Old Oct 04, 2012, 06:39 PM
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
Originally Posted by wingloada View Post
Wow. I'll take that as a compliment. I had not seen nor heard of the Genie when I drew these up last week (I have been away from the hobby for 20 years). It is based on my experience with the Sagitta and dozens of other planes I built years ago. I guess there are only so many ways to make a wooden fuselage! I hope I have not given the impression of taking someone's design. That did not happen and if it seems to be a problem I'd be happy to take down the drawing. Should I do that?
Bill
I wouldn't.
dion9146 is offline Find More Posts by dion9146
Old Oct 04, 2012, 06:55 PM
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
Fickle flier: The short kit and plans do not include a fuselage. It's designed to work with existing pod/boom composite fuselages out there. Same with the Houston Hawk but fuselages for the HH are not so easy to source. That's why I drew one up and this Yardbird fuse is a variation of that. I made another version today for the HH. It could easily be modified for the Yardbird too. I like to build with wood, that's why I have even started down this path.
pdf of straighter Yardbird fuse:
http://wkleinsasser.net/download/Yar...e_fuselage.pdf
Bill
wingloada is offline Find More Posts by wingloada
Old Oct 05, 2012, 12:08 PM
wingloada's Avatar
Joined Apr 2012
Here is a wooden pod fuselage adapted from the other one I posted.
http://wkleinsasser.net/download/Yar...selage_pod.pdf
Old Oct 05, 2012, 06:07 PM
dion9146's Avatar
Joined Feb 2006
I like your designs. This one looks similar to my e-pod. I'd post a pic of that too, but I just drew it out right on the building board and put it together over top of the plan.
Old Oct 05, 2012, 07:58 PM
Granby, CT, USA
Joined Jan 2001
yardbird fuselage for houston hawk?
Without my digging out my plans from their safe resting place, I'd love to know what dimensions of the Yardbird wooden fuselage whose plan was just posted here would need to be changed in order to use it with the Houston Hawk plans/lasercuts.
I think I'm asking what the differences are between the Yardbird and Houston Hawk designs that pertain to mating them to a fuselage.
Thanks, folks.
PeterH is offline Find More Posts by PeterH
Old Oct 05, 2012, 09:32 PM
dion9146's Avatar
Joined Feb 2006
The Hawk has plug in wings at the fuselage like a Sagitta, the Yardbird is a top mount like an Allegro or Bubble Dancer (just to name some of my other planes).
Obviously that makes the fuselages much different.
Dion
Old Oct 05, 2012, 10:24 PM
solo6796's Avatar
United States, TX, Richmond
Joined Aug 2003
You guys believe this thread started in 2006?
I wonder how many Yardbirds and Hawks have been built since then...
AJ
solo6796 is offline Find More Posts by solo6796
Old Oct 05, 2012, 11:32 PM
Granby, CT, USA
Joined Jan 2001
fuselage
Dion, the shoulder wing mount for the Yardbird vs. the plug-in wings of the Houston Hawk sure does make a difference. Oh, well, a good idea while it lasted. All us HH builders are patiently hoping that Jack gets enough breathing room to design a wooden HH fuselage. I have a lovely brand new fiberglass fuselage for the HH, but I was hoping to be able to build its structure entirely of wood. At any rate, you did a beautiful job with the Yardbird fuselage. Thank you.
Old Oct 06, 2012, 12:21 AM
wingloada's Avatar
Joined Apr 2012
I also drew up the fuselage and pod versions for the Houston Hawk. Here they are:
pdf:
http://wkleinsasser.net/download/Str...ge_HH_tail.pdf
dwg:
http://wkleinsasser.net/download/Str...th_HH_tail.zip
POD
pdf:
http://wkleinsasser.net/download/Str...selage_Pod.pdf
dwg:
http://wkleinsasser.net/download/Str...selage_Pod.zip
Let me know if you see anything that needs changing. Before putting these up, I contacted Jack Womack and he has given me permission to post these.
Bill
Old Oct 06, 2012, 06:49 AM
dion9146's Avatar
Joined Feb 2006
I think the nose needs more droop.
Old Oct 06, 2012, 08:33 AM
rnshagam's Avatar
Albuquerque, NM
Joined Nov 2003
AJ
I built my YardBird about 2 years ago w/ two Art Hobby fuses--TD and electric. Still flying. Use the electric mostly. Flies great. Just remember to use spruce, not 'hard balsa' for outer panel spars, or you'll build the wing twice, like I did.
Hey, MW, where are you these days?--ASA misses you!!!
rnshagam is offline Find More Posts by rnshagam
Old Oct 06, 2012, 10:00 AM
wingloada's Avatar
Joined Apr 2012
Dion9146,
Ha!
I can still send you that plan if you really need it!
B
Old Oct 06, 2012, 12:02 PM
Granby, CT, USA
Joined Jan 2001
HH fuselage
Bill, that's a lovely fuselage. Thanks very much for drawing it up.
Old Oct 06, 2012, 12:14 PM
wingloada's Avatar
Joined Apr 2012
Thanks, PeterH
Here are the most recent files:
Fuselage pdf
Fuselage dwg:
http://wkleinsasser.net/download/Yar...e_fuselage.zip
Pod pdf:
dwg:
http://wkleinsasser.net/download/Yar...selage_pod.zip
These are designs that I have not yet built and tested but please feel free to use them as you wish keeping that in mind.
Bill
Old Oct 06, 2012, 02:30 PM
dion9146's Avatar
Joined Feb 2006
Dion9146,
Ha!
B
That's OK, I still have a Genie fuselage.
