Old Nov 10, 2010, 06:01 PM
Mitchell Covell is offline
Find More Posts by Mitchell Covell
Canada, ON, London
Joined Nov 2010
Thank you Johnny. No way of knowing whose experience will save me from one of those really hair pulling mistakes
Mitchell Covell is offline Find More Posts by Mitchell Covell
Old Nov 11, 2010, 01:02 PM
canard addict is offline
Find More Posts by canard addict
Joined Jun 2005
Mitch Covell
I neglected to mention my interest in the this thread in my first post. Got too wrapped up in theory – very bad habit ) I am just starting into RC, and my first design is going to be (hopefully) a very forgiving, slow flying, canard.
I am most of the way through the design phase now, and I will post the drawings when I get them finished.
Mitch, Welcome to the Canard Forum! Your reference to the views of Don,(and others) on page 114 found us in only one of the interesting topics here.
A search of the thread will produce answers to many of your questions. I look forward to seeing your design of a large slow flying canard.
Captain Canardly Johnny
Charles: I'm wondering: is the present design, shortened moment for canard
purely as a" goofin off on the porch" with 'flatspinnings'?
more later! Johnny
Johnny, my Duck was designed to do what I had in mind at the time.
1. Nose high three point landings.
2. Low aspect ratio wings for quick rolls.
3. Elevons front and rear for positive longitudinal control.
4. Extended rudder for better yaw control
5. Symmetrical airfoils for outside maneuvers.
6. Canard wing to finalize delta shape and control front of model.
The ability to spin was an afterthought of completion.
Charles
canard addict is offline Find More Posts by canard addict
Old Nov 11, 2010, 07:15 PM
Captain Canardly is online now
Find More Posts by Captain Canardly
who has rabbit ears down
Captain Canardly's Avatar
United States, MN, Buffalo
Joined Jan 2007
Seems like the job is getting done!
more later, am still absorbing infos'/ datas snow forecast, should be great for CAD Works!
later, Johnny
Captain Canardly is online now Find More Posts by Captain Canardly
Latest blog entry: Have a laugh on me!
Old Nov 11, 2010, 08:54 PM
Joined Jan 2007
poor lil' renolds numbers being bludgeoned
I got a bit distracted during my data search, came up with this sequence of events:
pic1) Stokes Law
Pic 2) Stokes Radius
3)boundary layer http://www.symscape.com/.
4)flow seperation
Not necessarily guaranteed to be the actual sequence of searched data, as I was actually looking for Conical lofting, and came across this fellow!- the daddy of the Spline!
Pic 5) Shoenburg
Johnny
Old Nov 11, 2010, 10:00 PM
Don Stackhouse is offline
Find More Posts by Don Stackhouse
Don Stackhouse's Avatar
United States, OH, Bradford
Joined Jun 2005
Originally Posted by Captain Canardly View Post
...I was actually looking for Conical lofting...
Try:
http://technology.calumet.purdue.edu...97/ilin97.html
The father of this technique was A. Roy Liming, who was in charge of the lofting of the shapes for the P-51 Mustang. He later wrote a book about the method, "Practical Analytic Geometry with Applications to Aircraft".
The method uses conic sections (circles, ellipses, parabolas, hyperbolas) to define the shape of the object. The key thing about this is that conics are second-order curves. In other words, the highest exponent of "X" in their equations is two, i.e.: X^2 (in other words, "X squared"). So, exactly why is that important?
For those of you who had basic Calculus, and were not so traumatized by the experience that you immediately purged all memory of it from your mind, you might recall that the two basic operations in Calculus are differentiation (finding the derivative) and integration (finding the integral).
Finding the integral of a curve's mathematical equation gives you the area under the curve. If you have a funny-shaped wing planform, but you have an equation mathematically describing the shape, then integrating that equation will give you a formula for the area of that shape.
If you find the derivative of the mathematical equation for a curve, that new equation gives you a formula for the slope of that curve at whatever point along that curve you plug in the "X" value for that point.
When you take the derivative of an equation, the resulting formula has an order that's one less than the equation it came from. The derivative of a second-order equation (such as a conic section) is a first-order equation (the equation for a straight line). The derivative of a first-order equation is a zero-order equation, which is a constant. The slope of a straight line (the first-order equation) is constant (a zero-order equation) along its entire length, from minus infinity to plus infinity. If the slope was not constant along its entire length, then the line would not be straight!
Now, why should we care? If we have an equation for the shape of something, and therefore the path that an air molecule takes when flowing along it, or the path your eye sees when studying that shape, and that shape is lumpy, it does not look pleasing to the eye. If it has wiggles, it will not "look" all smooth and pretty to an air molecule, there will be velocity and pressure fluctuations in the flow.
From a kinematics standpoint, the first derivative of the basic shape gives you the velocities along that shape. The second derivative (the derivative of the derivative) gives you the accelerations, and those also tell you what's going on with the pressures along that surface.
