Old Apr 04, 2010, 06:07 AM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
My original drawings for the Lillycat were posted here back on Nov13, #3138.
Evolutionwise, I mean with the benefit of hindsight, I would make those floats 60mm x 60mm in the outside measurements of the cross section in front of the step, and I would make the noses longer to improve the water handling. Just as I was getting up speed for take-off, the nose would dig in and she could whip around. I learnt to leave the rudders alone at speed and use the ailerons to keep her level.
That Starship wing, with tip fins, has such a lot of possibilities. I have a nice 220watt motor in mind as a tractor.
What could go wrong?
cheers chaps!
ick
nickchud is offline Find More Posts by nickchud
Old Apr 04, 2010, 06:21 AM
Cybernaught is offline
Find More Posts by Cybernaught
Onward through the fog.
Cybernaught's Avatar
Bohol Philippines
Joined Aug 2008
Originally Posted by canard addict View Post
Steve and Nick, You two are full of new ideas. Thanks for showing them. Too bad about Whisper 4, Steve. With it's short nose, could there have been too much UP incidence in the canard wing? Just a guess.
I have hit a snag on the Delta Duck with the main wing. Someone said that the leading edge of the main wing was not so aesthetic and it has proven to be a tough build. I will change the top view to a more conventional shape. The symmetrical airfoil is not so friendly on the flat building board but it has been drawn and copied to card stock so it will be used. As with the Evader, a new design must come together well to spark the enthusiasm for a construction drive.
Charles
Your new build looks promising, Charles. Good Luck!
When you get tired of messing with all those airfoil problems, try a KF notched foil but I warn you when you see how well they work you may never go back!
Easter Sunday here and a great day. Got the CatScratcher maidened and about 8 more flights in two sessions. I'll upload video to the KF thread tomorrow when we go to Tagbilaran and I can get to the Internet Cafe and some high speed servers. CS is a pretty amazing bird if I do say so but thats a bit OT for here. Even if she did start out as a Canard.
I got started on a new Canard today too. I'm about 4 lazy hours into it and it seems to be coming together. Here are a couple of pics.
The main wing is 12" x 24 and the canard is 9"x8". Both are KFm2s. Incidence isn't more than a couple of degrees at most.
Well have a look and see what you think. Plan at the moment is elevons with canard elevator mix. I gotta run the numbers through the canard CG calculator to get the gear installation to balance things out.
Happy Spring Solstice to all you Pagans out there.
Just about over the cough. Feeling much better.
Steve.
Cybernaught is offline Find More Posts by Cybernaught
Old Apr 04, 2010, 11:11 AM
canard addict is offline
Find More Posts by canard addict
Joined Jun 2005
Steve, That new design looks fast. Is the red bar to the rear of the canard wing an elevator? I would normally think that your controls are too near the CG but with elevon elevator coupling it will probably be fine. There is a friend in our model club who designs and builds like you and Nick. I hope to take some photos of his work soon to show.
Charles
canard addict is offline Find More Posts by canard addict
Old Apr 04, 2010, 04:22 PM
Bohol Philippines
Joined Aug 2008
Charles
Hi Charles,
Yep! the red part is the elevator and it's 2.25" x 9". I was thinking elevator aileron with just two servos but I don't have much incidence here so not sure it would work. The longer the nose the easier it is to break in a hard landing too. It wasn't too successful on the last Whisper MK4 version. Though that one turned out to be great as a wing. CatScratcher, the accidental airplane... Go figure!!!
The new canard is not an astheticaly pleasing thing to look at but it's my first boomer canard and I'm more interested in getting it in the air for a look-see at performance. If it doesn't worrk out I can remove the booms and I have a Nifty.
Steve.
Old Apr 04, 2010, 09:47 PM
Bohol Philippines
Joined Aug 2008
This should have been attached to the previous post but I had a brain fart....
Steve
Edit: April 5, 2010 10:48am
Here is the maiden and demise of Whisper MK4.
Whisper MK4 FnL.wmv (2 min 0 sec)
Old Apr 05, 2010, 05:57 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Wow Steve! That was quick. Your designs are number one in the fun to faff scale.
Here's a new idea, have a look at this. You could say it's a canard, though I think the control is just elevons and the forward wing is static. Good though, isn't it!
