Old Dec 11, 2006, 07:56 PM
peterpont is offline
Find More Posts by peterpont
Troutdale, Oregon, United States
Joined Oct 2003
6 bladed prop
Well, here I go again, looking for the impossible. Has anyone ever made their own? Could 2 -3 blades props be combined? I am open to any and all ideas but am deadly serious on finding a solution.
peter
peterpont is offline Find More Posts by peterpont
Old Dec 11, 2006, 08:17 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Its deffinately possible, one recently in groups posted but i cant remember who
but it does require building a accurate jig to mill saw the correct angles when cutting up the hubs of the props then they were clamped together using 2 turned lipped washers that were notched around the circumference for the blades to poke through so the prop hub was completly encapsulated.
olmod is offline Find More Posts by olmod
Old Dec 11, 2006, 08:28 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
You are modifing the crap out of a safe 2 props by leaving sharp edges that can shatter without any warning at any rpm.
Non running, fine.
Flying, your lawsuit at a flying field.
Can you balance it for running balance ?
EDIT.
What plane used 6 bladed props ?
cyclops2 is offline Find More Posts by cyclops2
Old Dec 11, 2006, 09:35 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
OK so your a nay sayer that still does not say it cant be done safely,no rpm figure has been discussed,vario prop seem to do it ok with 4 blades.
Old Dec 12, 2006, 02:08 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
peter
Sure. I've designed lots pf props to make yourself..
http://www.rcgroups.com/forums/showthread.php?t=585380
I guess I could do a 6 blader if you asked me nicely..
Hub area would be the tricky bit..Also RPm would be a tricky thing..if you go low enough its safe.
Old Dec 12, 2006, 03:12 AM
hul is offline
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
Originally Posted by olmod
Its definitely possible, one recently in groups posted but i cant remember who
Lynxman? Starting at post #312 http://www.rcgroups.com/forums/showt...ight=propeller
Hans
hul is offline Find More Posts by hul
Old Dec 12, 2006, 03:22 AM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
Some big turboprops. The newer Hercules variants certainly have them.
Work in Progress is offline Find More Posts by Work in Progress
Old Dec 12, 2006, 03:40 AM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
The hub is the problem... you could use varioprop blades, or perhaps heli tail blades.
ATR airliners have 6-bladers, as well as the hercs.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Dec 12, 2006, 03:46 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
An all wood solution is possible..if the power levels are not too high...which they will not be if its a true scale prop. Generally you end up with pretty low RPM and pretty coarse pitch.
Milling up a varioprop type hub in metal is quite an undertaking..
Old Dec 12, 2006, 03:58 AM
Joined Jun 2006
True... however, a hexagonal core block to which you could screw six T-Rex tail blade grips wouldn't be too bad, nor would the fitting to do the job of the 'rex's pitch slider.
And since a T-Rex tail does 19000 RPM stock, it's going to be pretty strong even if you use the plastic grips. I think it's a runner, but you'd only get something like a 6" diameter. Motocalc tells me a 6 blade 6x4 takes around 400W at 15000 RPM and creates a kilogramme of thrust; not shabby performance.
Old Dec 12, 2006, 04:26 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Oh..6" is not an issue..I was assuming it as 10-12" diameter..I wouldn't want to run that much over 5000..
Old Dec 12, 2006, 04:31 AM
Joined Jun 2006
Well, for bigger you'd want to do the same thing, but with T-Rex 600 or Raptor blade grips. Really big, I guess you could use main blade grips... but that's getting silly, you'd need 2500W to turn a 6-blade heli head using 325mm blades...
Old Dec 12, 2006, 10:38 PM
Joined Oct 2003
6 blade prop
WoW! Great response from knowledgable people. I am in the process of building a 5% replica of the Dehavillan dash 8 Q400 (402) I am antiscipating a prop length of between 8 and 10 inches. I plan to gear for a lower rpm and may use additional forces to add to the torque and thrust of the plane. I have to work out the weight issue as well as the wing loading as these planes(commercial turbo-props ) had a very narrow wing.
What compromises I will have to make along the way will determine the use of a scale prop (6 rather unique blades).
thanks again to all and please keep following this thread and add to it when you feel a need.
peterpont
Old Dec 13, 2006, 12:37 AM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
<snip>
How about this one.
Tom Frank is online now Find More Posts by Tom Frank
Old Dec 13, 2006, 01:04 AM
Joined Jun 2006
Well, one possible advantage of the heli tail grips idea is that you could do variable pitch, which could save quite a bit of power getting enough thrust for takeoff.
So, I ran the numbers on a 5% Q400.
I assumed a 1.42m wingspan, 15.77dm^2 wing area, and 1950g all-up weight.
It seems if you use T-Rex 600 tail grips and blades to make 9.45x9 6-blade props, and you use something like a pair of Hyperion Z3025-12s direct drive on 3s2p 1800mAh lipo (or one 3s 1800 pack per motor, equivalently), you get a plausible model. It will probably need flaps, with a 13.1m/s (47kph, 29mph) stall speed clean, but it'll fly around for about half an hour at optimum cruise (4.5 minutes WOT), and top out at around 30m/s (108kph, or 67mph). Sounds nice to me.
However, variable pitch would be a big win; by going VP with a range from 6" to 13", you could probably ditch half the battery capacity, drop the stall speed to 12.5m/s, and at the same time increase the top speed by 20%... and still keep 22 minutes of duration. You'd also get the option of a bit of reverse pitch for braking, and even the ability to make the cool pitch-sweep sound big turboprops make as they do their taxi checks.
Convet 2-bladed prop to 3-bladed prop Steve_S Power Systems 3 Aug 05, 2002 08:44 PM
Single bladed prop? Redster High Performance 4 Feb 13, 2002 10:29 PM
Aeronaut 6.5x4 or 6.5 prop for Zagi 450T ? freq Foamies (Kits) 3 Oct 25, 2001 06:36 PM
Needed 2-bladed prop recommendation for Elfi setup. ajohnson Parkflyers 1 Sep 08, 2001 11:34 PM
