Old Mar 18, 2011, 09:40 PM
Barnikal is online now
Find More Posts by Barnikal
Barnikal's Avatar
USA, CA, San Jose
Joined Nov 2007
Thanks for the link. I guess I didn't use my head
Barnikal is online now Find More Posts by Barnikal
Old May 23, 2011, 10:44 AM
CraigaSOARus54 is offline
Find More Posts by CraigaSOARus54
Joined Jun 2009
Yardbird wing question
Id like to start building the wing to either the Yardbird or the Houston Hawk as I like them both, can anyone provide any feedback on the design change between the two? is one stronger, fly better etc. I will be building a wood fuse for my project, Has anyone done similar? Thanks in advance.
CraigaSOARus54 is offline Find More Posts by CraigaSOARus54
Old May 24, 2011, 01:08 AM
rnshagam is offline
Find More Posts by rnshagam
rnshagam's Avatar
Albuquerque, NM
Joined Nov 2003
My advice in building the YB is that you should use spruce for the mid-panel spars. Jack Womack says get the hardest balsa you can for the spars, but believe me, just do spruce--otherwise you'll be building the wing twice like I did. Otherwise, it's a great flying bird.
rnshagam is offline Find More Posts by rnshagam
Old May 24, 2011, 10:22 AM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Yep... just use spruce...
Wow... lots of interest in my woodies these days... and my shop is not even started...
schrederman is offline Find More Posts by schrederman
Old Sep 08, 2011, 09:48 PM
Barnikal's Avatar
USA, CA, San Jose
Joined Nov 2007
New Yardbird II
Yardbird II built on a Art Hobby High Aspect Fuse and using Bubble Dancer tail feathers. So I guess it could be called a High Aspect Yardbubble.
All up weight 49.2 oz First flight 26 min. I now fly the Yardbird as well as a Houston Hawk
Old Sep 09, 2011, 12:46 AM
rnshagam is offline
rnshagam's Avatar
Albuquerque, NM
Joined Nov 2003
E-Yardbird
As long as someone else has a YB to show off, I might as well brag about my latest mod to my Yardbird that I completed a few months ago: Got another Art Hobby High Aspect E-fuse and stuck a HobbyKing NTM3548-1100 motor in the nose, a HK Plush 60 amp controller, Zippy 2200 mah 3S 20C battery, and a 9/5(?) prop to draw about 35 A. All up weight is about 60 oz. The plane launches pretty good, making it to 200 m in 25 seconds--good enough for our ABQ Rules F5J unlimited class.
My only problem is that on two flights I forgot sometimes to pull the antenna out of my TX, as I've been switching most of my planes over to 2.4--but not this one (yet!!!). Made for some exciting flights--luckily no damage.
Old Oct 03, 2012, 06:27 PM
wingloada is offline
Find More Posts by wingloada
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
Possible wooden fuselage
Please excuse the cross post but If anyone is interested, I was experimenting over the weekend with a prototype wooden fuselage to work with the Yardbird. I am not an engineer, just a fairly long in the tooth modeler so it's a 'use at own risk design.' I have not built this, only drawn it up and hope to get some comments from the community.
It's based on an unofficial fuselage design I am working on for Jack's Houston Hawk and also is related to the Sagitta approach (lite ply, nose hatch block, etc.) I free-handed the fin/rudder lines by eye, so it's not quite right, but the idea is there. It has a 9" root chord but even that is flexible--the wing bolt formers need to be located per the wing drillings so that is still in the works in this plan.
** It came to my attention after drawing up the fuselage and posting for suggestions here that it looked quite a lot like the Genie. I hadn't known of that plane before that comment by dion9146 and another by lincoln on a different thread but I see it is true. As such, I have taken down that version and replaced it with one that is not so Genie-like. It can be found in a later post in this thread (#527).
Bill
wingloada is offline Find More Posts by wingloada
Old Oct 03, 2012, 07:12 PM
wingloada's Avatar
Joined Apr 2012
Te?
Hi Jack,
I just received a set of plans for the Yardbird. Beautiful plane!
Do you still recommend the TE approach that is drawn (a sheet on top and a sheet on the bottom with the rib extending to the edge of the TE within) or do you use another, more solid approach now, as I have seen in some posts here? If the latter, does the Mountain Models Yardbird short kit cut the ribs that way?
Thanks for your design and thanks for your help.
Bill
Old Oct 03, 2012, 08:13 PM
dion9146 is offline
Find More Posts by dion9146
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
All comments/suggestions for improvement are welcome.
http://wkleinsasser.net/download/Yar...e_fuselage.pdf
Bill
Looks like a Genie.
Here is my wood/CF/wood fuselage Yardbird.
dion9146 is offline Find More Posts by dion9146
Old Oct 03, 2012, 10:06 PM
wingloada's Avatar
Joined Apr 2012
"Looks like a Genie."
Yes, I was given a link to the Genie a few days ago. I hadn't seen it before but the drop nose is shared.
Bill
Old Oct 04, 2012, 10:07 AM
dion9146 is offline
dion9146's Avatar
Joined Feb 2006
Don't get me wrong, I love the drop nose look of the Genie fuselage. That's why I built one. But even your construction plans look like you and Harley sat down next to each other and started designing.
http://augiemckibben.tripod.com/site...010_traced.pdf
I think it will look good under a set of Yardbird wings!
Old Oct 04, 2012, 02:25 PM
wingloada's Avatar
Joined Apr 2012
Wow. I'll take that as a compliment. I had not seen nor heard of the Genie when I drew these up last week (I have been away from the hobby for 20 years). It is based on my experience with the Sagitta and dozens of other planes I built years ago. I guess there are only so many ways to make a wooden fuselage! I hope I have not given the impression of taking someone's design. That did not happen and if it seems to be a problem I'd be happy to take down the drawing. Should I do that?
Bill
Old Oct 04, 2012, 03:41 PM
Joined Nov 2002
Hi Jack,
Bill
Yes, built per plans is the best... and lightest...
Old Oct 04, 2012, 06:34 PM
Fickle flier is offline
Find More Posts by Fickle flier
United States, NV, Reno
Joined Jun 2012
Yardbird Kit
Is there one in the works? Where would one get the plans if not?
Thanks, sorry to pester.
Fickle flier is offline Find More Posts by Fickle flier
Old Oct 04, 2012, 06:38 PM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
Mountain Models has a short kit with plans.
Wazmo is online now Find More Posts by Wazmo
