Old Sep 10, 2002, 03:08 PM
Mike Hall is offline
Find More Posts by Mike Hall
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
Check out this new design (NEW TO ME ANYHOW)
Check out my new plan i just built. The wing is made of 1/8" depron with black depron (paper still on) spar. The wing is very strong and very strait. The stabilizer is also 1/8" depron with black pepron spar. Here are the specs on the plane.
Wing span: 32"
Wing area: 270 sq "
weight: 11.6 oz ready to fly
Motor: GSW EPS 300 C with 10x4.7 prop.
I just took it out in my front yard took it off and landed it a few times and it seems to fly great. I will give a flight report later tonight.
Mike Hall is offline Find More Posts by Mike Hall
Old Sep 10, 2002, 03:09 PM
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
top view.
Old Sep 10, 2002, 03:10 PM
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
Side view.
Old Sep 10, 2002, 03:45 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Looks great!! Own design or a nock-off?
I was thinking about slapping something togeather like that for small eletric as I fly the glow .40 size fun flies and love them.
I'm guessing it doesn't hover?
rcav8r2 is offline Find More Posts by rcav8r2
Old Sep 10, 2002, 03:58 PM
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
well I got the idea from the AND NOW but its really nothing like it and i dont know of any other planes besides something like a tiny that looks like this one. As far has a hovering, I think with the right battery back it would. you can hold it strait up with full throttle and it wants to hover but not quite. This is with a small Nimh battery back and with a more powefull batter i think it might hover. I know this EPS 300 C should put out over 12 oz of thrust with the right combo.
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
pic of airfoil in stabilizer.
Old Sep 10, 2002, 04:45 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Cool.... Looks just like a Stickit from about 7 years back only your tail is shorter coupled, and the airfoil is a bit thinner to scale. I was just gonna scale down the Stickit
It was THE competition funfly in it's day.
Now you got me thinking about building that "someday" model.
Old Sep 10, 2002, 08:51 PM
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
Man does this plane fly good But its way underpowered. what is a more powerfull geared motor setup that will not weigh much more than the EPS 300? I also would like to use more powerfull batterys but i would like to keep them under 2.5 oz to keep the plane light. With its light weigh its very stable with power off and flys like a trainer untill you start to turn and it turns around in a snap. I have been having a hard time getting into inverted flight. Anyhow have tips on how to get inverted and keep it there. I have been trying to roll into inverted but this thing rolls so fast i cant stop it fast enough
Old Sep 10, 2002, 09:06 PM
soonerflyer is offline
Find More Posts by soonerflyer
I want that 1 this 1.....
soonerflyer's Avatar
OKLAHOMA
Joined Aug 2002
You could reduce youe control throws
BTW what are they at now?
soonerflyer is offline Find More Posts by soonerflyer
Old Sep 10, 2002, 09:11 PM
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
So just reduce the control through and it will roll much slower. I never thought of that. The contol throughs are about 1.5" each way. I like how it turns fast but It rolls so fast you cant stop it.
Old Sep 10, 2002, 09:35 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
If you have a computer radio you can also add some negative expo... Will tame it around nutral, but you can still give full stick for those blur rolls.
Speaking of control throw and plane reaction. If you have more than 45 degrees throw, you can actually cause the plane to react slower. Found this out on a fun fly some years back. 45 degrees was great so I though more would be better. Well the thing rolled and looped better at about 3/4 stick than it did at full stick. Put all throws back to 45 degrees, and it rolled and looped faster.
strange but true
Old Sep 11, 2002, 07:17 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Good looking And_Tiny_Now!
I agree, reduce the aileron throws to about 30 degrees for now, 45 degrees max, for the best roll rate. As far as inverted goes, try a 1/2 loop to get to it. If it requires too much down elevator, move the cg back and try again. With the symetrical airfoil, the inverted vs normal flight should require very little change in elevator. CG will likely be just a smidge behind the thickest part of the wing. Make sure your ailerons are in-line with the fuse for the most efficient flight. The 300 should be able to pull it, if it is trimmed right. Otherwise, a brushless would be the next step without adding weight. A 380/400 will require more battery, causing more weight, etc....
You didn't say what battery. You will likely want AAA's for decent current capability...
Gene Bond is offline Find More Posts by Gene Bond
Discussion Wow! -Check out this new P-38 Kit. mrebman Electric Warbirds 4 Apr 19, 2006 03:26 PM
Check out this new website - BLADEcpREPAIR.COM robmoll Micro Helis 11 Dec 08, 2005 07:29 PM
check out this new A-10 warthog mattk17 Parkflyers 15 Aug 26, 2003 09:44 AM
Check out this new twin EDF !!!! RookieOne Electric Ducted Fan Jet Talk 1 Mar 24, 2003 01:46 PM
Check out this new motor mount! Ben Diss Electric Plane Talk 2 Dec 16, 2001 10:41 AM