If the shape you have is a second-order curve (such as a conic section), then the second derivative is a zero-order equation, which is a constant. Therefore, a conic section is a shape with constant acceleration. That means it is physically incapable of having any wiggles in it. It is mathematically smooth. The only way to get an inflection point or other sort of wiggle is if you join two or more conics together to deliberately create that wiggle. It's like a manual transmission in a car, it will never shift on its own, only if you specifically tell it to.
This means it will be naturally pleasing to the eye, and naturally smooth to the airflow.
The NURBs and splines commonly used by a lot of "modern" CAD programs are higher order curves, at least third order and in some cases higher than that. Those are capable of having wiggles, including ones that are so small you don't consciously see them, but still significant enough to be subconsciously distracting, and enough to cause pressure fluctuations that could trigger flow separations. You can't be sure you have them under control.
A shape constructed from conics will only do exactly what you tell it to. Conics are trustworthy.
Don Stackhouse is offline Find More Posts by Don Stackhouse
Old Nov 11, 2010, 10:45 PM
Joined Jan 2007
Thanks Don!
Thanks for confirming I'm tracking like a young pup after his first bird! I had forgotten, during my search, that I had saved that (page) as PDF, for lunch time reading-
My search for proper conics is 2 fold (pics)
What had driven me nutz earlier this year, was that there is "no" public data of the actual fuse layouts for the mustang, as I have a conversion from 3 views to 3D as a tutorial video planned.
sleepin' time now!
Old Nov 12, 2010, 07:04 AM
Joined Jun 2005
Thanks Don and Johnny for the interesting material. The review of Calculus brought back memories. It is satisfying to see how it works with Conics to produce sections of our flying machines. It would be great to see the perfect canard design.
Charles
Old Nov 12, 2010, 08:46 AM
nickchud is online now
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Wow! Well done Don. You've managed to break 40 years of sublimation. I studied all that stuff once but I never saw it as having a practical application, apart from giving me a way to string out my student days a little longer. What a waste! I wish we could convince youngsters today about the relevance of applied maths. I've always approached it on a need-to-know basis. Maybe the solution is to show kids the problems that can't be solved without it. The problems are interesting, even if the maths are just a set of tools.
Now, here's my newest cunning plan.
As always when I'm having fun, my favorite planes end up with the fuselage smashed to matchwood sooner or later. First I had a Delta Duck, then a ChuddleDuck. Now I've done it again and, as usually happens, the wings stubbornly survive.
Next time I plan to mount the motor on the tail and build a Polaris Seaplane type of body, with a canard. There are quite a few variants on this theme, I know Laddie is one of the forces behind it, also TheKM with his Twinkle, and I've always admired them.
My airfoil is symetrical, so I can turn the wing over to put the servo arms on top, out of harms way. This should give me the rough-terrain plane I need and a seaplane in the bargain.
Here are some of my thoughts:
1.The Polaris has the elevator panel right in the prop-wash, the Polar Duck won't. Should be fixed by the elevon - elevator combination.
2. Battery and motor at opposite extremes - not good for gyroscopic forces, nor for the long power cables. Videos of the Polaris flying show it to be very well behaved.
3. Get the CG right and set the thrust incidence to -2 degrees.
What could go wrong? Suggestions gratefully received.
cheers
Nick
nickchud is online now Find More Posts by nickchud
Old Nov 12, 2010, 12:08 PM
Joined Jun 2005
Originally Posted by Mitchell Covell View Post
This post is directed to Don Stackhouse.
Sorry to be chiming in late here, I needed to settle some other issues and deadlines, and I wanted to think a bit about how to respond.
Mitchell, I'd also like to apologize in advance for being blunt. I don't like playing the role of "wet blanket", but sometimes it's necessary. Frankly I see some serious red flags, and I would rather bring a monsoon down on your parade now (when you can more easily do something about it) than tell you a bunch of pretty lies that give you a warm fuzzy feeling, but set you up for an even bigger disappointment later, when you have a lot more invested, both financially and emotionally. That would be doing a disservice to both of us, as well as the other members of this discussion.
...First I would like to address the idea of the rule of thumb. I think that a rule of thumb is a solution to a specific type of problem that has been found to work in practice. The usefulness of a rule thumb depends on how closely the context of application resembles the type of problem from which the rule was derived. Conversely, the danger of using this type of rule lies in failing to recognize that some significant parameter is no longer within the limits that defined the type of problem that defined the rule in the first place. The outcome in this situation cannot be predicted by the rule: the plane might perform well, or it might not...
I absolutely agree.
