Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
Which B-program is applicable? Same as used at last DMFV indoor competition? Regards Ruud |
Jürgen
of course it would be fairly easy to increase the numbers of competitors, but after all it is an annual Championship where you want quality rather than quantity. The schedules are intentionally difficult in order to avoid having to run qualification contests. As the models are getting lighter and slower, even 50 competitors appear too much for a 2 day competition. You may already have to decrease the number of pilots for round three. While promoting F3P is for sure a good thing, F3P-C and -D are foreseen for smaller events (i.e. like club or county competitions). Jürgen
Is there any chance that the F3P-C and D could be revised slightly to give everyone something new to fly at the entry level? aerolite |
As I modified the FAI F3P-AP schedule for the DMFV German Indoor Championship last year, I called it F3P-Expert and the new F3P-B schedule F3P-Sport to avoid confusion. If I ever needed to create a schedule below F3P-Sport, I would most likely call it F3P-Hobby. ![]() Jürgen
Jurgen, thanks for the clarification on the different sequences. I like your idea of an expert and sport schedule.
We have lots of folks wanting to try pattern for the first time, and we let them fly the older traditional C pattern. What are your thoughts on changing it up a little to make it more interesting for those just getting started, like maybe adding 1 or two more maneuvers? Also a question on the F3P-expert. I see several different versions used. Example, some with spins, some without. What is the most common version being used, so we can start using it here in the states for our local events? Is the only difference one has the spin and another doesn't? It seems some do the torque roll differently also, what are your thoughts? aerolite |
When the FAI in 2008 came up with the new F3P-A schedules (Preliminary and Finals) for 2009/2010, top-pilots from various European countries sat together at a restaurant in Casteau/Belgium and modified it, to make it suitable for the standard gyms (with lower ceilings and/or obstacles at the ceiling). It was also test flown the next day at the competition in Mons/Belgium (hence "Mons-Schedule"). For the DMFV F3P-Expert schedule, I used the Mons-Schedule with some modifications. The Mons-Schedule has no spin, as F3P models don't really stall and spin well and I also consider torque-rolls against the torque effect of the prop a bit "abnormal", hence the other modification. Instead of using a "Finals-schedule", I introduced an "Unknown-schedule" at the 2009 Championship for the first time. Jürgen
German Indoor Aerobatics Championship 2010
Just a little "Heads up":
The German Indoor Aerobatics Championship 2010 organized by the DMFV will take place from 06.- 07. November 2010 in 68794 Oberhausen, same hall where the first German Indoor Aerobatics Championship took place in 2001. For those who are planning a visit, Heidelberg and the Technik Museum in Speyer and/or Sinsheim are not far from there. No changes from 2009 in F3P-Expert (except of a different Unknown in the Finals of course. ).A slightly modified F3P-Sport sequence (no 1/2 roll in the turn, i.e. less inverted flying - see attachment). Jürgen
| Thread Tools | |
| Discussion Upcoming ISR events | TFLG | Inland Slope Rebels | 0 | Jun 09, 2006 04:13 PM |
