Old Sep 13, 2002, 05:19 PM
alex_parkflyer is offline
Find More Posts by alex_parkflyer
Berlin, Germany
Joined Aug 2002
Thanks Jochen! So used a 5gram receiver/ or finally came out with it! Hm, I'll think about that! Thanks anyway!
Alex
PS: Where in Germany do you live?? As you sure have read, I live in Berlin.
alex_parkflyer is offline Find More Posts by alex_parkflyer
Old Sep 13, 2002, 11:11 PM
rallen is offline
Find More Posts by rallen
Melbourne City Hlpt, Australia
Joined Dec 2001
Alex,
You could also look at Rick Ruijsinks MicroMag www.micromag.com it is a bit more expensive,but is excellent and is available on 35 Mhz
Robert
rallen is offline Find More Posts by rallen
Old Sep 14, 2002, 12:49 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Well I've learned a few things about building this airplane. DON'T use midwest balsa, it's WEIGH (spelled correctly) to heavy. I tried using it after building most of the plane with Sig contest balsa. Well basically, I can forget the Midwest balsa, it is about 5 times heavier than the Sig. Also DNA was quite right, the acrylic paint that is 44 cents at walmart works wonders. That's some great stuff for little or close to nothing, and it looks great on balsa. Well I'm now waiting on some more contest balsa, after that I'll post pics of my progress. I'm loving this little wonder. If it flies 1/2 as well as it looks, I'll be exstatic.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Sep 14, 2002, 04:09 AM
Berlin, Germany
Joined Aug 2002
Hi Robert! Thanks for the hint, but when I click on the link, it says: "No web site is configured at this address." So I tried it with ...... .net but then it shows a french site about computers. What is the right link?? Is it an Australian site??
Alex
Old Sep 14, 2002, 09:33 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
The Micromag site is http://www.ruijsink.nl
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Sep 14, 2002, 03:20 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I don't think you can buy the Micromag currently.
Fantastic model!!!!!
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Sep 14, 2002, 08:18 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
For some reason, I can't open the file.
Does anyone else have this problem, or can tell me how?
Chuck
Chuck is offline Find More Posts by Chuck
Old Sep 14, 2002, 10:40 PM
Chris3D is offline
Find More Posts by Chris3D
Chris3D's Avatar
Joined Apr 2001
I just tried it and it opens fine. You need the free Adobe Acrobat reader program, available here:
http://www.adobe.com/products/acrobat/readstep2.html
Let me know if you continue to have trouble.
Chris3D is offline Find More Posts by Chris3D
Old Sep 14, 2002, 10:43 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
OK, I got it. This is great. Thanks, Chris.
Chuck
Old Sep 14, 2002, 11:14 PM
harryo is offline
Find More Posts by harryo
Mmmm... crunchy balsa.
harryo's Avatar
United States, CA, Oakland
Joined Sep 2002
Thank you so much Chris... for all of your time and effort.
I was wondering if you had any other file formats of the drawings. I would love to try and build a 280 sized Pitts. I can read just about any vector-based file type. (dxf, dwg, cdr, ai, 3ds, wmf, etc... )
Okay, the reason is this... I dont have the tiny equipment needed to fly it. Chris did such as amazing job on this plane, that I want to try a parkflyer sized version.
P.S.: Oh yeah, I almost forgot. I'm not sure if this is a common practice these days, but... It's very nice to be able to print the parts outlines with their detail lines on the laser printer. Then, just fire up your iron and set the heat to high and you can "iron-on" the crisp black outlines directly from the plans onto the balsa. The toner from laser printers is heat activated and will transfer quite easliy. You can then cut the shapes away with you #11 blade and airbrush/dye your second pigment on. This iron on technique works incredibly well, and even better if you print with a slightly higher than normal density on your printer. If you don't have access to a laser printer, don't fret. Most photo copiers use this type of toner too. I'm sure your local copy center would appreciate your patronage.
thanks,
-=h=-
harryo is offline Find More Posts by harryo
Old Sep 15, 2002, 02:45 AM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Originally posted by alex_parkflyer
[PS: Where in Germany do you live?? As you sure have read, I live in Berlin. [/B]
Near Bielefeld.
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Sep 15, 2002, 06:57 PM
Boston, Mass
Joined May 2001
You might check out this Pitts Post on the RC Microflight BB.
Gordon
Old Sep 16, 2002, 12:17 AM
cactus is offline
Find More Posts by cactus
Micro Fpv=BVLOS around couch
United States, CO, Durango
Joined Sep 2001
Thanks Chris! I started mine today....
http://www.rcgroups.com/forums/showt...threadid=61785
cactus is offline Find More Posts by cactus
Old Sep 16, 2002, 01:52 PM
D W is offline
D W
Find More Posts by D W
D W
I love you man.
D W's Avatar
United States, NY, Pelham
Joined Sep 2002
Gotta thank all here for discussion re: "painting" model with dyes and/or food coloring. Have been thinking of gettin Roadkill P-38 but turned off by use of markers to color model (see Backyard Flyer -Winter 2002, YUK!!!). Now can't wait to find some documentation to see what could be done.
Are there any problems with the dyes 'bleeding' and how do you manage such crisp lines on the Pitts?
A truly fantastic model that Pitts and def. now on my to do list, even if like some she never gets her innards and just graces my 'hanger'.
Thanks .
D W is offline Find More Posts by D W
Old Sep 16, 2002, 02:45 PM
Berlin, Germany
Joined Aug 2002
Hey Dan, I've got to ask you something what I think is important: Are the pitts kits going to have additional aileron wings and stuff like shown in Chris's plans? I really want to build the aileron one, when the kits become available, or even think about building two, one with and one without ailerons! So when the kits come out, please tell me (I'll take at least a Pitts and a Moth) - so I think I should start saving my pocket money for that!
Hm, somehow it seems that Chris wasn't here for some days! Hopefully he's working on his next model..... Hope...hope...hope... (I really hope it's a German bipe!!! )
Alex
Free plans are going away AerodromeRC Scale Kit/Scratch Built 65 Oct 01, 2002 11:39 PM
G10 Frames for the Piccolo are here! Mario Electric Heli Talk 32 Aug 07, 2002 10:01 PM
My CP 8 x 1700's are here. (Yeah!!!) hmhoshi Electric Sailplanes 16 Oct 31, 2001 05:10 PM
Slim Gyms are here! (NSP) sal Parkflyers 13 Apr 26, 2001 05:55 PM
Sanyo CP-1300SCR are here! Ralph Weaver Electric Plane Talk 8 Apr 24, 2001 10:18 PM
