Old Jul 28, 2001, 06:41 PM
KOMET 44 is online now
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Which is a good receiver for the .40 to .60 size e-plane conversions???
I never had really shopped for a lite weight receiver and just thought i'd ask What's everybody is useing??.I have a fma tetra in my twin star.i also use a fma fortress for a test receiver but never have checked the weight.thanxs for your help.stefanP
KOMET 44 is online now Find More Posts by KOMET 44
Old Jul 28, 2001, 06:56 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
It's probably difficult to find a better small receiver than the RCD/Hitec 555.
Sparky Paul
PJB's Seriously Aeronautical Stuff
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 28, 2001, 09:10 PM
TopGun is offline
Find More Posts by TopGun
Pine Bluff,AR,USA
Joined May 2001
Nothing beats a JR. I am a glow heli pilot mainly and they are harder on RX's due to vibrationa nd etc. than anything out there. A JR is the creme of the crop. Futaba's are not as good and Hitec's are fine, but lack the refinement of a JR. JR does cost a bit more I admit, but as the old saying goes, the good things are cheap and the cheap things aren't good. I do hear great things about the Multiplex RX's though. Their PPD RX's that are half PPM(FM) and half PCM. You set your TX to transmit in PPM and the RX still has pre-set hold points like a PCM does.
TopGun is offline Find More Posts by TopGun
Old Jul 28, 2001, 10:01 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Agree with Topgun
I fly both Jr and Hitec. Favorite, due to years of reliable flight, is Hitec Supreme.
Great reliablility, 8 channels etc.
Price is right, excellent reliable erformance
Standard for Eflight seems to be the Hitec 555
DaveW is offline Find More Posts by DaveW
Old Jul 28, 2001, 11:24 PM
BillM is offline
Find More Posts by BillM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
The answer to this question is directly tied to the brand transmitter that will be used with the receiver and the type of signal propagation used. You cannot use JR or Airtronics receivers with Hitec and Futaba because of the frequency shift-JR and Airtronics is positive-Hitec and Futaba is negative. There are also other factors to be considered.
BillM is offline Find More Posts by BillM
Old Jul 29, 2001, 12:21 AM
Rod is offline
Rod
Find More Posts by Rod
Rod
Canada, BC, Kelowna
Joined Nov 1999
You should consider the FMA Extreme 5 receiver. It is one of the lowest cost dual conversion receivers on the market. It is definitely worth consideration.
Rod is offline Find More Posts by Rod
Old Jul 29, 2001, 12:51 AM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
Question: How many channels do you want (now); and how many might you want in the future?
I have a ton of Hitec 555's for 5 or less channels, and a Hitec Fortress for 8 channels. Bulletproof in my experience; readily available; relatively inexpensive.
Terry
temacc is offline Find More Posts by temacc
Old Jul 29, 2001, 01:00 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I'll agree: Hitec Surpreme or Super Slim (which is just a 7 channel repackaging of the 555 I'm told) or the 555 itself (for 5 or fewer channels). Note that these are available in both high or low shifts so can be gotten to work with whatever transmitter type you have.
I've also had decent luck with FMA receivers and have an Extreme 5 I need to try out.
Of course in a plane that size, the receiver that came with the transmitter should be just fine.... 3/4 of an ounce on a 40 to 60 size plane isn't going to be that big a deal. I fly planes that size with my full sized Airtronics Rxs.
BEC is offline Find More Posts by BEC
Old Jul 29, 2001, 02:45 AM
wiley is offline
Find More Posts by wiley
wiley's Avatar
owosso, mich
Joined Mar 1999
FMA has the only true dual conversion micro receiver on the market. this will be the next one i buy, as you never see them for sale used. i too fly JR, nothing but.
wiley is offline Find More Posts by wiley
Old Jul 29, 2001, 03:38 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
On a big plane like that you can use anything you like. If you particularly want a small Rx I'll second the Hitec 555. Lovely piece of kit.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Jul 29, 2001, 04:26 PM
fisher is offline
Find More Posts by fisher
Joined Apr 2001
You won't beat Futaba for dependability. I gave away a jr 7 channel because of reliability problems. The jr shift is different than Futaba by the way if you buy one it won't be compatible.
Hitec is ok for the price but not up on quality control issues. Their service is top notch though.
Multiplex seems to be leading edge but relatively new here. not widely distributed either.
For a 40 – 60 size plane E or other wise you shouldn’t need micro gear. I’d get a Futaba FM
fisher is offline Find More Posts by fisher
Old Jul 30, 2001, 12:26 AM
D.G.B.
KOMET 44's Avatar
Joined Jun 2000
Gentalmen THANK-YOU for the replys! Rite now i fly only 4channel airplanes.i use a futaba skysport radio&a hitec focas 3.i do have a older futaba pcm radio but i use that for my giant scale planes.Have fun,stefanP
Discussion Looking for 40 to 60 size spacewalker kit or plans jab1026 The Builders Workshop 1 May 31, 2006 12:36 PM
Wanted MK retracts for 40-60 size plane coloradoz Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 18, 2006 07:58 PM
Wanted Power setup for 40-60 size plane valerko Aircraft - Electric - Power Systems (FS/W) 2 Dec 29, 2005 10:13 PM
For Sale NIB Magnam XL80rsf 4 stroke for 40~60 size 3D plane heliguy Aircraft - Fuel - Airplanes (FS/W) 0 Oct 31, 2005 07:58 PM
FS: JR Digitals for 40-60 size conversions Bill K. Aircraft - Electric - Airplanes (FS/W) 4 Jun 30, 2004 08:52 AM
