Old Dec 18, 2006, 02:08 AM
Kai@UCSB is offline
Find More Posts by Kai@UCSB
Kai@UCSB's Avatar
United States, CA, Fremont
Joined Nov 2003
EVO programming for DLG (Ail/Rud mix)
Hello All,
Is there way that we can program our EVO to switch between different (three) flying phases and "turn-off" the aileron-rudder mix for one of them?
What I am trying to get is three flying phases:
Speed/Normal/Thermal and I use switch-O (a 3-position switch) to change the phase. At the same time, I would like to "turn-off" the aileron-rudder mix at Thermal phase only.
Sounds easy but I tried several methods and they can only "turn-on" the mix in one of the phases and "turn-off" in other two phases. I originally used another switch for aileron-rudder mix but I found it will make flying much easier if less swtiches are used.
Please share your experience...
Thank you.
-Kai
Kai@UCSB is offline Find More Posts by Kai@UCSB
Old Dec 18, 2006, 03:58 AM
P-51flyer is offline
Find More Posts by P-51flyer
P-51flyer's Avatar
USA, CA, San Jose
Joined Aug 2005
I will work on it for you Kai, I have an idea as to how to do it and i will play with it. Let me know if you have tired this already though and this may not be explained the best... In the mixer menu under combi - sw, aileron -rudder mix, turn it off there. In the rudder mixer you have 3 Ail - Tr (Dr. Drela's program) and the 1st one can be turned on in place of the combi-sw aileron/rudder mix. What if you set it up and say the o switch turned that "on" and just make the "on" position your normal flying mode so that when you flip it to off it then turns off the aileron rudder mixing. Since its like 2am i will take a look at this in the morning if it does not make sense and try to explain it better. Hope that works, not too sure right now about it hahaha.
Aaron
P-51flyer is offline Find More Posts by P-51flyer
Old Dec 18, 2006, 01:58 PM
Endless Sloper is online now
Find More Posts by Endless Sloper
Rick Rogahn
Endless Sloper's Avatar
Seattle, WA
Joined Jun 2005
I would LOVE to see a DVD for programming Radios. I have an EVO 7 and a Optic 6 and I am positive I'm only using 10% of the capabilities. Anyone have a good webosite or video out there that could un-stupify me?
Endless Sloper is online now Find More Posts by Endless Sloper
Old Dec 19, 2006, 06:17 AM
Richard S is offline
Find More Posts by Richard S
Stream Team Models - Pilot
Richard S's Avatar
Milton Keynes, UK
Joined Oct 2005
A great website for info on MPX transmitters is : http://www.rc-soar.com/multiplex/index.htm
Mike Shellim who runs the site is well known for being one of the most helpful guys in the hobby.
In addition, have a look in the "Radio's" board on this forum. There are two guys (HarryC and Joedy) in-particular who are very knowledgable about all things multiplex.
Richard S is offline Find More Posts by Richard S
Old Dec 19, 2006, 09:54 AM
Rick Rogahn
Seattle, WA
Joined Jun 2005
Awesome, thanks Richard!
Old Dec 19, 2006, 11:13 AM
P-51flyer's Avatar
USA, CA, San Jose
Joined Aug 2005
http://www.multiplexusa.com/Radios/S...20Tutorial.pdf
A GREAT tutorial and how I learned to program the EVO. Takes you through step by step. And if you have questions on programming don't hesitate to post here and im sure you will get help for whatever radio you need it for.
Aaron
Old Dec 19, 2006, 01:13 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Kai,
I've had really good help (and I've needed it) on the Evo forum in Radios.
But I'm just curious, why do you want the rudder/aileron coupled in the other two phases?
GaryO is offline Find More Posts by GaryO
Old Dec 19, 2006, 04:33 PM
skyboyken is online now
Find More Posts by skyboyken
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
I don't have an Evo (I have a Cockpit SX) but the way I have achieved what you want in the past on less capable Tx's is to create a negative ail - rud mix that is only switched on in the phase where you don't want rudder mixing. Its effect is to negate the existing mix that you want off in that phase.
Break a Leg!
skyboyken is online now Find More Posts by skyboyken
Old Dec 21, 2006, 03:11 AM
Kai@UCSB is offline
Kai@UCSB's Avatar
Joined Nov 2003
Hi,
Finally got some time to give a try. The approach that Aaron suggested works!!! Thank you man... The only limitation is the "Thermal" mode need to be in the center position of the 3-position switch...
Gary,
I like to disable R/A mix in thermal mode because I can do more cross-control between Rudder and Aileron.
Thank you guys...
-Kai
Old Dec 22, 2006, 10:21 PM
GaryO is offline
Joined Sep 2001
Kai,
Glad you got things working. I guess my question was not clear after reading it. I was really wanting to know the rational for having the mix at all.
9303 Programming for DLG 2 servo wing rpsmithii Hand Launch 11 May 24, 2009 12:20 AM
Question EVO Programming for Hyper DL - Ailerons as Flaps for Launch John_R_C Hand Launch 10 Jul 07, 2005 10:53 AM
Question Help: Futaba 9CH programming for DLG Mousson Radios 0 Sep 04, 2004 09:58 PM
Anyone using royal evo radio for DLG? thrmaln Hand Launch 2 Apr 12, 2004 02:30 PM
Help: Eclipse programming for DLG FlyingPig Hand Launch 14 Nov 06, 2003 11:56 AM
