Florida, USA
Joined Jun 2008
This is a Steven Wong design of the COZY MKIV made of 5mm depron. It is lightweight, but somewhat fragile. I added landing gear and extra weight and bigger motor. It originally had a "Full flying" canard, it was horrible. I chaged it out to a more conventional stab elevator arrangement. Now it flies good enought that I went ahead and painted it. So maybe some inflight photos soon.
Roger |
Joined Jun 2005
Thanks for showing, Roger. Canard control by moving the entire wing, depending on it's size and speed can be tedious. Using a tiny end point adjustment setting plus exponential may work well. For a new design it could be really helpful to find the perfect angle of incidence for the wing and then lock in in place and add elevators. My initial design was with a fixed angle with canard area ratio to the main wing as recommended by Andy Lennon. Area has been added to my canard wings but never taken away.
I would welcome more views of your work. Charles |
Charles - By the time I joined in with this thread, you guys had more or less settled on a canard of 20% of the wing area with a positive incidence of 2 degrees. I'm not sure of the optimum moment, some of the most successful flyers have had pretty long snouts.
That rule of thumb has worked well for me for a wide range of models. I've never felt the need to try a "live" canard, but I do like control panels that are at least 25% of the total canard area. Then, suddenly you came along with the Delta Duck, much smaller canard and very little moment so you can't really say you've never taken away from your canard wings. I had to give it a try. There's no doubt that it needs elevons, but it's not just a flying wing with a fancy nose appendage. My Polar Duck uses the Delta Duck main wing, but a regular canard with a reasonable moment. It's working really well now that I've found an optimum incidence for the tail stabiliser, which is fixed at -2 degrees. The CG is 10mm back from the one recommended in the CG calculator (ignoring the rear stab). No elevons. I'm managing inside and outside loops, inverted flying, high alpha almost hovering. Just beginning to get confident with it. She glides and lands very well. I can adjust the speed with the elevator without fear of a vicious stall. By addng a little throttle, I can land with a high alpha and quite a steep descent. Long may it last! cheers Nick |
Those are rules of thumb, but they are not based on any particularly "sound" science.
There is nothing "special" or "optimum" about that particular area ratio, or that particular incidence, or that particular moment, independent of the context of the other parameters of the design. They do influence each other, but each has other parameters whose influence is at least as important to them. Only by considering all of those parameters, as well as all of the other design parameters, together within the context of that particular aircraft's mission profile, can you make any sense of it all. The required incidence is more strongly affected by other parameters that you are not including, things like the airfoils of the wing and canard, and their planforms, stall characteristics, the canard moment arm, etc.. As far as area ratio, that is meaningless without also considering the moment arm as part of the equation. As far as optimum, you can get better efficiency by making the canard somewhat smaller than 20%. It's like that old wives' tale about "square" props (i.e.: diameter equals pitch) being more efficient; just because something seems to make sense does not make it actually true. In fact, it could be quite the opposite. Be very careful of rules of thumb, they are one of the primary habitats and hiding places of the "engineering sacred cow". If you take the time to hunt through those habitats (finding the true optimum, vs. what seems like at first glance ought to be the optimum), there could be some very tasty barbeque on your menu. And yes, I speak from considerable first-hand experience on this. |
Don
This is what I posted in Sept 08 Quote:
When I've crashed them, it has been mechanical or electrical faults, pilot error, eyesight. Only by flying with the CG too far back, or turning without spare energy have I had an unmanageable plane. Would you say that I get a wider margin for error by keeping the wing loading as low as possible? ![]() NIck |
Joined Jun 2005
Nickchud
On models with long moment arms for the canard like the Georgia Goose, I used 3.5 more degrees on the canard than on the main wing to assure that the canard wing would stall first. My intuition calls for a gradual reduction in canard incidence as the moment arm decreases. In the case of the new Duck, does the main wing really care if the canard stalls? It is there to influence the angle of attack of the large wing and to give front end steering. Don Stackhouse Quote:
Your comments have been a great help to me along the way. Charles |
I agree with Don that smaller canard area can potentially achieve greater efficiency but it requires a well optimised design to realise that gain. If the design isn't well optimised there could be limitations on other important parameters such as stall speed and elevator authority. I also read above that we should consider the mission profile in the context of the design. On that basis it sometimes won't be an issue if the efficiency is compromised by adopting a conservative design with oversized canard area. Quote:
United States, IL, Chicago
Joined Dec 1996
From Nick
PS Dereck: I drove to Stranrar in 1970 in a 1955 Singer Roadster 4AD with a bunch of student friends to tour N. Ireland. We could have been on the same trip! We spent the night before sailing camped by Loch Lomond. Someone lent us a frame tent, we'd never seen it before and we didn't try and erect it till after midnight. You will guess, correctly, that we slept in the open air.[/QUOTE] We went just before Easter, made the drive in one day. Somehow, we got four of us, one rider's father, four bikes, several pairs of spare wheels and our clothing into my four door Moggy and a Moggy Minor van, ex Post Office. 'We' were the four man Hull Brewery / Hull Coureurs Cycle Racing Team, one of the first sponsored amateur cycling teams in England. The aim was the four day long 'Tour of Northern Ireland' AKA the McArdles Beer Race. Four stages, around 60 - 70 miles each, around Northern Ireland, and a short lap 'criterium' around the seaside town we stayed in one night. Seeing as the competition included the likes of a four man squad from York who went on to represent England in the Olympics, we got wasted! My dubious claim to fame was some lap prizes in the 'crit' and a high finish in it - climbing Irish mountains wasn't my style, but racing around a half dozen corners in a half mile lap for 20-odd laps was more like it. Due to my inevitable lack of car skills at the time, we spent the drive there and back replacing engine oil that probably hadn't been changed for a long while... Halfway back, I figured out how to turn the heater on too. End of non-canard rambling, honest. D |
Non-canard ramblings..... all part of the community.
Mission profile - I accept that gliders are a whole different ball-game. But anyone thinking of an own-design canard, or a build from 3-views should not be put off by too much sophistication. My point is that, with low wing loadings and high power-to-weight ratios, almost anything will fly as long as it balances. (ed: also as long as there's more vertical and horizontal surface behind the CG than in front). Just look back over the pages of this thread. Plenty of planes, like The Dark Angel, have a 6mm flat board airfoil and the Slow Stik is seriously under-cambered. There is any number of possibilities and inventive contributors. Airfoils - My own personal favorite is the symetrical one used by the Delta Duck : 10% thickness, or the S3021, which John recomended for the Starship: 10.5% thickness and very nearly symetrical. For the canard, something classic like the Clark Y but thinner: 8% seems to get good, predictable results. Here I go - getting more complicated, sorry. cheers Nick |
Joined Jun 2005
Dereck, A great story which I thoroughly enjoyed partly because it painted pictures in my mind of a place never visited. I envy the bikers around here for their powerful legs.
John 235 Quote:
Charles |
