Old Sep 12, 2002, 07:11 AM
GHarvey is offline
Find More Posts by GHarvey
Lino Lakes, MN, USA
Joined Dec 2000
Need info on a new plane - FoldingFlyer
I was doing some research and came across a Speed 400 foam board plane called the foamflyer selling for a mere $20 or 3 for $50. They appearantly are being distributed by Norvel but the plane's web site has almost no information on it. www.foldingflyer.com Does anyone know anything about this plane? I'd like to know wing size (length, area), gear ratio, prop used, weight, battery (cells, type, capacity) used, as well as servos and receiver recommended. I assume it is a parkflyer, but how fast does it fly and is it aerobatic.
I'm sure someone on the zone must know something about this one.
GHarvey is offline Find More Posts by GHarvey
Old Sep 12, 2002, 10:03 AM
cnims is online now
Find More Posts by cnims
cnims's Avatar
United States, TX, Coppell
Joined Dec 1996
I ordered 2 of these kits a couple of years ago right after they first came out. They are still in the box, I haven't put them together yet. Not sure about the wingspan, but I believe it's designed for a speed 400 with the Mini Olympus gear drive (2.3/1) The material more closely resembles coroplast rather than foam.
cnims is online now Find More Posts by cnims
Old Sep 12, 2002, 10:15 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
That was actually several years ago, it was very heavy and would barely fly with a geared 400. I'd be really surprised they're still selling them. Because it was so heavy it needed to fly fast so I wouldn't call it a park flyer. It worked a bit better with a Norvel 061 engine and without the weight of the battery but then you needed even better reflexes.
After fiddling with various electric setups I eventually put a little diesel on mine but it didn't last very long.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Sep 12, 2002, 10:57 AM
cnims is online now
cnims's Avatar
Joined Dec 1996
Steve,
What electric setups did you try with this plane? Did any of them give satisfactory results?
Old Sep 12, 2002, 12:25 PM
AMTJIM is offline
Find More Posts by AMTJIM
"Bible Thumper"
AMTJIM's Avatar
United States, AZ, Tucson
Joined Mar 2001
I contacted Norvel about these recently and they are out of production. I happen to find a couple in a hobby shop. Very simple to make at home, which is probably one of the reasons why they are gone. The pattern is printed right on the foam board, so you only need one to make scratch builts at home.
AMTJIM is offline Find More Posts by AMTJIM
Old Sep 12, 2002, 05:37 PM
N. Staffs, UK
Joined Jan 1997
Sorry I can't really remember now, it was a while ago. Obviously none were good or I would have stuck with them. I think I tried S400 direct on 7 and 8 cells and probably a SpeedGear 400 6V but I don't recall if it was 1.85 or 2.33. Nothing I tried would climb above head height so I gave up and stuck the diesel in instead. At least it saved the weight of the battery.
Steve
Need info on Arup plane plan from Flying Models back issue Tomahawk Electric Plane Talk 7 Jul 05, 2011 08:41 AM
Discussion Info On new plane Little E Beginner Training Area (Aircraft-Electric) 0 Feb 14, 2006 10:20 PM
Need advice on new plane for eflight BL 370 cnc custom Foamies (Kits) 0 Dec 13, 2005 01:57 AM
New indoor flyer need info on the pico stick!! Derek.C Parkflyers 10 Apr 23, 2002 01:28 PM
