Old Apr 20, 2001, 10:39 PM
Old school newb
PunkerTFC's Avatar
Iraq
Joined Feb 2001
How do i make my own hot wire rig?
can someone point me to instructions on how to make my own hot wire rig?
PunkerTFC is offline Find More Posts by PunkerTFC
Old Apr 20, 2001, 11:05 PM
Function Over Form
BillH's Avatar
Connecticut
Joined Feb 2000
THe best way to do it is find a Variac, and hook it up to a 12 volt step down transformer. IF you dont use the stepdown, the adjustments will be WAYYYY too sensitive, if your finger slips, the wire will turn bright red and melt. Also the 12 volt stepdown will keep your Variac from frying.
As for the Bow, just design your own design out of PVC or wood, Make sure you can adjust the tension on the wire.
AS for the wire, use Stainless steal fishing leader wire. Its available in tons of thicknesses, and works much better than nichrome wire, despite what people will tell you.
[This message has been edited by BillH (edited 04-20-2001).]
BillH is offline Find More Posts by BillH
Old Apr 20, 2001, 11:12 PM
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
I've heard you can also just use a model train transformer. I don't know what specs it needs though.
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Apr 20, 2001, 11:21 PM
dave morris's Avatar
orlando fl
Joined Oct 2000
BillH I am a little fuzzy on the 12v transformer, I use my Variac without one and have no problem (short of electrocution) with the adjustments. I just crank it to about 10-13 volts and cut away. It is a 15 amp unit I got from a surplus store for 125$.
dave morris is offline Find More Posts by dave morris
Old Apr 21, 2001, 12:22 AM
Old Guy
Ron Cichowski's Avatar
Carver, MA USA
Joined Jun 2000
http://www.charlesriverrc.org/articles_foam_vac.htm
This link should give you some ideas.
Ron
Ron Cichowski is offline Find More Posts by Ron Cichowski
Old Apr 21, 2001, 12:41 AM
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
I use a 24 volt 3 amp transformer and the stainless wire. Nothing else but an inline fuse and it works great. Your cutting wire must be kept around 35 to 40 inches.
Adam
Adam Neat is offline Find More Posts by Adam Neat
Old Apr 21, 2001, 09:32 AM
Martin Irvine's Avatar
Kingston, Ont., Canada
Joined Aug 2000
I'm using a speed controller and a 12V deep cycle battery _ things I just happen to have around the shop
(I also use a servo driver now but have run it with a receiver and transmitter)
I also am using stainless steel fishing wire for the cutting wire in bows made from 3/4" dowel and 3/16 spring steel. Dead simple and cheap.
cheers,
Martin
Martin Irvine is offline Find More Posts by Martin Irvine
Old Apr 21, 2001, 09:50 AM
Function Over Form
BillH's Avatar
Connecticut
Joined Feb 2000
Dave, I wish I could tell you why, but my boss who is an Electrical Engineer told me to do so, or I would blow out my variac. I think he mentioned it had something to do with the impedence.
Old Apr 21, 2001, 10:06 AM
maciek's Avatar
Worcester, Ma, USA
Joined Feb 2001
I connected two car battery chargers in series, and I adjust temperature by sliding one of the power wires along the nichrome wire (shorter distance between the wires makes the nichrome hotter). It's worked for me really good and all it cost me was a couple $ for the nichrome. I also had to borrow a second charger from a neighbor:-)
<marquee> hope this helps... <marquee>
[This message has been edited by maciek (edited 04-21-2001).]
maciek is offline Find More Posts by maciek
Old Apr 21, 2001, 01:23 PM
Function Over Form
BillH's Avatar
Connecticut
Joined Feb 2000
Why I light dimmer?
DOesnt the Variac have an adjustable wheel you turn?
Old Apr 21, 2001, 01:50 PM
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Originally posted by BillH:
Why I light dimmer?
The transformer/dimmer is a lot cheaper than a variac.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Apr 21, 2001, 01:59 PM
Function Over Form
BillH's Avatar
Connecticut
Joined Feb 2000
ohh ok, makes sense, I thought they were using all three together
Old Apr 21, 2001, 06:48 PM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
We're all flying electric planes, right? All I use is a seven cell battery pack and a homemade bow with .015 music wire. If the wing has too long a length of cut (music wire too long) for the seven cell pack, I use an eight cell pack. It works for a few cuts and then you simply recharge it. Works better if you have a couple of packs. I found a drawing of a bow on a german site.
http://www.jps.net/cobrajet/Foambow4.JPG
GregG is offline Find More Posts by GregG
Old Apr 22, 2001, 12:03 AM
Joined Nov 2000
I use an Astro charger in "test" mode. You can dial in any current you want.
Old Apr 22, 2001, 12:54 AM
Canada
Joined Nov 2000
Aircfraft Spruce and Specialty they have a Webb site.. sell Variacs for $60 and an 'El cheapo' hot wire kit consisting of a largish 24v transformer and a household light dimmer for $18.
Laughably simple, easily home duplicatable.. and it really works, especially using "Controline" stainless wire, obtainable free from any CL flier.
Bare is offline Find More Posts by Bare
How do I make my boat fast? slinges Racing Boats - Electric 16 Apr 09, 2013 05:30 PM
Alert How Can I make my own prop saver? ssyed Beginner Training Area (Aircraft-Electric) 5 Aug 10, 2004 12:55 PM
Question How do I make my Ascent lighter ? ilopes Electric Sailplanes 4 Dec 18, 2003 04:15 PM
How do I make my own decals? PDX Slope Pilot Electric Plane Talk 11 Apr 13, 2003 12:28 PM
How do i build my own Jet neophyte Electric Ducted Fan Jet Talk 1 Feb 19, 2003 10:55 PM
