Old Dec 14, 2006, 06:46 PM
simo10 is offline
Find More Posts by simo10
Planes from 1oz to 55lb's
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
Castle ESC's break records, my entries.
Over the past few years my father and I have been breaking records. Most of our records are electric based planes. Nearly all our tests and most of our records have used our trusty castle creations esc's either on the record day or in one of our tests.
We also have a new high altitude plane that uses a CC 80 esc and will be able to go to altitudes of 18000 ft, (that is as hight as the faa will let us go without yelling at us!) It has 17,500 mah of lipos (2500x3s7p) and has a flight time of more than 2 hours at a low power cruise. It uses a Kontronik 480-33 geared 5.2:1 with a 12x8 prop. This setup id 90% efficient (measured)
The distance plane is bigger and heavier and has if I remember, 36,000 mah of li-ion round cells(4s15p), as when we did our research they had the most watts per pound. We have not tried it, but it should be able to fly over 4 hours under power. It has an Actro cl-8 14x12apc, not the best, but light and it works.
simo10
Below is a list of all our electric based records.
see also
http://records.fai.org/pilot.asp?from=model&id=5074
noskylimit.com
Class F (Model Aircraft)
Sub-class F5 Open (Aeroplane, Electric motor S (rechargeable sources of current))
Category : F5: Radio Controlled Flight
N172: Distance in a straight line : 164.19 km
Date of flight: 05/11/2004
Pilot: Giorgio AZZALIN (USA)
Course/place: Jacksonville, FL (USA) - Scottsmoor, FL (USA)
This one was interesting, a few days before, we were doing a test for an altitude plane we were working on. It used the 250 dollar kontronik esc that was intended to be used on the distance one. The planes wings broke under stress in flight and the esc was gone. No one in the area I lived had a specialized esc. I gave my lhs a call, and asked if they had a CC esc in stock they said they only had the smaller sizes and the others were sold out. We drove all the way down to graves hobby shop in orlando, a 3 hour drive and picked up a CC 80.
We used it for the record and it worked great, but it is still not as efficient as the kontronik jazz 55.
N174: Distance to goal and return : 68.9 km
Date of flight: 06/11/2004
Course/place: Jacksonville, FL (USA) - St. Augustine and return
This was a short one, it used a castle creations ESC if I remember correctly.
Sub-class F5 Open (Aeroplane, Electric motor COMB (all sources of current))
N193: Distance in a straight line : 226.61 km
Date of flight: 24/04/2005
here COMBO just means we used a small non rechargeable li-ion for the rx and servos, which is totally under the guidelines.
simo10 is offline Find More Posts by simo10
Old Dec 15, 2006, 12:18 AM
UFly is offline
Find More Posts by UFly
UFly's Avatar
Chandler AZ
Joined Sep 2005
Im impressed, nice work.
UFly is offline Find More Posts by UFly
Old Dec 15, 2006, 08:09 AM
simo10 is offline
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
Here are some frame grabs from the altitude plane.
Old Dec 16, 2006, 08:43 AM
MattZC is offline
Find More Posts by MattZC
I just love flying
MattZC's Avatar
Traverse City ,MI
Joined Dec 2005
wow
Matt
MattZC is offline Find More Posts by MattZC
Discussion X-rays and Castle ESC's GBR2 Castle Creations 2 Mar 24, 2006 01:52 PM
For Sale Castle ESC's, BP 30 ESC's, Warp 4 and more DrDHalko Aircraft - Electric - Power Systems (FS/W) 14 Jan 26, 2006 11:25 AM
Help! Where to buy Shrink Wrap like what's on TP Packs and Castle ESC's Dynomike Parkflyers 4 Jan 03, 2006 10:49 AM
Sold Castle ESC's and Link Gene Chernosky Aircraft - Electric - Power Systems (FS/W) 5 Dec 05, 2005 07:06 PM
Castle ESC's Pixie and a Pegasus! BrunswickOH Aircraft - Electric - Airplanes (FS/W) 2 Feb 17, 2005 03:39 PM
