Old Dec 15, 2006, 05:40 PM
WATERTIGHT is offline
Find More Posts by WATERTIGHT
Joined Dec 2006
Resin--or Epoxy Resin???
Hello-
Building A Dumas Dauntless--What Is The Difference Between Resin----
Used To Glass---Or Finishing epoxy Retsin?? I thought This Was Just
Like Regular Two Part Epoxy--To Glue Parts--Why Would U Use It As
A Paint Base Befor Priming Or Paint--???
Can Some One Tell Me The Best Way To Prime And Paint Your Boat
"Electric" So It Comes Out With a Nice Shine--And Not To Many Flaws--LOL
First Used A Coat Of Resin--Than Prime---The Boat Did Not Look To Bad At All-- But When i Hit it With The Regular Gloss Paint--Ohhh--It Brought
All The Cracks--Wood Grain--And Wood Filler--Right Out---
So Now Sanded It Up Again--HELP-------
Whats Next???????
HELP!!!
WATERTIGHT is offline Find More Posts by WATERTIGHT
Old Dec 15, 2006, 07:35 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
It sounds like you are wanting to just coat the boat with resin and forget the fiberglass. Your first coat of resin has soaked into the wood, good thing but has laft some grain exposed. You will need to apply a few more coats of resin to fill the grain in, sanding lightly between coats to knock down the high spots. Thats if you let it cure fully between coats. If you let the resin just get tacky, then you can apply another coat without sanding. I prefer this method if time is available, it speeds up the whole process tremendously. After you have enough coats of cured resin then you can sand it down to a smooth finish.
When you are happy with the results then wipe the hull down with some degreaser using white paper towels. Now you are ready for a coat of primer. Your final finish is only as good as the effort you put into it.
green-boat is offline Find More Posts by green-boat
Old Dec 15, 2006, 10:01 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Epoxy resins are also used to produce fiberglass products.
They are completely different than the hobby epoxies used for cement.
Here is a tutorial on epoxy resing and fiberglass.
http://www.rcgroups.com/forums/showthread.php?t=329811
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Dec 15, 2006, 10:30 PM
pusar is offline
Find More Posts by pusar
I see a plan in your flaw
pusar's Avatar
Shaker Heights, OH
Joined Mar 2005
Welcome Watertight! I would highly reccomend using fiberglass on the Dauntless. With all the planking the fiberglass gives quite a bit of strength. The fiberglass will give the boat a great smooth finish for paint.
With all the planking in the bow if the boat ever hit or bumped something like a rock or a piece of wood you would be quickly taking on water. Dumas wood, paint and resin are a bad mix for a boat that will see water if thats what you intend to do. The resin alone can become brittle.
Have any pictures?
Marty
pusar is offline Find More Posts by pusar
Old Dec 16, 2006, 04:51 AM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
watertight, welcome to RC groups matey
once you have used resin on the outside, add fibreglass resin on the inside to treat the insides, as unlike abs plastic, wood can swell up if ya boat takes on water. NOT GOOD!
but hope to see ya on the water soon.
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Dec 16, 2006, 07:15 AM
Joined Dec 2006
[B] Thanks A Lot People--Will Get Back To Work On It--Was Very Helpful Info-
Will Post A Picture Soon , As I Move Along With This Paint project!!!
Tks Again!
Old Dec 16, 2006, 10:02 AM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
watertight, If you only use polyester resins to seal the hull, you run a great risk of it cracking or even pealing in a short period of time. When ever you use a poly resin your best to use it with cloth to help stengthen the hull and prevent water from ruing your efforts. Epoxy coatings do not always need cloth to give a good protective coating on your prodject. The best thing to do is to always coat thye inside of the hull and the outside. As with the others, sand the surfaces and make sure every thing has had sufficiant time to cure as your location (climate) has an effect on the cure time!
keith S is offline Find More Posts by keith S
Old Dec 16, 2006, 08:21 PM
Joined Dec 2006
My Dauntless
[B]Here Is A Picture Of My Dauntless-
I Hope----
I Always Loved This Boat--But never Liked The Pit In Front-
Boat Has Nice Lines- Never Cared For that Pit---lol
So Away It Went------
Waiting On Electronics--Now-----
Watertight
Old Dec 16, 2006, 08:54 PM
pusar is offline
pusar's Avatar
Shaker Heights, OH
Joined Mar 2005
The 2nd picture (primer shot)it looks like you slid the top cabin much closer to the front?
Marty
Old Dec 16, 2006, 09:07 PM
Joined Dec 2006
[b]right Marty-
I Did Not Epoxy It In Place Yet--needs Some More Work--just Placed It
On For Pictures--
Ps-would Flat Paint Be Better--or Gloss-semi Gloss--i Found That
If The Undercoat Is Not Perfect--you Are Better With A Flat---
Because If You Try A Gloss--wowwww--all Kinds Of Things Appear--lol
You Know What I Mean--lol-
Old Dec 16, 2006, 09:48 PM
pusar is offline
pusar's Avatar
Shaker Heights, OH
Joined Mar 2005
Flat paint will cover the most blemishes. Next is a matte finish followed by a glossy. The glossy has a tendency to make models look like toys. That being said, many times a gloss can be used on a hull and a matte or flat finish can be used on the deck. It just depends on the type of boat you are building and how you want it to look.
Marty
Finishing Resin or glassing and resin? new2rc Scale Kit/Scratch Built 65 Nov 03, 2005 09:24 PM
white wood glue or epoxy resin??? Masterpiece Composites Fabrication 2 Sep 14, 2005 08:24 AM
Epoxy or Polyester resin?? spitfirem9 Slope 6 Mar 02, 2005 12:56 AM
