Old Dec 16, 2006, 03:09 PM
flyingace451 is offline
Find More Posts by flyingace451
No warning points today!!
flyingace451's Avatar
Hixson, TN
Joined May 2005
How do you install CA hinges?
I just went on a small shopping spree at the LHS preparing for the 2 planes I'm going to be assembling this Christmas. I got me some FoamSafe CA (that stuff is more expensive then I thought), some 5 minute epoxy, and some CA hinges.
The CA hinges will be going on an HL Yak-55 and an HL Pitts S-2, but I have never used hinges before. So my question is, how do you install them? Is medium CA ok for putting them in, because all I have is medium but it says to use thin...ANY help is greatly appreciated.
P.S. I've got a sim sitting under the tree...I want to open it really badly.
flyingace451 is offline Find More Posts by flyingace451
Old Dec 16, 2006, 03:17 PM
Khosravi is offline
Find More Posts by Khosravi
Chris Khosravi - KK4LJH
Khosravi's Avatar
United States, GA, Marietta
Joined Jul 2004
for foam planes you should use tape. Packaging tap works pretty good. it would be very hard to hing a foamy since the foam is only like 3-6 mm thick
Khosravi is offline Find More Posts by Khosravi
Old Dec 16, 2006, 03:20 PM
DOZZ is offline
Find More Posts by DOZZ
St. Peters MO.
Joined Apr 2005
You dont use CA Hinges on these planes. You tape the controle surfaces on with a good clear packing tape
DOZZ is offline Find More Posts by DOZZ
Old Dec 16, 2006, 04:09 PM
Hixson, TN
Joined May 2005
Ah ok, I thought I'd get rid of the packing tape I've used because I thought no one else really did it. I guess I was wrong, so I'll hang onto the hinges for something else I guess. Thanks for the advice everyone, they were only $3 anyway! ...Can I open my presents now? *NO*....drats.
Old Dec 16, 2006, 04:13 PM
MikeBiv is offline
Find More Posts by MikeBiv
TP 1.21 Gigawatt Needed
MikeBiv's Avatar
Hendersonville, NC
Joined Jul 2005
I've used CA hinges on the same Yal with great success! Used medium CA.
It can be tough lining up the control surfaces, but the result is great.
Packing tape? No way, made that mistake before. Use Blenderem.
MikeBiv is offline Find More Posts by MikeBiv
Old Dec 16, 2006, 06:37 PM
Leonard is offline
Find More Posts by Leonard
Leonard's Avatar
Tyler, Texas, United States
Joined May 2001
I like book binding tape from 3M (#845).
Leonard is offline Find More Posts by Leonard
Old Dec 16, 2006, 07:09 PM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Very interesting! I'm not familiar with this tape but I Googled it and it sure sounds like it will make good hinges.
I wonder how well it sticks to EPP.
Pete
PGR is offline Find More Posts by PGR
Old Dec 16, 2006, 07:37 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
On my EPP planes I use CA hinges and GWS hinge material. I use 15 min epoxy to give me some working time. On the Ca hinge, I cut them narrow and use a hole punch on the sides to make them more flexable. The tape always comes loose sooner or later, more so on EPP, but I've never had a CA hinge come loose. Butch
Butch777 is offline Find More Posts by Butch777
Old Dec 17, 2006, 07:29 AM
JoeDirtRC is offline
Find More Posts by JoeDirtRC
D/FW
Joined Aug 2004
If you get an Airfoilz Yak, they come with pin hinges that you epoxy in. And I believe their control surfaces are 6mm depron. So you don't necessarily have to use tape, you can make CA or pin hinges work. If you use tape, definetly use blenderm or Dubro hinge tape (which is blenderm). The only problem I have with taping hinges is that no matter how tight I think I have things, my controls always seem to still move up and down at the hinge line. Of course this makes my trim setting change during flight.
I've thought about going back to the pin hinges. Maybe if I just use one on each end and then use blenderm in the middle it would stop that from happening. Does anyone else have any advice or ideas?
JoeDirtRC is offline Find More Posts by JoeDirtRC
Old Dec 17, 2006, 09:24 AM
PGR is offline
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
I've been using both Tyvek (CA) hinges and tape on my EPP slope planes and the result is nearly bulletproof. It's flexible yet holds an accurate hinge line which is important on planks like my 48" Moth (for example):
The elevator mix travel on the elevons is only about 1/16 inch total (as in from full-up to full-down). Despite the small amount of travel, this plane will turn on a dime and leave change. Aileron mix travel is around 30.
Needless to say, any slop in the hinge line would result in a plane I could never trim for hands-off level flight yet this Moth tracks like it's on rails.
Pete
Old Dec 17, 2006, 09:37 AM
thermlin' is offline
Find More Posts by thermlin'
Needs a vacation
thermlin''s Avatar
In a house
Joined Nov 2005
oh yes, the Moth happens to be very sensitive, and all ive flown it is on realflight!
hats off to you for controlling that beast!
thermlin' is offline Find More Posts by thermlin'
Old Dec 17, 2006, 10:58 AM
PGR is offline
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
It's actually not that hard to control. It goes right where I point it and isn't prone to doing things I don't ask it to. But that's because I spent a lot of time on details like hinge lines, mechanical linkage ratios, and nailing the CG in a no-compromise way.
That said, it's not a very relaxing plane to fly because of it's speed. For something with no motor, it will sure wend it's way through lots of sky in very short order. It's a plane that requires all your attention all the time.
Pete
Old Dec 17, 2006, 01:42 PM
D/FW
Joined Aug 2004
Thanks for that input PGR, I'm gonna try it on my next foamie.
Old Dec 17, 2006, 02:11 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
When applying CA hinges, first draw across the hinge line with a crayon. Then stick a pin right through the middle. The pin will make sure that the hinges are in both surfaces evenly, and the wax from the crayon will ensure that the CA does not stick to where the hinge flexes. The reason you don't want CA on the flexible part of the hinge is because it solidifies the textured fabric stuff, and places too much stress on the flexible plastic. They'll work fine for a while without the crayon treatment, but will eventually tear.
cwojcik is offline Find More Posts by cwojcik
Old Dec 17, 2006, 05:48 PM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
cwojcik,
Best advice I have heard for those type of hinges. Thank you.
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
How do you install a GWS pinion? Mr. Wiz Power Systems 14 Sep 24, 2004 07:28 AM
How do you clean CA of covering film? vintage1 The Builders Workshop 15 Feb 08, 2004 05:56 AM
How do you install a GWS Prop Saver ? OzzieFlyer Electric Plane Talk 7 Nov 15, 2003 07:06 PM
How do you get CA off of the Kitchen Table (before the wife finds it!) jdpowell22 Electric Plane Talk 27 Jan 18, 2002 11:45 AM
