Old Dec 09, 2006, 01:55 PM
sharkovios is offline
Find More Posts by sharkovios
Athens, Greece
Joined Feb 2005
Help!
Something Broke in my 4-in-1 (c28)
Hi,
there is a rectangular component in my 4-in-1 that says "C28" (just above the Crystal.
Does anyone know what this is cause it's broken after a fall
and i can't find it anywhere?
TIA,
Antonis
P.S. My 4-in-1 is of E-sky's Lama 2 V3
sharkovios is offline Find More Posts by sharkovios
Old Dec 09, 2006, 02:31 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
If they used typical circuit board labeling... that would be a capacitor.
You can't just guess about the "value" of the capacitor to replace it... A wide range of capacitors can be the same size. hopefully there is enough left of the old one to read the value off of it. It should have some number followed by uf or pf.
If you can take a pic of the board, pointing out the broken part, someone with the same 4-in-1 could read it off of thiers.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Dec 10, 2006, 05:00 AM
Hell-e-Guy is offline
Find More Posts by Hell-e-Guy
Joined Jan 2006
I fixed a whole bunch of e-sky 4 in 1 for a local shop.
I don't remember the marking but it's probably the resonator or the discriminator.
If it has 2 leads it's the discriminator.
Hell-e
Hell-e-Guy is offline Find More Posts by Hell-e-Guy
Old Dec 10, 2006, 05:56 AM
Athens, Greece
Joined Feb 2005
Hi,
Thanks For the replies. Below I have some photos which will be a bit more explaining.
On the PCB it says "CF2", maybe a ceramic filter? i don't know..
Any info will be appreciated.
Antonis
Old Dec 10, 2006, 10:14 AM
dleroi is offline
Find More Posts by dleroi
Don L.
Old Lyme, Connecticut
Joined Feb 2006
Originally Posted by sharkovios
Hi,
Antonis
It looks like a lead sticking down on the left side in the picture - is it a through hole device? If so, is there enough of the other lead left to solder a wire on? If so, you could just solder on a wire, put a glob of epoxy over the connection, and re-use it.
- Don
dleroi is offline Find More Posts by dleroi
Old Dec 10, 2006, 11:23 AM
Athens, Greece
Joined Feb 2005
Don Hi,
I tried That too but it's completely torn out..
Thanks Anyway
Antonis
Old Dec 10, 2006, 04:10 PM
dleroi is offline
Don L.
Joined Feb 2006
Don Hi,
Thanks Anyway
Antonis
Antonis,
OK, well for what it's worth, I think its a 455KHZ ceramic discriminator. They are used in many rc devices and rc toys. Here's a link:
http://www.xenon-tech.com/index_epro...products_id=38
I have one that you're welcome to. If you want it, PM your address and I'll get it in the mail.
- Don
Old Dec 11, 2006, 08:06 AM
Athens, Greece
Joined Feb 2005
Dleroi,
Thanks you've been a great help..
I'll check first in my local shop and if i can't find it i'll pm you.
Thanks Again.
Antonis
Help! Is my 4 in 1 going south? Steppenwolf Coaxial Helicopters 3 Jul 15, 2007 06:29 AM
Discussion My 4 in 1 is toast but atleast i have something else to fly! STi489 Coaxial Helicopters 6 Feb 24, 2007 11:11 PM
Question How do i modify my 4 in 1 receiver? omloro DIY Electronics 3 Jan 22, 2007 01:09 PM
Question Pet project:How do i modify my 4 in 1 receiver? or do i need to? omloro Modeling Science 1 Jan 22, 2007 11:10 AM
Discussion did i fry something in my 4-in-1 on my BCX? heligrom Coaxial Helicopters 4 Feb 13, 2006 09:43 AM