...Whilst pondering your post, I started to wonder about what constitutes the irreducible elements of an aircraft that must be capable of level flight and have dynamic pitch stability
From your discussion, I think you're referring to static pitch stability, the property of an airplane that makes it want to return to the trimmed angle of attack and airspeed after the pitch attitude has been disturbed. Dynamic stability is the ability to damp out oscillations. Both types of stability are important, but are primarily controlled by different parameters.
at aerodynamic stall. This is what I came up with:
• There must be at least two lifting surfaces with AC’s that are longitudinally separate. In the case of a flying wing these would be different parts of the one wing. The longitudinal order of the AC’s of these surfaces must not change for any orientation of the aircraft that would be part of it’s design flight envelope.
In other words, if you try to fly backwards, all bets are off !
[quote]• If the AC’s for both lifting surfaces are behind the CG, then the first lifting surface must stall first, and the second lifting surface must produce a small (relatively) negative lift. This describes the “conventional” configuration.[quote]
Not quite. It is very possible, in fact in certain flight conditions commonplace with many conventional aft-tailed aircraft, for the tail to make positive lift, and for the plane to still have positive static pitch stability.
What actually matters is not the lift of the wing and tail (or canard), but rather how much they each change in response to the attitude change, and whether the resulting change in their moments about the C/G wants to correct the disturbance, or make it worse.
The "long way" to look at stability is through "stability derivatives". Recall in my last post on conic sections how the derivative of an equation gives you the formula for the slope of the original equation? If we construct the formula for all the different forces acting on the airplane about the pitch axis, or the yaw axis, or the roll axis, then take the derivative (the "stability derivative" about that control axis), we get the formula for the slope, or changing of the forces about that axis. That slope tells us how these forces change for a given disturbance about that axis. Whether that slope is positive or negative tells us if the plane will be statically unstable or stable about that axis, and the steepness of that slope tells us how strongly the plane responds to a disturbance. A plane with exactly neutral static stability will have a horizontal line for the sum of its forces, and therefore the slope of that line, and the value of its stability derivative about that axis, will be zero.
• If the AC’s for both lifting surfaces are ahead of the CG, then the first lifting surface must produce a small (again relatively) negative lift, and the second lifting surface must stall first. I have never seen an airplane using this configuration, although I imagine it could be made to work – perhaps not well )
To make this work, you would need to have the dCl/d-alpha of the rear surface be greater than that of the forward surface.
Let's look at that parameter "dCl/d-alpha". It's a term from calculus (funny how that keeps popping up!). The slope of something is the ratio of how much one parameter changes for a given change in the other parameter. "dCl" is the difference in Cl, the lift coefficient. "d alpha" is the change in the angle of attack, or "alpha". I stick the dash in there between the "d" and the "alpha" just to separate the two, so folks don't get confused and start asking me what this funny new word "dalpha" means. It is not a negative sign. Ideally, what should be there is the lower case Greek letter alpha.
So, dCl/d-alpha is the slope of the lift coefficient vs. angle of attack curve, the change in Cl for a change in alpha. And, if we have an equation for that Cl vs alpha curve, taking the derivative of it gives us the formula for that slope.
In the case of your C/G behind both AC's design, if, for a given change in alpha, the rear surface changes its lift proportionately more than the forward surface, you can still get a net self-correcting behavior from the plane.
I only know of one series of aircraft that do this, but there might possibly be some others I don't know of from other designers. The ones I'm aware of are a series of flying wings I've been developing for over a decade that have the C/G at 52% of the Mean Aerodynamic Chord (the AC is at 25%), have conventional non-reflexed airfoils, essentially zero twist, positive lift all the way out to the tips, an elliptical lift distribution, and are naturally statically stable in pitch. No, I won't tell you the details of how I did it. However, it's not something you're likely to find in any of the aero textbooks.
• If the AC for one lifting surface is ahead of the CG, and the AC for the other is behind the CG, then both lifting surfaces must produce positive lift, and the first lifting surface must stall first. This describes the “typical” canard.
Not only stall first, but the behavior prior to stall, based on the relative lift force and moment changes I discussed above, must also match.
I doubt that an airplane with the AC of the main lifting surface very close to the CG can be designed to have predictable stall characteristics. This is because small changes in the position of the AC of the main lifting surface, or of the CG, could change the basic configuration, and it would be difficult to make the secondary surface behave predictably because it would have almost no load – and any load it did have might be either positive or negative.
Not true. Most conventional aircraft out there have the C/G close, perhaps very close, to the AC of the wing.
You express concern about "small changes in the position of the AC". The AC, for all practical purposes, does not move. That's the key difference between it and the older concept of "Center of Pressure", which does move quite a bit.
Some apparently conventional designs are actually the third configuration. A good example is the DHC-3 (single Otter): the CG is behind the AC of the main wing and it has a ‘flying’ (lifting) horizontal stabilizer – an amazing load lifter according to my father who is a retired bush pilot. An interesting consequence of this is that the DHC-3 will not climb without flaps – the horizontal stabilizer does not have sufficient authority to maintain climb attitude. The flaps act like the elevators on a canard, and create a pitch up moment that makes climb attitude possible.
