Old Jul 28, 2001, 03:24 AM
Foxtrot is offline
Find More Posts by Foxtrot
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
How do you tell if you have a cold solder?
I'm reworking some battery packs. And was just wondering if there was a way to tell if you have a cold solder joint.
Foxtrot
Foxtrot is offline Find More Posts by Foxtrot
Old Jul 28, 2001, 05:15 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
By looks, look real close. If you can't say its perfect, redo it. Another way of putting it is, if you are wondering if it is right, it's not.
..AZ Chuck
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Jul 28, 2001, 06:52 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
If you can see it, it needs to be shiny. If it's dull, it's bad. However, tough to see between cells!
I always try to pull my cells apart after soldering them. I also drop the soldered up strips of cells (before I complete the pack) on the bench a few times to see if anything gives.
..a
Old Jul 28, 2001, 05:28 PM
tahustvedt is offline
Find More Posts by tahustvedt
Norway
Joined Jul 2001
If it's a lump it's bad. If it's flat and look like it's blending with the surface, it's good.
tahustvedt is offline Find More Posts by tahustvedt
Old Jul 28, 2001, 06:33 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Shiny is good but I've found it hard to get on a battery because of the great heat sink capacity of the battery. If the solder is all liquid when I remove the iron, it's a take for me. The iron has got to be hot enough to melt it in under a second. You should be able to see the solder hardening in a few seconds after the iron is removed.
hoppy
PS Andy's comment on dropping the pack reminds me of the technique ham radio operators use when getting a new rig...drop it on the table from a couple inches up to see if there are any loose connections. Better to have the factory fix them while under warranty.
I've been using this technique on my RC eauipment. Dive it in from 50' and see if it still works.
[This message has been edited by hoppy (edited 07-28-2001).]
hoppy is offline Find More Posts by hoppy
Old Jul 28, 2001, 07:12 PM
Foxtrot is offline
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
Thanks. Looks Like I'm doing something right for a change.
Foxtrot
Old Jul 28, 2001, 07:56 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The iron doesn't need to be all that hot for solder to stick to a cell - but you DO need to have a large enough tip to be able to hea the end of the cell without all the heat being drawn out of the tip. 40W is more than enough to solder any size cell, more heat (power) doesn't help. That's why the guns are so useless - no mass in the tip.
..a
Discussion How do we tell if we are making progress? GaryO Hand Launch 10 Aug 17, 2006 08:14 AM
Discussion how do you tell if you have a dead cell in your pack AzJason Batteries and Chargers 4 May 12, 2006 06:27 PM
How do you tell if you have damaged windings? Paul Power Systems 1 May 13, 2002 02:37 PM
How do you tell if a GWS ICS-50 is actually trying to put out full throttle. The Other Dave Parkflyers 3 Jan 08, 2002 05:52 PM
How do you control flap/crow etc effectively if your radio do not have.... Magna Power Systems 4 Sep 23, 2001 08:52 AM
