Old Dec 12, 2006, 03:50 PM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
Question
I need two or three 20 to 30 amp Fet's. Help.
I would like to buy two or three Fet's in the 25 to 30 amp range. They are cheap online, but the minimum order and shipping is costly. I am hoping someone has a few they might want to sell, that is left over from a build. Thanks for looking.
Himeros
himeros is offline Find More Posts by himeros
Old Dec 12, 2006, 03:59 PM
rockom is offline
Find More Posts by rockom
rockom's Avatar
United States, IL, Genoa
Joined Jan 2004
Ask the manufacturer for free samples....
Have them shipped to a business address.
rockom is offline Find More Posts by rockom
Old Dec 13, 2006, 04:09 AM
JohnMuchow is offline
Find More Posts by JohnMuchow
CamLight Systems
New York City, USA
Joined Oct 2003
I've got a bunch of IRL540N, IRL1404 and IRF1405 in TO-220 case. Would any of these work for you?
[Edit] For anyone else reading this thread, I also have ten IRFPS3810PBF FETs in SUPER247 case that I'm not using and would love to sell.
JohnMuchow is offline Find More Posts by JohnMuchow
Old Dec 13, 2006, 02:33 PM
himeros is offline
O. C. CA
Joined Jan 2005
If I am reading the spec sheet right the RIL 1404 should do the trick. It appears the Rds is .004 Ohm or 4.0 M Ohm. The current is way more than I need, but I hear bigger is better. How much for 3 shipped to 92626 slow way? Thanks for the reply
Himeros
Old Dec 13, 2006, 03:36 PM
CamLight Systems
New York City, USA
Joined Oct 2003
The IRL1404 and IRF1405 both have very low Rds-on. I find that once it warms up a bit, the actual Rds-on is about twice the rating...still darn low. I easily pull 10amps through them without a heat sink and much higher current levels with sinking. And the IRL1404 turns on fully at a lower voltage but the IRF1405 has a higher Vds rating.
Three 1404's will be $6.69 (I paid $2.23 each), padded envelope is 70-cents, and shipping will probably be a dollar or less. I'll know the exact amount when it's all packaged up.
If that sounds good, you can PM me your address and I'll get them out to you on Wednesday.
Old Dec 14, 2006, 12:49 PM
himeros is offline
O. C. CA
Joined Jan 2005
P. M. sent. Thanks
Himeros
Link Cermark 20-30 amp brushless esc's flightmare Hot Online Deals 7 Sep 07, 2007 07:14 PM
Discussion I need a fixture that lets an old fashioned Deans two or three pins connector to plug phil alvirez Electric Plane Talk 5 Jul 24, 2007 05:35 PM
Two Or Four Brushless Motors On A Plane Do Need Two Or Four Brushless Esc's agapornis Power Systems 1 Jul 17, 2005 06:17 PM
WTB speed control 20-30 amp\w bec joe blosser Aircraft - Electric - Airplanes (FS/W) 2 Jun 01, 2002 08:25 AM
Two or Three Capaciters? OCModels Power Systems 14 Sep 18, 2001 10:14 AM
