Dec 12, 2006, 09:51 AM
Joined Mar 2006
Spiderwire or monofiliment fishing line is what most of us are using for the cables. Then just use standard control horns and servo arms, or make your own from carbon fiber, coffee can lids, old credit cards, etc.
Put the control horn on the control surface as close to the hinge as possible, and make sure its locked in there good and solid with glue. Then tie on your cables.
The cables dont need to be super super tight. If you tie them too tight, they fight against the hinge, and will pull the hingetape up. Just tie them tight enough so that they are not floppy.
If your pullpulling the rudder from inside a enclosed fuselage, cross the wires over inside the fuselage to keep them from rubbing the fuselage walls or binding.
