Old Dec 10, 2006, 04:53 PM
mmartin55 is offline
Find More Posts by mmartin55
Joined Mar 2004
New Product
3.5 scale Piper PA-25 Pawnee
I am writing to inform you that we have completed plans and cut files for the Piper PA-25 Pawnee in 3.5 scale and are now cutting and shipping parts.
The list price for the laser cut partial kit with plans is $395.99 and includes the following:
WINGS
Hand-selected 1/8" Balsa wing rib set complete full ribs and "D" section partial ribs,
Birch Plywood 1/8" root ribs and wing strut mount hard point ribs,
Birch Plywood 1/8" servo mounting plates for both flaps and ailerons,
Birch Plywood 1/4" curved wing tip rib- and spar-notched formers,
Hand-selected 1/8" Balsa aileron/flap partial ribs,
Hand-selected aircraft quality Hardwood wing "D" section spars,
Hand-selected aircraft quality Hardwood wing main spars,
TAILS
Birch Plywood 1/4" curved fin and rudder, stab and elevator rib- and spar-notched formers,
Hand-selected aircraft quality fin, rudder, stab and elevator spars,
Birch Plywood 1/8" rudder and elevetor acutator horn location plates,
FUSELAGE
Hand-selected Balsa turtledeck and foredeck bulkhead and cockpit/canopy formers,
Birch Plywood 1/4" and 1/8" main fuselage bulkheads and firewall doubler,
Birch Plywood 1/8" fuselage side wing root doublers,
Birch Plywood 1/8" fuel tank and landing gear mount box,
Birch Plywood 1/8" forward fuselage main side formers,
Birch Plywood 1/16" thick fuselage lower hatch and framing doublers,
Birch Plywood 1/8" empenage servo mounting panel,
Birch Plywood 1/8" servo mounting trays, rudder and elevator,
Birch Plywood 3/16" scale tailwheel mounting plate,
PLANS
2 sheets, 36" x 75" with complete assembly drawings of fuselage, both wings and tails,
Detail for shop-made elevator horn,
Detail for removable wing strut fabricatioin and mounting,
Detail for jury strut fabrication and mounting,
Detail for scale landing and navigation light fabrication and construction,
Detail for removable wing/spar fabrication,
Scale prop and spinner diameters and thrust line,
Scale landing gear wire profiles and bending patterns,
Scale engine cowling and wing strut fairing profiles and patterns,
And the TMRC logo!
SPECS
Wingspan: 123" (3.1meter)
Length (rudder to spinner): 84" (213cm)
Height (at tail)" 23" (58cm)
Width (at stab): 34" (86cm)
All Up Weight: 25 lbs. (11.33kg)
Engine disp: 100cc
These will be made in limited numbers and at present we do not offer formed plastic parts. In the case of the engine cowling, only the front bowl would need to be shaped from balsa or laid up, while the access panels and lower surfaces may be flat wrapped with 1/32" plywood or glass sheet over a wood form and built to have a removable upper section for engine access and installation or service. We are also looking into fabricating a plug for the cowling to have a commerically available unit based upon the response to this mail in large part.
Please let me know if I should add yours to the cut list for this month and have a very safe and Merry Christmas and Happy New Year!
Tom
mmartin55 is offline Find More Posts by mmartin55
Old Dec 11, 2006, 12:44 AM
wiz310 is offline
Find More Posts by wiz310
In love with my Rappy
Leonora, Western oz.
Joined Mar 2006
AAAAAAARRRRRGGGH, why would you do this to me after I just went through all the grief of enlarging my existing plans and buying material?.
I might offer my cowl plug to you for a tidy sum though.
will also be making airfoil struts (aluminum) and strut fairings plugs.
Dammit. you should have posted a week ago and I would have bought from you.
wiz310 is offline Find More Posts by wiz310
Old Dec 11, 2006, 01:01 AM
Joined Mar 2004
Sorry man. I've been posting about it coming down the pike for about six months. Need I find and show you the threads? I would be interested if you have 28% scale glass parts tooling that will fit ours perfectly. I can send you a set of drawings for the engine cowl, and left and right hand wing strut fairings. Are you making a canopy plug complete with raised door frames?
Tom
Old Dec 11, 2006, 01:43 AM
wiz310 is offline
Joined Mar 2006
No, my plans are actually built up balsa cabin area with plastic windscreen, windows fitted into lite ply frames. (the doors open on both sides).The roof is sculpted balsa as well.
if you send me a template of your firewall and fairings , I will measure it up against my plans and let you know about the glass cowl and fairing plugs. After weighing my struts and the gear to make the aluminium struts, the aluminium ones win by quite a bit, as well as being structurally stronger.
Cheers, Wiz.
Old Dec 11, 2006, 08:26 AM
Joined Mar 2004
Same plans it looks. Mine are redrawn from the Dick Graham plans at quarter scale and then also enlarged and redrawn at 3.5 and 2.5 scales. Parts are available for all in laser cut short kits with machined hardwood for spars in wings and tails.
Tom
Cool TMRC Quarter Scale PA-25 Pawnee Kit Release mmartin55 Scale Sailplanes 20 Feb 07, 2006 04:45 AM
FS : 1:3.5 scale DFS Habicht kit MTT Aircraft - Sailplanes (FS/W) 1 Mar 07, 2005 07:46 PM
FS: New EZ Laser 200 - Bud Light 1/3.5 scale Keitha Aircraft - Fuel - Airplanes (FS/W) 7 Jan 29, 2004 11:34 AM
Sig 1/5 scale Piper Cub Michael in Toronto Scale Kit/Scratch Built 5 Oct 04, 2002 11:30 AM