Well, there is some confusion here. The reason it won't climb without flaps is a detail design issue involving the available elevator authority, and is not inherently a matter of the AC of the wing. It is also not necessarily related to the use of a "lifting" tail. In fact, the individual AC's of the wing and tail are not what matters. The thing that matters is the position of the C/G relative to the AC of the entire aircraft, which for most aircraft is mainly the result of the combined AC of the wing plus the tail. As long as the aircraft's total AC is behind the C/G, generally speaking it will have positive static stability, regardless of where the AC's of the individual flying surfaces happen to fall. Generally speaking, if the aircraft's total AC is in front of the C/G, the plane will be statically unstable. However, if you can work "outside of the box", exceptions are possible, such as my statically stable flying wings with their AC at 25% of MAC, and their C/G well aft of there at 52%. It can be done, but you have to put the textbooks away and go back to fundamentals, just like you referred to in your first post.
Over two years ago I decided to pursue a long simmering interest in RC aircraft. I ordered a transmitter, motor, servos etc. – and then shortly thereafter I was offered a job teaching science, math and English in China. The RC project has been languishing on the shelf since then. However, now I have the time to resume it, and many of my design decisions will be dictated by such things as the EPS 400c (3x reduction ratio) and the 10x4.5 slow fly propeller that I already have.
Design process:
• This will be my first plane, so it must fly like a trainer – slow and stable.
Mitchell, speaking as a definitely interested, but reasonably objective (I hope) bystander, I have to say that it sounds like you're trying to run before you have learned to walk. That's an almost guaranteed recipe for skinned knees and a bloody nose. The plane you're describing will take some serious development work to sort out all of the details, before it's likely to have the qualities needed to be a good trainer, and the test flying needed to do that effectively will require an experienced pilot to sort out what's going on, and what's needed to fix it. I strongly suggest you get an experienced pilot to help with this, or else become an experienced pilot yourself using a de-bugged and proven design. I also suggest getting a few conventional designs under your belt before diving into a canard design. A canard can have the properties you're looking for, but (contrary to what some of the folks on this thread seem to want to believe) those properties are not inherent in a canard layout, they have to be designed in.
One of the most difficult things to predict, especially at low Re's, is stall behavior, and the qualities you will need will depend a great deal on the relative stall characteristics between the wing and canard. That's not something that's likely to happen by accident or just by analysis (NONE of the commonly available airfoil programs are likely to make reliable predictions of that), and it's likely to involve some serious blood, sweat and tears before you get it just right.
• I am designing for a Vmin of about 5 m/s
11 MPH, which is do-able, but you will need to keep the wing loading moderately low.
and a trim speed of between 8 and 10 m/s. Vmax will be limited by the motor/propeller combination – probably no greater than 12 m/s.
18 MPH, 22 MPH and 27 MPH respectively. A bit fast for optimum trainer qualities, although that should handle a fair amount of wind. However, if it's windy it's also usually turbulent, which makes it bad weather for beginners, regardless of the airplane.
What a beginner needs more than anything else is time to think. That means you need to have something slow. I personally recommend indoor models, such as our Roadkill Series Piper Cub:
http://www.djaerotech.com/dj_product/roadkill_cub.html
or a GWS Slow Stick or Tiger Moth,
or a low wing loading two meter sailplane such as a Gentle Lady or our 2-meter Chrysalis:
http://www.djaerotech.com/dj_product/chrysalis2m.html, particularly the electric version.
• Re > 50,000 for all lifting surfaces, since most airfoils behave unpredictably below this point.
Actually, things start getting squirrely below about 120K, and the reliability of most airfoil analysis programs starts to deteriorate as well.
This means a minimum chord of 15 cm given the low Vmin.
Mathematically correct, although designing for 50K generally requires some decent low-Re experience. 100K is quite a bit easier.
[quote]• Given the limited power, and the minimum cord length, the canard will be close to 50% of the total wing area (probably around 40%), and the A.R. for both the main wing and the canard will be relatively low.[quote]
Depends on what you mean by "relatively".
In general, your statement above seems to jump to quite a few conclusions unnecessarily quickly.
In general, a canard aircraft will have the best overall efficiency if the canard is as small as possible, so the greatest possible percentage of the plane's weight is supported by the wing, not the canard. This can be achieved by using a long moment arm for the canard. This is also the best thing possible for dynamic stability, which is at least as important for handling qualities.
A short span, low aspect ratio wing will be likely to have poor roll damping.
• The large canard makes a tractor configuration a reasonable choice.
A tractor arrangement is good for the propeller efficiency, but it's going to invite trim issues, and it's definitely going to make it more likely for the wing to stall before the canard. I do not see where a large canard automatically argues in favor of a tractor prop. I also do not see where a large canard is necessarily a good idea for this design. Yes, it's nice to try to keep the Re's up enough to be reasonable, but there are a number of other things that are at least as important.
