Old Feb 16, 2007, 11:38 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Rudder hinge time...
This can be a bit intimidating for a first-timer... I first determine where the hinges should go. I am using 1/8 Robart hinge points. They will be recessed all the way back to the center if the leading-edge radius. That means the bottom one will actually be deeper than the top, because the radius is larger. These have to be square and true so I use my tube-taped-to-the-triangle method for keeping it all square. Once the rudder's drilled and relieved, I make a couple of centering punches out of 1/8 dowell, and put them in the rudder. I place the rudder exactly where it has to go, and push them in to mark the fin post. Like this...
schrederman is offline Find More Posts by schrederman
Old Feb 16, 2007, 11:41 PM
Joined Nov 2002
Looks like this...
Here's the fin post marked and ready for drilling.
Old Feb 16, 2007, 11:46 PM
Joined Nov 2002
Work with it until...
... you have 30 degrees of movement without binding or pushing the rudder out... It is doable.... ... Here's the proof...
Old Feb 18, 2007, 01:09 AM
Joined Nov 2002
Progress against plan....
Looks like my boss is rating me, from the title...
Anyhow, she's finish sanded and the spoilers are fit... and...
Old Feb 18, 2007, 01:12 AM
Joined Nov 2002
And another
Breaks down into a nice little package for an RES ship...
Old Feb 18, 2007, 01:18 AM
Joined Nov 2002
Not bad...
... for a woodie... I'll maiden her this Monday, weather permitting.
Jack
Old Feb 18, 2007, 02:11 PM
Phoebusflyer is offline
Find More Posts by Phoebusflyer
Full Scale Better! UOHHHH!
Phoebusflyer's Avatar
United States, TX, Lytle
Joined Dec 2006
Good looking ship, Jack! I was wondering if you ever heard anything more from Mark Miller on the Hawk kits?
Allen
Phoebusflyer is offline Find More Posts by Phoebusflyer
Old Feb 18, 2007, 04:07 PM
solo6796 is offline
Find More Posts by solo6796
solo6796's Avatar
United States, TX, Richmond
Joined Aug 2003
Needs a V tail...
HA!
AJ
solo6796 is offline Find More Posts by solo6796
Old Feb 18, 2007, 09:05 PM
soarrich is offline
Find More Posts by soarrich
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
That's the nicest wooden fuse I've seen in a long while, maybe ever! Really cool. :^)
soarrich is offline Find More Posts by soarrich
Old Feb 18, 2007, 09:18 PM
Joined Nov 2002
Almost ready...
I added the trim and cut in the spoilers and they're hinged. I need to get the radio installed and balance her and she's ready. I was going to do a lot more trim but decided against it. I need some 1/8 chrome striping tape. Maybe in my travels next week I can pick some up. Hoping to maiden tomorrow... if the wind'll die down, I will! I may yet change the canopy color. I tried twice to make it chrome but the Monokote wouldn't shrink that much. I found the Monokote to be fine for the wings and stabs, but the fuselage and rudder are Ultracoat. It was not any easier than Monokote, but did handle the curve of the canopy easier due mostly to the color...
Old Feb 18, 2007, 09:27 PM
Joined Nov 2002
Tail view
I wanted to add this view of the tail because it shows how nicely you can make a wood rudder/fin combination fit, with a little work. It's very thick, being the NACA010. The stabs start with that airfoil and taper to NACA008. In spite of it's size, it's all pretty light. When balanced and ready I'll publish her weight... even though it's not really nice to talk about a girl in that way...
By the way... thanks for the kind words, guys...
Old Feb 18, 2007, 09:40 PM
Joined Nov 2002
V-Tails???
AJ,
Are we going to have to have another flyoff... like we did with Hawks #1 and #2? Needs a V-tail... what a comment... ...
Allen, the Hawk kits are coming, but Mark's about to move to St. Louis. The release will probably follow his move.
Another kit note, Brian at Mountain Models / Laser Arts says he wants to do a full kit of the Yardbird. I'll be busy redrawing and detailing it for the next month or so.
Old Feb 18, 2007, 09:48 PM
Joined Nov 2002
One quick word about this airfoil... The S3014 shows a slight reflex close to the trailing edge. Try to stay true to that. I put on a sock and ironed the Monokote down to the ribs beginning at the aft edge of the sheeting. It should fly quite nicely, and with a bit of ballast, penetrate nicely too.
Old Feb 18, 2007, 11:49 PM
cynjon is offline
Find More Posts by cynjon
Retired USAF
cynjon's Avatar
USA, SD, Piedmont
Joined Jul 2005
Good news on both fronts! Even though I've been wanting a HH for awhile now, and will most likely get one when Mark gets the kit together (with FG fuse hopefully), the Yardbird really appeals to me as a builder. I LOVE the look of the YB fuselage and since it's a woody kit, should be relatively easy to produce in kit form, compared to a FG fuse. Thanks for the awesome build thread Jack!
cynjon is offline Find More Posts by cynjon
Old Feb 18, 2007, 11:53 PM
jmfitzgerald is offline
Find More Posts by jmfitzgerald
jmfitzgerald's Avatar
St. Louis, MO
Joined Mar 2005
Full Kit!!!
i was standing by waiting to hear this news about a full kit!!! that is great news!!! i'll sure be getting one, i can't wait!
Matt
jmfitzgerald is offline Find More Posts by jmfitzgerald
