find More Posts by Don Stackhouse
Old Aug 26, 2012, 08:58 PM
Joined Mar 2011
Reflex on the nose if there is such a thing. I had a canard on it but started thinking of experimenting with a flat bevel on the underside of the LE to act as up (canard)elevator. The entire model is a T shaped flying with the outer wings swept deltas and inner wing ar of .3 sticking forward as a forebody. The inner wing should be at a higher incidence but untill I build next model I thought I would try the bevel which in effect makes it an inverted airfoil. I hope I explained clearly
Old Aug 26, 2012, 08:59 PM
Joined Mar 2011
Correction ' T shaped flying wing'
Old Aug 26, 2012, 09:25 PM
Joined Mar 2011
My idea is contrary to logic because the flying machine I am designing needs to be inefficient OGE, to remain in IMO regs. Today at high speed it remained stable just 12" (about 1/3 wingspan) off the ground. In fact it was very nose heavy and would descend OGE even with full up trim but yet IGE would climb back OGE untill I trimmed down a bit. My goal is to adjust cg and trim to maintain about 1 wingspan height.
Old Aug 27, 2012, 01:26 PM
Joined Mar 2011
http://www.youtube.com/watch?v=Ipdk9...re=context-cha
sorry about poor quality...
take off and level hands off elevons, climbed it for stall test, dropped her nose after i cut power. released sticks after nose dropped and then pulled up and added power. i think she ran out of eleveator before she stalled.
interestingly i moved cg back and although still nose heavy OGE she actually felt a little TAIL heavy IGE, not as solid and smooth as yesterday.
Old Aug 28, 2012, 04:10 PM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Professor Ann Dowling
I've just been listening to a really interesting program about the engineer behind this project to design a silent aeroplane.
BBC: The Life Scientific Let me recommend it - fascinating. She is "Professor Dame Ann Dowling, head of Engineering at Cambridge University and one of the UK's top 10 women scientists and engineers."
Nick
PS Here's a link to the 4-view. The plane was designated SAX-40. Not quite a canard, but it looks an interesting project.
The airframe makes use of a novel centre-body shape with leading edge carving. This balances the aerodynamic forces without the need for a tail, and enables an optimal wing design with an elliptical lift distribution and low cruise drag.
Old Aug 28, 2012, 10:45 PM
Joined Mar 2011
Thanks Nick, she's gr8.
Old Aug 29, 2012, 05:30 PM
Joined Mar 2011
The side view makes it look like the center is an inverted airfoil. That would make it stable without a tail. Also the The forebody mean chord line would be at a higher incidence than the wings and also act as a canard. My model became stable without a tail when I introduced negative camber at the LE of the forebody.
Old Aug 30, 2012, 06:23 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
I've been Googling around and searching for SAX-40 without finding any previous efforts to build a flying model of it.
I think I could make those shapes out of Depron, with the aid of a rolling pin and by cutting out some wedges to make 3-D curves. As you say "The side view makes it look like the center is an inverted airfoil." or just a fat belly . What's going on with that lip around the forebody? It's a bit difficult to see from the diagrams just how big it is and what angles. Technically speaking, could that lip be called a canard?
A lesson I have learnt the hard way is to be sure that those wings will be rigid.
Old Aug 30, 2012, 12:31 PM
Joined Mar 2011
Very interesting.
The bottom of the center looks like an inverted airfoil but the lip (strake) joining the wing/fuse together with the nose and top of fuse looks cambered and at a lower incidence than wing. The lower incidence may not create much lift/drag in cruise but at higher AOA, like on approach, may contribute much lift for a lower app speed.
If the forebody stabilisies the aircraft and produces lift we may venture to say it is a canard.
My 2 cents...
Old Aug 30, 2012, 03:00 PM
canard addict is offline
Find More Posts by canard addict
Joined Jun 2005
Great observations Nick and captarmour, I was thinking the same as you. On modern aircraft, the wings are moving rearward to replace horizontal stabs and extend forward to replace canards. High aspect ratio type wings seem to be a thing of the past. My recent thoughts have been on trying to locate a single motor at the center of the fuselage at the CG point with a low rear wing and a high 50% canard.
It will require a kv of around 2200 and a prop about 4.5 inch diameter.
Captarmour, It would be great to see a picture of your model which was in the video.
Charles
canard addict is offline Find More Posts by canard addict