• I am willing to sacrifice efficiency for stability, and have a swept leading edge for the main wing – probably around 15 deg which would provide about the same stability as 5 deg of dihedral.
Only when near the stall angle of attack. The "dihedral effect" of sweep is proportional to lift coefficient, reaching zero when Cl is zero.
Sweep does tend to unload the root and load up the tips, inviting tip stalling. Also, there is a balance between wing dihedral (including the dihedral-like effects of sweep) and fin authority. To much fin/not enough dihedral gives you spiral instability. Too much dihedral/ not enough fin gives dutch roll problems. Given that most canard aircraft tend to have very short moment arms for the vertical tail, and therefore tend to have atrocious vertical fin authority and yaw damping, as a group they tend to be even more sensitive to these problems.
Adding significant amounts of sweep to the wing gives you what amounts to a variable dihedral airplane. It's very possible you could end up with significant spiral instability at higher airspeeds and low Cl, and also have serious amounts of dutch roll at low speeds and high Cl, such as during final approach and the flair for touchdown on landing.
• At these low Re’s I think that having the canard placed significantly below the main wing does not present a problem. The low Re limits the achievable stall angle, and therefore it is unlikely that the airflow from the canard at stall will interfere with the airflow over the main wing in any way that might precipitate separation on the main wing.
The wake of a flying surface is a lot larger than you realize (see attached NASA photo), it's roughly equal in height to the span of the flying surface. Unless you can make the canard enough lower to be below by more than the semispan of the canard plus the semispan of the wing, their flow fields will interact with each other, and probably not in a good way.
If you could get them vertically that far apart, the relative drags of the wing and canard are now going to start influencing pitch trim in ways that are normally small enough to be ignored. The span loading and Reynolds number issues are likely to make these effects destabilizing in pitch.
Having the span of the canard close to that of the main wing (probably slightly less) will ensure that the outermost part of the tip vortex from the canard (which creates a local upflow) will not increase the AoA at the outer part of the main wing. However, this position of the canard and main wing will likely cause the canard tip vortex to reduce the spanwise flow (the leading edge is swept) over the outer part of the main wing. Without a wind tunnel who is to know what the effect of this will be. It might reduce the tip vortex of the main wing.
It's not likely to have much effect on the spanwise flow, but it is likely to reduce the angle of attack on the inboard portions of the wing. This will interfere with the wing's spanwise lift distribution in a way that will probably hurt efficiency, and also increase the likelihood of tip stalls.
• Airfoils. I do not think that there are ‘good’ airfoils for canards.
I disagree. A canard is a flying surface, and follows the same rules for defining the required airfoil properties as any other flying surface. What matters is how well you match those requirements to the airfoils you select or design for that application.
I like the "shoe analogy" for this issue. Yes, it's important to have a shoe that's well designed and well constructed, but what is even more important is how well that shoe fits your personal foot. Michael Jordan's shoes on your feet are not likely to help you be a better basketball player, unless your feet are exactly the same size and shape as his.
I think that there are a nearly infinite number of combinations of configurations, wing planforms, airfoils, Re number environments, design profiles etc. These combinations range from the very good to the very bad. Once the configuration, design profile, Re number etc. have been decided, it is pretty obvious whether a given airfoil (if you have the data for it) will be good or bad. Certainly it doesn't have to be perfect.
I'm not sure it's necessarily a matter of "very good to the very bad". More often it's a case of not having the best fit between the airplane's mission profile vs. the details of its design (see "shoe analogy" above). What works in one situation might not be so successful in another. However, with that caveat, I think we are roughly in agreement on this point.
“The World of Krauss” site has been invaluable to me since it has airfoil data for the range of Re numbers that most models fly in. I just decided which characteristics are most important for my design profile, and then picked a few airfoils having those characteristics.
I was not personally familiar with that site. However, your subsequent statements raised enough red flags with me to prompt me to take a look.
The first red flag is that any source that seems to recommend a 14-16% thick airfoil for an Re = 50K application should immediately be viewed with great suspicion, if not discarded as invalid right at the beginning.
I cannot accurately predict the effect of wing planform, build imperfections etc. so I am not going to worry about trying to find the perfect airfoil. I choose the NACA 4614 for the canard because it has a sharp break to the Cl,
A gentle break would actually give you more gentle stall characteristics. What matters it not that you have a sharp break at stall. What you need is a canard that loses lift, and therefore the ability to pull the nose up, and the wing to a higher angle of attack, faster than any loss of lift in the wing as it approaches stall.
Here's where I really start to get serious heartburn with that source. They use a program that's based on the old Eppler program to do their airfoil predictions. Eppler is good at Re = 500K, not so good at Re = 250K, starts getting pretty shaky at Re = about 150K. It does not iterate on the boundary layer, which becomes very important at low Re's.
