thank you, all, for your input... now i think i got it all sorted! i was able to remove the wood around the control horn in the rudder to extract it, once it was out, cleaned i up, put a new balsa mounting block in there, and reinstall the control horn MUCH closer to the hinge line, vs where it was at. now i can get 2 1/4" movement in each direction, which i feel much more comfortable with, vs the about and inch in each direction i was only getting with the original install.
i also finished up the spoilers, and boy did it take some work... shaving some balsa here and there, fitting this and that, and wallah, done deal. now it's all ready to go, but one more question on the CG, jack. you said start with 4 5/8" back from LE and you even fly it at 4 7/8"... and man that seems to be far back with a root chord of 9"... and if i run the numbers in a CG calc, (see attached photo) it tells me much further forward... any thoughts? could it be the differences in our fuses or tails? but that sure seems like a big difference. Matt
Matt,
Did you take the sweep into account when you figured the CG? Where did you end up putting it? I'm glad you are enjoying it. Nicely done... you came in 1 oz. lighter than mine. JW |
Latest blog entry: The BEST!
Far out, Man!!! (Oh heck, I probably just dated myself.) There's not much in the modeling world as satisfying as having someone else enjoy your designs... now if I can just find someone to plot my Journey plans for me...
Jack |
The tail looks like the Alcyone construction.
T |
Latest blog entry: Stork 4 Pro X-tail from...
