Old Feb 09, 2007, 10:22 AM
canard addict is offline
Find More Posts by canard addict
Joined Jun 2005
Way to go Mustang!! Please keep us informed. Charles
canard addict is offline Find More Posts by canard addict
Old Feb 09, 2007, 11:02 AM
Airboatflyingshp is offline
Find More Posts by Airboatflyingshp
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Mustang that makes for a good configuration but I'm a not sure from the pictures if you've just reversed the wing??................and therefore the aerofoil..which could be challenging?
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Old Feb 09, 2007, 11:22 AM
fuelsguy is online now
Find More Posts by fuelsguy
fuelsguy's Avatar
Seattle
Joined Dec 2001
Hi Guys,
I just found this thread, lots of good info and discussion, thanks for starting and adding to it.
I was told the "canard" term came from the Wright flyer demo in Paris. An Englishman saw the airplane coming in to land and it was going to fly just over the top of a nearby man. The Englishman shouted"Duck!" several times, realized the person was French and switched to French and shouted "Canard, canard!" The aviation experts assumed he was calling the airplane a canard and the name stuck forever.
Ivor
fuelsguy is online now Find More Posts by fuelsguy
Old Feb 09, 2007, 11:40 AM
Joined Jun 2005
Duck, or Canard
Excellent,fuelsguy! And then came Goose and other birds. Charles
Old Feb 09, 2007, 12:10 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
guys,the wing is just reversed changing the airfoil,but i can sand it differently if i need to since i just taped the wings and put in a fiberglass center spar.Fuselage is now also blended with the nose
MustangAce17 is offline Find More Posts by MustangAce17
Old Feb 09, 2007, 12:23 PM
B'ham UK
Joined Oct 2005
Just checking instead of cups try small drinks bottles for your cowls..raid the bins like a true SPAD builder would!
Old Feb 09, 2007, 12:25 PM
EDF Addicted
Joined Sep 2005
LOL i'll see what i can find
Old Feb 09, 2007, 01:20 PM
Tom Smith is offline
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Kyle, in order to get that backwards airfoil to "possibly" work you will have to sand the wing paper thin. It will never work the way it is. Looks cool though. Turn it around and make the motors tractors instead of pushers and it will probably be fine. Sorry to be so negative, but the laws of Physics don't change. Tom
Tom Smith is offline Find More Posts by Tom Smith
Old Feb 09, 2007, 01:27 PM
EDF Addicted
Joined Sep 2005
Tom,I wonder about that though because I have seen many forward swept birds fly and they are very stable although i think the airfoil is correct on them. Also I'm adding leading Edge slats but still have the option to turn the wing forwards
Old Feb 09, 2007, 01:43 PM
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
They may be swept foreward on those other models, but the airfoil id facing the right direction. The high point of most airfoils has to be at 25 to 30% of the chord. Yours, the way it is now, has the high point at 70 to 75% of the chord. It will never work. If it does, I'll eat my socks. Tom
Old Feb 09, 2007, 01:55 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
yeh, but they don't say it won't work..there is more than one recorded case of a RET plane having the wing banded on backwards, and flying perfectly well. In fact the pilots never noticed the difference. IIRC one said 'oh should it go on that way: I have always flown it the other way'
Old Feb 09, 2007, 02:07 PM
B'ham UK
Joined Oct 2005
Futher idea cut the outboard wing sections off outbord of the motors and swap them over............but doing that you get a stagger swept as on Irrigon............the other thing would be to recut the angle of theouter panels so the roots to give the present sweep........when you've re-joined it you will have to blend the join but its an idea but the forward sweep does look very cool.
Old Feb 09, 2007, 02:12 PM
EDF Addicted
Joined Sep 2005
After several test glides trying the wing forwards(gonna have to talk to Charles about the forward swept) it glides well with the canard slightly positive and flaps(since wing is on right) at neutral. The nose wheel held up to the abuse and once attached it will be stronger. going to get another 6x4 3 blader today and talk to my friend about the original design. I want to see this bird fly
Old Feb 09, 2007, 02:16 PM
Joined Jun 2005
Mustang, It looks like the wing will reverse. If so, you will have a better balanced model, I believe. The Miles designs are similar. Charles
Old Feb 09, 2007, 02:20 PM
EDF Addicted
Joined Sep 2005
ok thanks Charles,forward it is