It's one thing to generate a performance prediction for Re = 50K. It's another matter entirely to generate a performance prediction that's actually any good at that Re.
Even if the overall performance predictions are accurate (which in this case I find EXTREMELY doubtful), the predictions of stall behavior, both the angle and especially the characteristics, are likely to be utter nonsense. There are no public domain programs that do a good job of predicting stall characteristics at even moderate Re's, and the lower the Re the worse they get.
and the AoA for this break decreases with decreasing Re numbers (stall = 100 @ Re = 50,000).
That's going to be true of almost any airfoil.
For the main wing root I choose the NACA 4414 because it has a very high and gradual break in the Cl graph(stall = 130 @ Re = 75,000. For the tip I choose the NACA 4416 (same family) because the Cl graph doesn’t really break – it just levels off around 130 (Re = 50000). This should make stalling the tip of the main wing almost impossible.
Well, um...NO.
At Re = 50K, a 14-16% thick airfoil will ave less max lift than one about half that thickness. At all angles of attack, large portions of that thick airfoil are likely to have separated flow, which also invite the possibility of aerodynamic hysteresis as those separated areas move around with changes in alpha.
The actual stall characteristics, as I indicated above, are likely to bear little resemblance to those predictions.
About the only thing we can say with much certainty is that those airfoils at Re = 50 -100K will have terrible L/D's. Yes, they will probably have what appears to be gentle stall characteristics, but only because they are already, at all angles of attack, operating in a condition of what amounts to a partial stall. What the exact details of that stall look like, and the angles where those details occur, will be very difficult to nail down with any certainty or precision.
In general, at lower Re's (such as the 50-80K region), you need low thickness (below about 8.5%), modest camber (1-2% or less) and the max thickness point around 23-25% aft of the leading edge.
With these choices I should be able to have 00 decalage, and still have benign stall characteristics....
Decalage is not a primary determiner of stall characteristics. C/G determines the amount of static pitch stability, and one side effect of that is the required canard lift force to keep the plane in trim at a given airspeed. That canard lift force will then have to be generated by the COMBINED effects of decalage and elevator deflection. Whatever your decalage provides will have to be amended by the elevator's effects to get the plane in trim at the desired airspeed. This includes getting the plane to fly at or just above stall speed.
• One vertical stabilizer, and the fuselage narrows down to the rudder for simplicity. Putting the rudder at the end of the fuselage also increases the moment arm.
Depending on how long the fuselage is. Although there can be some yaw and spiral stability benefits to inward-lifting winglets on the tips, in general your best bet is to put the fin(s) wherever you can get the best moment arm.
• Tricycle gear (harder for a beginner to crunch).
Yes and no, properly done a taildragger can have better ground handling than a trike, but that generally requires a plane with good damping in both yaw and pitch. On canards that can be a problem. However, getting good rotation characteristics at the end of takeoff run can be a major problem on canard aircraft. Voyager had some really bad quirks in this regard, and the band-aid fixes they developed to deal with them were what was ultimately responsible for the plane dragging its tips on takeoff for the round-the-world flight.
• Cheap build materials, and a slab sided fuselage for easy build – I am sure that I will crash my first model during the learning process.
Almost always a good strategy.
Let me suggest another. You have a lot of unknowns here, some serious technical risks (even with some appropriate airfoils), and the probability of some significant design iterations required before you end up with something acceptable. I suggest doing some smaller models to sort out the issues and answer some questions, before investing in the bigger one. Start with small (maybe 10"-12", 30 cm) balsa free-flight scale models of your design, fly them in your living room. Thin out the airfoils to about 3-4% thick for these to allow for the effects of Reynolds number. Start with glider versions, don't worry about power till you have the basic C/G, flying surface arrangements, etc. sorted out. You can also cut the control surfaces out, use aluminum foil to reattach them, and then experiment with things like incidences, flight trim and control responsiveness. By the time you actually invest big time and bucks in your model, you will have already identified most of the real problems you face, as well as having a decent handle on the effectiveness of your proposed solutions.
Old Nov 12, 2010, 12:59 PM
Trevorh is offline
Find More Posts by Trevorh
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Don,
I always find your aerodynamic lessons very enlightening - one reason why I continue to lurk on this thread despite not having any Canards planned at present.
You give two different criteria for static pitch stability.
Firstly the dCl/d-alpha argument:
Originally Posted by Don Stackhouse View Post
From your discussion, I think you're referring to static pitch stability, the property of an airplane that makes it want to return to the trimmed angle of attack and airspeed after the pitch attitude has been disturbed....
What actually matters is not the lift of the wing and tail (or canard), but rather how much they each change in response to the attitude change, and whether the resulting change in their moments about the C/G wants to correct the disturbance, or make it worse.. ..
