Old Dec 19, 2006, 02:26 PM
mbuehler is offline
Find More Posts by mbuehler
Tacoma, WA
Joined Apr 2006
I've had mine to this too. If the chopper has allready armed and I turn the radio off, it will head for the moon! Caused my first crash in the kitchen. Balanced the blades, gave it a total tune up, lifted off and landed, shut off the receiver, then almost lost my face as it came right at me. Hit two walls and my plants, didn't stop until the transmitter was back on. Now I don't turn the Tx off until I'm SURE the chopper has no power
mbuehler is offline Find More Posts by mbuehler
Old Dec 19, 2006, 02:43 PM
qbert55ca is offline
Find More Posts by qbert55ca
Great White North
Joined Dec 2005
It must have something to do with the arming system. The old boys all have the TX first on last off drilled into them, but that was when you went to a flying field to learn how to fly. With the upserge of mini electrics they needed some way of preventing us NEWBIES from chopping our fingers off and thus the arming system. I guess somebody forgot to tel the manufactures that Newbies can figure out a way to get around all the thinking. A simple {1 sec loss of signal / land} program in the chip would have done the job, but who would have known.
I guess us Newbies and not so Newbies will just have to learn the old mantra,
TX FIRST ON LAST OFF DON't FLY BEYOND YOUR CAPABILITIES
Now all newbies together...
Robert
qbert55ca is offline Find More Posts by qbert55ca
Old Dec 19, 2006, 04:23 PM
beafraid8 is offline
Find More Posts by beafraid8
Mom says I'm special...
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
At least the CX2 has programmable fail-safe! I've tested it quite a bit, too with no problems.
beafraid8 is offline Find More Posts by beafraid8
Old Dec 19, 2006, 06:53 PM
Welder13 is offline
Find More Posts by Welder13
Welder13's Avatar
Shenandoah Valley
Joined Dec 2006
Went there, did that today. It was too nice not to get outside and it didn't seem too breezy... Powered up and at just about the 20 ft level an updraft grabbed the helo and started hauling it toward the neighbors horse pasture. Tried to fly it back home, but no joy; I should have cut power as soon as I knew I was in trouble. At about 100 yds downrange and 40 ft of altitude the bird became a rock. I couldn't see where it landed for the terrain, but it must have spooked the horses because they scattered. Found it in about 15 minutes - a broken skid was the only damage.
Welder13 is offline Find More Posts by Welder13
Old Jan 03, 2007, 05:04 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Originally Posted by dribbe
Hi,
Not sure what failure this could be?? Most Rf interference on 72mhz results in the heli going down!
If you do get a CX2....
If the link is lost, the motors will shutoff in less than a second (DSM2 Failsafe feature). I have confirmed this many times by shutting off the Tx in a low hover... It just drops (and the Rx link light goes out).
Range should be about 350 ft.
David
Are you saying that the CX2 range is only 350 ft.??
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Jan 03, 2007, 05:46 PM
brett s is offline
Find More Posts by brett s
Roswell, GA
Joined Jun 2004
If the range is 350', that's at least double the distance I could possibly see it well enough to fly - not a problem
brett s is offline Find More Posts by brett s
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
rc
Less than that.
Flew the CX-2 receiver in a normal airplane.. it lost contact at 300' or so.
It's not an outdoor system..
http://www.rcgroups.com/forums/showthread.php?t=619802
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 04, 2007, 07:44 AM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Wasn't the range for the original BCX about 1500ft.??
The CX2 is "new & improved"? I'm not excited about this news!!
FYI... We just had a local flyer report that at about 200' his CX2 went into full signal lock-out and dropped out of the sky like a rock. Luckily his heli was saved by a tree. Replaced all batteries thinking that would help, and had a repeat of the first crash minus the tree and totaled his machine. He called Horizon and was told that the range on the CX2 was as far as you can see it. He replied that he could easily see it drop out of the sky at 200'. Horizon tech replied that the range was actually 175'.
Anyone from Horizon have a comment on this?
rc
Old Jan 04, 2007, 09:56 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
rc
Two different radio systems.. The CX is on 72 Mhz. The CX-2 is on 2.4 Ghz, and it has a very low powered transmitter.
The LP5DSM system in the CX-2 really isn't suitable for outdoor flying where the plane can get some distance away.
There's no such restriction for the radio with the CX.
Old Jan 04, 2007, 11:47 AM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Sparky,
Thanks for your comment but is this really progress in the right direction?
I love my CX2 but am not happy about this reduced range.
My local hobby shop was telling all their customers that the CX2 had out of sight range because that's what the Horizon rep told him before they placed their order. They are considering only stocking CX1s now!
rc
Old Jan 04, 2007, 12:01 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Either helicopter will be uncontrollable at the maximum useable range because they'll be too small to see!
The plane I used to check the range is many larger than the CX.
I get very uncomfortable with the CX/CX-2 at more than 100 feet away.
They're too difficult to control at those distances.
I don't see any reference to range in the manual for the CX-2.
Possibly Eflite felt the loss of contact due to size alone would be sufficient.
Old Jan 06, 2007, 12:33 PM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Has anyone heard or seen anything on using the DX7 transmitter to control the CX2? Does it increase the range?
RC
Old Jan 06, 2007, 01:47 PM
aeronuts is offline
Find More Posts by aeronuts
aeronuts's Avatar
USA, WV, Charles Town
Joined Mar 2005
RC
I don't know for sure about range, but that should be dependent more on the TX that the RX, so I guess it would.
I understand that the DX7 will work with the CX2, but the DX6 will not.
aeronuts is offline Find More Posts by aeronuts
Old Jan 06, 2007, 08:23 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Flew the CX-2 receiver with the DX-7 transmitter.. I'd say it's OK for the typical foamie, range wise... might try it in a higher performance plane to get more distance.
Old Jan 06, 2007, 09:11 PM
dankirk is offline
Find More Posts by dankirk
dankirk's Avatar
Joined Dec 2006
Just curious, why would you use a CX2 receiver with a DX7 in anything other than the CX2? Doesn't the DX7 come with a receiver to use that would allow long range?
dankirk is offline Find More Posts by dankirk
Rant My Blade CX want's to pitch forward! X190 Coaxial Helicopters 4 Feb 05, 2008 09:15 AM
Wanted please help me my blade cx flew away and sank adrian52492 Aircraft - Electric - Helis (FS/W) 35 May 27, 2006 08:07 PM
Discussion my blade cx flew away and sank adrian52492 Coaxial Helicopters 7 Apr 06, 2006 10:23 AM
Rant My T-Hawk flew away C-Ya Hobie Beginner Training Area (Aircraft-Electric) 28 Jun 04, 2005 09:30 PM
My Firebird XL Flew Away :( Manchild Parkflyers 7 Sep 15, 2002 08:56 AM
