Old Dec 22, 2006, 02:40 PM
wmcneal is offline
Find More Posts by wmcneal
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
Great review!
I just got mine yesterday and have been having a blast flying all over the room, landing on skyscrapers (tabletops), and chasing the cat (just kidding) ;-)
I had to adjust the gain trimmer on mine down slightly to get rid of a little tail wiggle, but other than that it flew great right out of the box. I got the police body for mine and it was a little difficult to swap bodies, but not too bad. I also got the motor heat sink for mine and installed it after the first flight and I'm glad I did because they do get very warm. That cheap investment will make the motors last longer. It was quite difficult to install the heat sink. I had to loosen the motors from their mounting so I could get it to fit in between the motors and the rotor shaft. I'm thinking of cutting some tiny air holes in the canopy just above the heat sink for better cooling airflow.
The only thing I wish about this helicopter is that it would move forward faster for better wind penetration. Even if you hold the cyclic stick full forward the helicopters' natural stability wont let it go very fast. Good for indoor ops and beginners, but not outdoors.
All in all I'm very pleased with the BCX2. It is a lot of fun to fly!!!
wmcneal is offline Find More Posts by wmcneal
Old Dec 22, 2006, 02:44 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Originally Posted by 10Thumbs
Wonder if Horizon will ever unbundle the TX so you could buy a DX7 TX and use it instead?
That would be awesome.......
Old Dec 22, 2006, 03:30 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Moving the pitch servo pushrod out two holes on the arm enhances wind penetration.
But then the indoor manuvering suffers, not enough "back stick" to get back from obstacles.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 22, 2006, 04:22 PM
JWags is offline
Find More Posts by JWags
JWags's Avatar
United States, MN, Rogers
Joined Mar 2003
Woohoo! Nose-in hover!
This thing is a joy to fly.
I bought a Corona years ago (around when I registered here), and never really got the hang of anything besides tail-in hover. I tinkered for a while, then moved to planes.
Even when I bought the CX2, I initially could only tail-in and side-in hover.
Last night I fabricated a USB controller and got about an hour's time on a simulated heli. I managed nose-in hovering and was doing (ugly) circuits of the field after about 15 minutes. None of it was pretty, but I was doing it, and not crashing much.
Today, I picked up the CX2, took off tail-in, and spun the tail around to face myself for the first time ever. It wasn't pretty, but it worked and I was hovering. Then I did lazy circuits of my "flying space" until the battery died just a couple of minutes ago.
The CX2 is actually easier than the simulator!
Kudos to E-flite for a fun helicopter that's more than a toy.
JWags is offline Find More Posts by JWags
Old Dec 22, 2006, 04:27 PM
That can fly?!? is offline
Find More Posts by That can fly?!?
Live, Die, FLY
Kalispell, in the Rocky Mountains
Joined Jul 2006
How much is the head speed increased? Also would it be easyer to get away from obsticles if the flybar was slightly shorter (more responcive).
That can fly?!? is offline Find More Posts by That can fly?!?
Old Dec 22, 2006, 05:04 PM
Nailz is offline
Find More Posts by Nailz
Seattle
Joined Dec 2006
Great videos and write up! I get mine from Santa in a few days! Another question... can this radio be used with any of the flight sims out there?
Nailz is offline Find More Posts by Nailz
Old Dec 22, 2006, 06:22 PM
NuNuJet is offline
Find More Posts by NuNuJet
United States, NY, Lake Grove
Joined Mar 2006
The headspeed doesn't increase, the deflection of the swash increases, causing increase in angle of attack (tilt) of the lower rotors. The end result is better wind penetration and much faster FFF. The trade off is a little less stability and lots of blade clashes if you are hard with the sticks.
Nunu
NuNuJet is offline Find More Posts by NuNuJet
Old Dec 22, 2006, 06:55 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
This doesn't increase the headspeed, it increases the amount the lower blade can move in the forward direction.
The easiest way to get away from obstacles is to identify them before flying, then don't into them.
Old Dec 22, 2006, 07:24 PM
gfdengine204 is offline
Find More Posts by gfdengine204
President, RC Dusters
gfdengine204's Avatar
Sandwich, IL
Joined Nov 2006
I just got a DX-7, and this heli is on its way. Any idea if I can bind the DX-7 to the BCX2?
gfdengine204 is offline Find More Posts by gfdengine204
Old Dec 22, 2006, 07:44 PM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
No idea if you can but it can be done.