And secondly, the cg ahead of AC argument:
Is there any way that these two criteria can be seen as the same thing? I have always clung onto the second way of looking at it because I can see how to achieve the correct disposition of cg and AC whereas designing for the right dCl/d-alpha is a tougher ask!
I must admit though that I tend to think of the cg ahead of ac giving a negative pitching couple which, in level flight, has to be counteracted by a positive pitching moment from the combined flying surfaces. So, if the model pitches down, I imagine the corrective force resulting not in direct response to change in attitude but rather in response to the subsequent change in airspeed which would increase the upward pitching moment from the flying surfaces.
I know this is dangerously close to the old concept of longitudinal dihedral but it is the best mental model I can manage!
If our models really do generate corrective forces in response to changes in attitude (as opposed to changes in airspeed), I really would like to get my head around it in a qualitative way - much as I have always loved calculus!
Trevor
Trevorh is offline Find More Posts by Trevorh
Old Nov 12, 2010, 01:38 PM
Joined Jun 2005
Originally Posted by Trevorh View Post
...You give two different criteria for static pitch stability.....Is there any way that these two criteria can be seen as the same thing? ...
Pretty much, if you get things arranged so that the one criterion is working, the other one is also usually working.
Probably another significant factor here is that the whole airspeed-related explanation is most likely quicker to tell and easier for the "civilians" to follow, so it gets used more than the angle-of-attack explanation, even thought the angle-of attack explanation is probably more technically complete.
It's a little like the Bernoulli vs. Newton debate about how a wing makes lift, both are focusing on the same problem, but coming at it from different directions. Both are valid, at least within the range of common designs.
If the angle of attack changes, both surfaces see the same change in angle of attack, other than local influences such as downwash from one surface changing its effect on another surface. This causes changes in the lift made by each. If we multiply those changes in the amounts of lift by their individual moment arms to the C/G, the difference between the moments will be in either a nose-up or nose-down direction.
In the case of a conventional tail, the C/G is forward enough that the moment change from the tail has proportionately more effect than that of the wing, resulting in a net correcting moment.
In the case of a canard, the C/G is far enough forward that the change in moment from the wing has proportionately more effect than the change in the lift of the canard. It's a leverage thing.
Wait - did anyone notice that the same phenomenon is occurring for BOTH? In both cases, the leverages work out such that the change in lift at the aft surface dominates, bringing the pitch attitude back towards the original setting. As I've said before, there is fundamentally no difference between a canard, a tandem-wing and a conventional layout. All represent different points along the continuum of "two-surface aircraft".
OK, let's look at it again through another example.
Consider an arrow, maybe one of those hunting arrows with the big wide triangular blades on the head, like a set of delta wings on the front of the arrow. Let's say it was in stable flight, but has just passed the apogee of its flight. Its attitude is horizontal with the ground, its inertia wants to hold it there (or if it was pitching, to continue pitching at the same rate, regardless of whether or not that kept it aligned with the flight path and airflow) but its flight path is now changing to downhill, causing the "relative wind" to hit it from slightly below.
This angle of attack causes an upward lifting force on both the head and the feathers. The angle is different from what existed before by the same amount at both ends of the arrow. At opposite ends of the shaft, the head and the feathers BOTH begin making lift forces in an upward direction.
Is the arrow going to realign istelf with the airflow, or will it pitch up to even greater pitch angles, and eventually tumble out of control ?? !!! Will it continue to its target, or turn completely around in mid flight, go back the other way, and skewer the person who originally fired it ??? !!!! Inquiring minds want to know !!!
The answer is "it depends".
If the head was really big and the feathers too small, that would favor a tumble.
If the head was really light, and some misguided (pun intended) person made the feathers out of steel in hopes they would be more durable in service, the C/G of the arrow might be way too far aft, giving the feathers little leverage and the head way too much, again favoring a tumble.
However, maybe the head on this arrow is metal and the "feathers" are - well - feathers, so the C/G of the arrow is well forwards, giving the feathers more leverage and the head less leverage. Maybe the feathers are large enough that their lift force is greater than the head. Maybe some of the above, or all of the above. Be it due to greater lift force, or greater leverage, or both, the feathers dominate, and the arrow begins to align itself with the now downhill flight path.
As it does so, thanks to gravity it also starts picking up airspeed. The lift forces on the head and the feathers increase, while the inertia of the arrow that resists changes in its rate of pitch change stays constant. We've already established that in this example, not because of any inherent property of all arrows, but rather because this particular arrow was designed and made correctly, the correcting forces of the feathers are dominant. As the airspeed increases, the correcting forces become even more dominant, straightening out any discrepancies in its attitude even quicker, and the arrow continues on its course even more straight and true.
LOOK OUT BAMBI !!!!
mmmmm...venison for dinner tonight!
