Problem Solved- ZDZ80
After talking to some others and searching the forums, I saw that the Zenoah GT80 may be a better choice. The tradeoff there is Fuji BT86Ei for $700 vs Zenoah's great reputation and widely available parts- but Magneto based ignition. Besides, I couldn't find a good drawing of the GT80 anywhere to see if it would fit in the cowl.
Long story short, the Bob Dively Stearman didn't seem to have enough cowl ventilation (~1/4" around cowl perimeter only ~7 sqin and not flow efficient) so I went for a slightly used "just broken in" ZDZ80 for $600 w/Pitts muffler included. As I have come to understand it, the mfrs generally grossly exaggerate the available HP so you need to base decisions on flying/hover performance EXPERIENCE and the ZDZ80 actually delivers near the performance of a DA 100 due to its light weight. That of course is dependent on the plane and its weight. Thanks for the feedback- first one is always a tough one and the more non-commercial input the better. HNY |
Clarification
Umm- the point I failed to make is that I'd probably have to punch holes in the (now cylindrical) spun aluminum cowl anyway for adequate ventilation. So I figured what the hey- mount a big single can "popper" inverted and who cares if the plug sticks out of the cowl 1/2" on the bottom. My guess from Troy Built Models 55# THRUST estimate is that the ZDZ80 may actually climb out of a hover on a 35# plane. I used to fly with Gene P and I don't think he's big on blowing smoke. If he says it delivers 55lb thrust then he probably measured it (statically). Dinking around with static thrust a few years ago in 40ish engines, we found that prop selection based on our measured static thrust is a good indicator of hover performance- which makes sense.
My only question now is how the ZDZ80 VR I just got differs from the ZDZ80 VR-J currently on the market. Thanks again cap232ac for helping put my ideas in order. |
Redirect to Giant Scale forum?!
I think I may have asked these questions in the wrong forum. Apologies.
For anyone that happens to stumble into this thread, here's a lifeline- be sure to see the Giant scale forum for more info- for example the following thread is a good overall intro to the gas engine choices out there: http://www.rcgroups.com/forums/showt...&highlight=ZDZ You need to decide between the cheaper heavier engines and the performance ones early in your shopping! |
| Thread Tools | |
| Hobbico Press Release - Fuji-Imvac BT-32 EI Gasoline Engine w/Electronic Ignition Sys | Dave Lauck | Product Announcements | 0 | Sep 28, 2005 02:43 PM |
| Fuji BT-50SA Gas motor on Ebay, 2hrs left | neilo | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jan 14, 2004 08:14 PM |
| Question Anyone flying a Fuji BT-32A gas engine? | fujimo | Engines | 3 | Oct 05, 2003 08:26 AM |