Unplug both motors from the 4-n-1 receiver (be sure to note where both plugs went and the polarity) then bind it to the DX7. Turn off the receiver and remove the binding plug.
Just use an aircraft setting and get the servo reversing switches set to move everything in the correct direction.
After all of the control movements match the directions that the manual says they should move for a given stick input you can add dual rates and expo to taste. Finally plug the motors back in and fly. After you get the copter trimmed, you can rebind to establish the failsafe positions.
gwh is offline Find More Posts by gwh
Old Dec 25, 2006, 01:12 PM
hudog is offline
Find More Posts by hudog
Joined May 2006
Couple of questions:
1) I'm debating between the CX2 for around $190, or the CoCo Lama on closeout for around $120 as a first helicopter. Is there a significant difference in flight characteristics between these 2, or would people with experience on the Lama recommend the CX2 as being significantly better?
2) Is there a training port on the Spektrum transmitter that allows it to me used with FMS simulation software?
tnx,
George
hudog is offline Find More Posts by hudog
Old Dec 26, 2006, 03:11 PM
bryadelm is offline
Find More Posts by bryadelm
United States, PA, West Chester
Joined Mar 2006
I have broken enough blades, skids, and one body to finally achieve hovering and basic flight patterns with my eFlite Blade CX2.
Has anyone located add-ons for 5th Channel with eFlite Blade CX2 Spectrum Tx to provide lighting, releasing objects or other features using the extra connections on the 4-in-1 Rx?
bryadelm is offline Find More Posts by bryadelm
Old Dec 26, 2006, 06:13 PM
wmcneal is offline
AMA 125691
wmcneal's Avatar
Joined Jul 2002
I was flying mine outdoors yesterday when I managed to get it up to quite a good speed. All was fine until I turned it into the slight breeze that was present. Next thing I knew the upper and lower blades were smashing into each other and shattering. Down she fell from about 30 feet up and landed hard on the pavement. Aside from the smashed forward fuselage and the blades being damaged she suffered no other ill effects. (correction: see post 43) I have ordered a new front fuselage and more blades. She will fly again, although I will be more careful to fly much slower when ther is ANY hint of any wind.
I guess this truly is a beginners Helo and ideally suited for what it is designed to do, hover around slowly indoors, but my next helo will be more suited to my flying style.
Old Dec 26, 2006, 07:19 PM
A.T.A.C. is offline
Find More Posts by A.T.A.C.
I make ARFs out of RTFs..
Wexford, PA USA
Joined Jun 2004
tnx,
George
I will be able to answer this question in a few days. I have a Co-Co Lama V3, and Mrs. Santa brought me a BCX2 . I have not tried it yet.
The Lama is a very nice heli, and it is a bargain. You can get it even cheaper here:
http://www.bestdu.com/home.php?cat=252
I got mine from Hobby-Lobby during a crash sale for $100. The only complain I have is the battery and/or the charger. At about the 10th charge/discharge cycle the battery puffed up. I had to destroy it. It is still resting in salt water! Other than that, it is a fine product. I can hover, forward and backward fly and do precision landing (most of the time ). It handles gentle breeze. I was able to fly it around at my backyard. I am expecting the BCX2 to be even better.
ATAC
A.T.A.C. is offline Find More Posts by A.T.A.C.
Old Dec 27, 2006, 10:02 AM
mcharles13 is offline
Find More Posts by mcharles13
Jaded Flyer
mcharles13's Avatar
United States, FL, Clearwater
Joined Aug 2004
I have a dx7 can the blade cx2 be purchased w/o the tx?
Can one be pieced together from replacement parts? Is that worth it cost wise?
I really dont need the Tx as i have a dx6 and dx7.
mcharles13 is offline Find More Posts by mcharles13
Cool E-Flite Blade CX2 hovering nose in tallflyer Coaxial Helicopters 8 May 06, 2007 10:53 PM
Sold E-flite Blade CX2 2.4GHz Transmitter Dynomike Aircraft - Electric - Helis (FS/W) 2 Apr 11, 2007 09:48 PM
Sold E-flite Blade CP RTF Micro Heli with Extras Harv Aircraft - Electric - Helis (FS/W) 18 Aug 01, 2005 11:41 AM
For Sale E-Flite Blade CP (new in box) QuietRiot Aircraft - Electric - Helis (FS/W) 0 Jul 28, 2005 09:38 AM
E-Flite Blade CP- anybody seen one? More Power!! Micro Helis 3 Apr 22, 2005 06:33 AM