I'll be trailing along behind soon, with the plans of my next Lillycat version.
cheers
Nick
Old Apr 07, 2010, 12:57 AM
Bohol Philippines
Joined Aug 2008
Originally Posted by nickchud View Post
...I'll be trailing along behind soon, with the plans of my next Lillycat version. ...
Nick,
Problems with the new canard. It will need a set of booms probably 12" longer than planned to balance it. So I'll make it into a Nifty and wait for your latest Lillycat to be completed before I start another. I think it will be a good idea for my first boomer canard to follow your lead. I may try a forward swept wing but not sure at the moment. Need to think about this...
Here's a pic:
http://www.rcgroups.com/forums/attac...mentid=3168407
You do the hard part and finish your design then I'll copy it and reap the benefits of your work.
I'm a bit disappointed but I"ll just have to be patient. It will balance about 1" behind the LE of the main wing and that's around 5" too far back.
Steve.
PS. I have a crazy urge t build a Lazy Bee for an AP plane too. Don't know what's coming over me...
Old Apr 07, 2010, 11:30 AM
Joined Jun 2005
Nick, Thanks for showing the flying canard boat. There were lots of great videos attached to your submission. Is the boat available as a kit or plans?
I like the Lillycat model and look forward to seeing more of it.
Charles
Old Apr 08, 2010, 01:48 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Thanks Charles
That IdroJeep is designed by the same guy who did the Stuntcat, which I have been knocking around with for a few weeks now. He released really good plans and instructions for that so I hope he will do the same soon for the flying boat. Meanwhile the plans for my new Lillycat will be ready this week some time and I'll post them on here.
cheers
Nick
PS
With special thanks to Perdu and Edmonds, I think I'll shelve the idea of a plane that can reverse direction in midflight for the time being. Any radical in-flight adjustment to the CoG seems to be a lot of faff for a little fun.
Old Apr 08, 2010, 09:06 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Lillycat plans
Here's where I'm up to so far...
All suggestions and questions will be gratefully received.
More to come...
cheers
Nick
Old Apr 09, 2010, 05:03 AM
Bohol Philippines
Joined Aug 2008
More to come...
cheers
Nick
Nick,
You are into some heavy design there... It's looking good. I'll be keeping an eye on it. Nice, and a very complete approach to your build. I wish I could do that.
Steve.
Old Apr 09, 2010, 10:00 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Hi Steve
I've got a really good design program that's used in schools in England. At first I was given a students' freebie version by a teacher friend of mine, but I've upgraded it now. It's called 2D Design from Techsoft Design tools. I like the 2D part of that name, I'm not at all sure that I will get my head round 3D. There are probably several other products before you have to get into expensive full-on CAD-CAM. Google Sketchup looks interesting too.
You can do it!
Nick
Old Apr 09, 2010, 03:20 PM
eipper is offline
Find More Posts by eipper
Eipper
Joined Jan 2005
Thread: Discussion Canard Forum: Show,Discuss, Learn Edit Post
eipper is offline Find More Posts by eipper
Old Apr 09, 2010, 04:48 PM
Bohol Philippines
Joined Aug 2008
Hi Steve
You can do it!
Nick
Nick,
I played around with various CAD programs and can do them but it takes too much time and effort for me. Yes. I can do it but I can also build a plane that will fly without using any plans at all and it's a lot less hassle. Besides I never follow the plans when I do have them. I always wander off into the either and get lost in some crazy last minute idea. I have Sketchup, by the way. I seem to be able to put an idea down best in Windows Paint. See Pic for the next potential build.
eipper
Amazing looking bird. Nice work.
Steve.
Old Apr 09, 2010, 05:08 PM
Joined Jun 2005
eipper Alfredo
LEZ Voyager dressed and flying
First I want to say THANKS to all you guys for the great info in this thread. The LEZ Voyager recovery is complete and the plane is flying VERY NICE
A great presentation and success story, Alfredo. Your accomplishment reflects many hours of study and hard work to produce one of the prettiest Long EZ's shown here. It seems that you have full grasp of the mechanics and power system of the model. Your success is a great reward to to all here who have contributed their thoughts. I look forward to seeing more of your work.
Charles
