Old Dec 14, 2006, 02:50 AM
Hydrocat is offline
Find More Posts by Hydrocat
hydrocat
Worcester Western Cape South Africa
Joined Feb 2006
Help!
Fox Engine Identification
Hi All
Please help me identify this engine. I know it must be from the Fox Factory, from the structure and carb design, but I cannot find any pictures on the Fox site that looks like this one.
- It has no markings on any of the casings or parts (none whatsoever)
- It must be around .36 to .50 in size
- The casings are factory polished
- It came with a copper fixed ventury carb (no butterfly) and a throttle
carb as fitted in the picture
- It has bronze bushings (no ball bearings)
- I would like confirmation that it is indeed a Fox
- Size and engine type
- Year/s of manufacture
Is the engine worth collecting or should I just use it somewhere?
Fanie
Hydrocat is offline Find More Posts by Hydrocat
Old Dec 14, 2006, 07:30 AM
dr.E is online now
Find More Posts by dr.E
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
Is that the prop they sold it with......
dr.E is online now Find More Posts by dr.E
Old Dec 14, 2006, 09:52 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
It looks like a Fox 36X.. with an aftermarket venturi and exhaust.
How old, I dunno.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 14, 2006, 10:11 AM
Jeffery is offline
Find More Posts by Jeffery
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
Fox made carbs like that, I think it's the right carb.
Jeffery is offline Find More Posts by Jeffery
Old Dec 14, 2006, 02:04 PM
Hydrocat is offline
hydrocat
Joined Feb 2006
Thanks for the response everyone......... Dr.E, the prop was fitted to hold the enjine upright for the pictures, and does not belong with it.
I cannot understand why someone would go to all the trouble to make moulds for such a beautifull engine and not put a name or brand or even the size nor serial markings on it. Was this common for Fox engines or perhaps a serious oversight?
Maybe I should remove the head again to measure the bore and stroke to establish the correct displacement first, or even mail Fox Manufacturing. Wonder if they'd bother to answer. Could be worth a try.
Old Dec 14, 2006, 02:19 PM
Jeffery is offline
And You're Not
Joined Oct 2002
Here you go:
Looks like a 40 or 45 from between '75 and '77. The carb and exhaust stack are correct.
http://www.flitelinesolutions.com/45history.html
The carb is the 2-Jet
http://www.flitelinesolutions.com/2jet.html
Old Dec 14, 2006, 08:21 PM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
It is a 0.40 cid (6.5cc). The 0.45 (7.5cc) was stamped as such on one of the mounting lugs. Too bad it doesn't have the 3-needle card. Fox has a very good customer service policy.
Konrad
P.S. This engine runs best on mild nitro 25% (Missile Mist) up to 40% nitro. The head has no squish band which result in poor low nitro performance. Also use only caster oil in 40% or lower nitro fuels.
The back door cover screams FOX. No need to say anything else.
Konrad is offline Find More Posts by Konrad
Old Dec 15, 2006, 12:31 AM
Hydrocat is offline
hydrocat
Joined Feb 2006
I also found a 1977 brittish RC magazine last night with a sales add stating that it is a Fox .40 RC selling for 28 Pounds, so you both nailed it. Thanks for the interest.
I've been flying for two years and have only seen/used the following brands: OS, Enya, Webra, ASP, GMS, Saito, Magnum, Fugi, Thunder Tigre, Cox, Super Tigre and YS. Looks like Fox was never marketed in South Africa. Now the big question.........Is it worth collecting?
Fanie
Old Dec 15, 2006, 08:39 AM
Jeffery is offline
And You're Not
Joined Oct 2002
Over here, Fox engines were ubiquitous fixtures in any hobby shop of that era. I'd be surprised if that one would bring $50 on Ebay with box and papers. But it's a nice example of the model, and it's complete with correct carb and exhaust. Being the bushing version rather than BB hurts its value IMHO, but it's still a good clean engine that was only produced for a couple of years.
I'd say hang on to it, it's bound to be somewhat of a novelty in SA, and selling it isn't going to make you wealthy
Old Dec 15, 2006, 11:14 PM
on pipe is offline
Find More Posts by on pipe
on pipe's Avatar
Omaha Nebraska
Joined Nov 2004
The .40's are old workhorses. Feed it a good dose of castor and it will last forever.
Ross
on pipe is offline Find More Posts by on pipe
Discussion Engine Identification Part 1 poppymann Engines 4 Oct 17, 2006 02:09 PM
Fox Engine information indoorff Engines 5 Sep 13, 2005 10:12 AM
