Old Oct 06, 2012, 03:37 PM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
appreciation
Bill, thanks for posting current copies. And thanks again for offering us the drawings.
PeterH is offline Find More Posts by PeterH
Old Oct 09, 2012, 06:56 PM
wingloada is offline
Find More Posts by wingloada
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
I have made laser cut sheets for the Yardbird wooden fuselage design. They're in the dwg folder:
http://wkleinsasser.net/download/Yar...e_fuselage.zip
Bill
wingloada is offline Find More Posts by wingloada
Old Oct 09, 2012, 08:56 PM
gdjsky01 is offline
Find More Posts by gdjsky01
Jeff
USA, CA, Redondo Beach
Joined Aug 2003
Where would you source the CF boom from? Did you design it to use the high aspect boom from Art hobby? Or something else.
gdjsky01 is offline Find More Posts by gdjsky01
Old Oct 09, 2012, 09:24 PM
wingloada's Avatar
Joined Apr 2012
It's not designed for any particular boom. The taper and diameter would need to be used to customize the formers F5 and F6 to match those dimensions and choose a boom that is the right length to give the approximate tail moment shown on the non-pod fuselage. If someone has the Art Hobby boom dimensions, I can take those and apply them but my drawing as of now is a bit abstract in terms of the boom.
I hope this helps.
WK
Old Oct 10, 2012, 08:26 AM
wingloada's Avatar
Joined Apr 2012
A tapering CF boom with a length of 32-34" should work. The diameter of the boom mount holes at F5 and F6 will need to be drilled to match it.
I contacted Art Hobby and they do not publish the specs for their booms since they are made to specifically fit their fuselage pods.
Mountain Models sells booms for both of Mark Drela's short kits (Bubble Dancer and Allegro). Here are the specs from their site:
Allegro: $33
Length: 32 in.
Diameter: 0.67 in. (2/3") tapered to 0.36 in.
16 grams
pre-preg carbon and bias glass
Bubble Dancer: $46
Length: 36 in.
Outside Diameter: 0.814 in. (13/16") tapered to 0.464 in
38 grams
Given the inset of the boom in the pod of a few inches, the Allegro might come up a bit short but possibly workable. The Bubble Dancer boom, a bit long, but also workable.
Old Oct 10, 2012, 04:18 PM
wingloada's Avatar
Joined Apr 2012
I have posted a revision of the pod so that the Bubble Dancer boom from Mountain Models will fit the dimensions and boom holes in the formers.
Here are the most recent files:
Pod for Bubble Dancer boom pdf:
http://wkleinsasser.net/download/Yar...selage_pod.pdf
Pod for Bubble Dancer boom dwg:
http://wkleinsasser.net/download/Yar...selage_pod.zip
Old Oct 10, 2012, 05:52 PM
dion9146 is offline
Find More Posts by dion9146
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
Mine is a Bubble Dancer boom made by Troy L.
dion9146 is offline Find More Posts by dion9146
Old Oct 10, 2012, 06:16 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Wingloada,
Quick question about your wood fuselage. Currently as built is the rudder going to be carrying the weight to the plane while it is resting on the ground? If I draw a straight line from the low point on the forward section of the fuse it seems to intersect on the rudder not the aft part of the fuselage. If my interpretation is correct then the rudder will take a bit of abuse on landings and simply resting on the ground inbetween flights. Am I seeing this incorrectly?
Nice looking fuselage by the way.
Wayne
Windependence is offline Find More Posts by Windependence
Old Oct 10, 2012, 07:35 PM
wingloada's Avatar
Joined Apr 2012
Hi Windependence,
I increased the size of the hardwood tail skid to ensure that the rudder is clear. It's in the dwg and pdf that I updated just now. Thanks!
Bill
Old Oct 10, 2012, 10:08 PM
wingloada's Avatar
Joined Apr 2012
Does this look like a good idea?
[Based on positive feedback I have developed the design a bit more--too beefy?]
Here is the dwg:
http://wkleinsasser.net/download/Yar...ng_adapter.zip
pdf is attached.
Last edited by wingloada; Dec 10, 2012 at 05:39 PM. Reason: updated uploaded image
Old Oct 10, 2012, 10:52 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Yep...
schrederman is offline Find More Posts by schrederman
Old Oct 11, 2012, 08:15 AM
dion9146 is offline
dion9146's Avatar
Joined Feb 2006
I have an old 2-meter that someone gave me that they did the same thing to. Seemed to work fine.
Old Oct 30, 2012, 07:01 PM
wingloada's Avatar
Joined Apr 2012
Build
I have begun a build of the Yardbird fuselage with a wing adapter to use with Houston Hawk wings. It's in the Hawk build thread:
http://www.rcgroups.com/forums/showt...691892&page=20
W
Old Oct 30, 2012, 09:00 PM
PeterH is offline
Granby, CT, USA
Joined Jan 2001
HH wing adapter drawings
Be nice if the drawing was a pdf file so's those of us who don't have the cad software can see it too...
Thanks.
Old Oct 30, 2012, 09:11 PM
wingloada's Avatar
Joined Apr 2012
PeterH,
I have posted pdfs and dwgs here so all can open them:
http://www.rcgroups.com/forums/showthread.php?t=1750415
W