Seek professional counseling. IMMEDIATELY!!!
Old Nov 12, 2010, 04:11 PM
Trevorh is offline
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Thanks Don, I think the penny's dropped now! Another way of describing the attitude-sensitive corrective effect is to say that, if the aircraft pitches up, the downward couple exerted by the weight acting through the cg and the lift acting through the AC will immediately increase due to the extra lift caused by the change in angle of attack.
I should be able to sleep tonight now.
Trevor
Old Nov 12, 2010, 04:40 PM
Joined Jun 2005
Originally Posted by nickchud View Post
...Next time I plan to mount the motor on the tail and build a Polaris Seaplane type of body, with a canard....
Except that neither of those is actually in the propwash.
...3. Get the CG right and set the thrust incidence to -2 degrees.
The big problem will be at the beginning of the takeoff run. You have no significant propwash on the elevators, nor the elevons. More downthrust might help some, but there is no practical thrust line angle that will make the line pass through the C/G. You will inevitably have a strong nose-down moment from the prop, which will begin just about the instant you open the throttle. The counterbalancing forces from the elevators and/or elevons won't really come into play until the plane is up on the step and getting close to liftoff speed. During the time in between, the plane will display a strong desire to turn itself into a submarine.
On aft-tailed airplanes with this problem, such as the Republic SeaBee or the Lake Amphibian, they place the horizontal tail (and the rudder too) squarely in the middle of the propwash. As long as there is enough authority from that induced flow, it works fine. However, I know of cases where they wanted to install bigger engines in planes like these, and found there simply wasn't enough authority from the elevators to keep the plane from trying to visit the fishes.
In your case it's going to be even more difficult. Keeping the longitudinal moment arms as long as possible would probably help, as well as keeping enough volume in the nose for good buoyancy. However, that will cut into your yaw stability.
Good luck, and remember, if it was easy, someone else would have done it already.
Old Nov 13, 2010, 02:11 AM
nickchud's Avatar
Market Harborough
Joined Apr 2006
Story of my life!
Thanks Don. I've got a plan to increase the size of the nose and add 'chine rails' (is that the right word?). Also a bigger canard to get some ground effect at an early stage. I've noticed with flying boats that you need to be very gentle with the throttle at the beginning of the take-off run. However, though I have flown my canards from water, it's never really been easy yet.
cheers
Nick
Old Nov 13, 2010, 02:16 AM
Canada, ON, London
Joined Nov 2010
Thank you Don. By showing me which of my initial assumptions are not valid you have done me quite a service. I won’t worry about a bit of rain if you don’t – I have been wet before. I am still waiting for materials to arrive (balsa etc), so I have the time to indulge in a protracted design process – and find out which of my assumptions definitely belong in the garbage can.
I have encountered a great deal of conflicting information on the subject of airfoils. If I understand you correctly, the model used for the data on the Krauss website is not able to make extrapolations of test data that are reliable for low Reynolds numbers. I thought I was going to be able to have my cake and eat it too: airfoils with excellent aerodynamic characteristics at low Re #’s that are thick enough to make building light, strong wings fairly easy. Oh well, such is life )
I didn’t write down all of the links in the chain of reasoning that resulted in the decision to use a tractor engine. Since I had already committed to a lower limit for chord length, the front wing would be a fairly large fraction of the total lifting area (for any reasonable span/AR). The motor has to go somewhere, and since the front wing will be producing a substantial amount of the total lift, placing the motor at the front makes one or two things easier without creating any difficulties in getting the centre of lift and the centre of mass in the same place.
I looked up the definition for aerodynamic centre, and discovered that the concept that I was looking for is closer to the centre of pressure. For an airplane in unaccelerated level flight, all aerodynamic forces (thrust, drag, lift) must resolve to one vertical force, equal to the weight of the airplane, and acting through the centre of mass. This is not aerodynamics – it is basic physics. If we resolve all forces to vertical and horizontal components (2 dimensional model), and assume that any torques (referenced to the centre of mass) associated with horizontal forces are small and resolve to 0 (not an unreasonable assumption for a simplification of an airplane in level flight), then all of the torques created by vertical forces (aerodynamic, gravity) must also resolve to 0. If we postulate three vertical forces, and stipulate that no two can operate through the same point, then my reasoning regarding irreducible elements holds for unaccelerated level flight. The torque associated with the force of gravity is 0, and therefore the torques created by the two aerodynamic forces must be equal and opposite. I agree with your point that for static stability, it is more accurate to speak in terms of rates of change. If these torques are modeled as functions of AoA, then the second derivative of f(AoA) | torque must be more negative for the forward most positive lift producing surface if there is to be static stability – thank you for straightening me out on the difference between static and dynamic stability! This of course ignores any other torques that might be a function of AoA, or values of AoA outside the limited range associated with normal flight – but this is a simplification.
Time to go to bed )
