Espritmodel.com Heli Air
Old Apr 12, 2004, 12:03 AM
New Zealand
Joined Feb 2003
To warren and those who scale up the micropitts:
I am very interested in your effort to scale up the micropitt. Like many I found the RFFS system a bit too steep and I have lots of pico servos / micro rx lying around which i would like to use. I have a few questions:
1. By scaling it up 75% you mean 1.75x of original right?
2. Do you have to use thicker balsa since the scale is now different?
3. How do you mount the GWS IPS unit to the plane? Any pics?
Thanks for your suggestions
Henry
dimple is offline Find More Posts by dimple
Old Apr 13, 2004, 03:39 AM
King of my own little world...
Brian Freer's Avatar
New Paltz, Ny
Joined Jan 2004
I've got a crazy idea: I'm thinking of stuffing some standard micro gear (15g worth) and a DD dcm 189 motor set up in the little pitts. I'll be ending up at about 4.5 oz auw with about 5.5 oz thrust. Think it'll work?
-Brian
Brian Freer is offline Find More Posts by Brian Freer
Old Apr 13, 2004, 07:21 AM
Gravity is a harsh mistress.
Tim Wolff's Avatar
Lambertville, Michigan, United States
Joined Sep 2002
-Brian
Sounds like a guided missle
Tim Wolff is offline Find More Posts by Tim Wolff
Old Apr 13, 2004, 08:38 AM
New Paltz, Ny
Joined Jan 2004
Prescisely!
Old Apr 13, 2004, 04:28 PM
AllAloneInSpaceAndTime
The Enemy's Avatar
Canada, ON, Guelph
Joined Apr 2003
Brian,
I like your idea too. I printed out the plans for it, but am having a little trouble scaling them up. I need a photocopier...
1.75% sounds about right.
What prop do you plan on using, and what material for the airframe? I've been having pretty good results with a 4.5x4. But have no exact thrust measurements on it with the J250.
TTYL
Corey
The Enemy is offline Find More Posts by The Enemy
Old Apr 16, 2004, 03:47 PM
Worcester, MA
Joined Oct 2003
Does this style of construction have a name? Chris3D's planes work well for 2x enlargment. I would like to see some warbirds done with this method. I may attempt one myself in the future.
Do you design the plane in 3D in CAD and then unroll it to a flat plane for templates?
nismo240
nismo240 is offline Find More Posts by nismo240
Old Apr 16, 2004, 10:35 PM
New Paltz, Ny
Joined Jan 2004
Corey:
I haven't decided on a power system yet, but I think I might put a J250 in an EPS 100 gearbox (6:1) which should yeild pretty good thrust results. As for the scaling and materials, I went too my local copy center and had them blow up the plans to 175% which cost me like $1.75. Since duplication of balsa exactly to proportion whith the plan enlargments isn't possible (can't buy 1.75/32 balsa sheet) I just doubled all the thicknesses (I'm using 1/16 balsa for the sheeting, 1/8 basswood for the cowl since it's a bit more durable, and 1/4 balsa for the wheel pants and wheels). It should end up a bit fat but that shouldn't matter since it's going to be ridiculously overpowered anyway .
I am having a little trouble deciding how to color it though, I wanted to stain it originaly, but the stain just doesn't look too hot on balsa, so I think I might just try the fabric dye.
-Brian
Old Apr 16, 2004, 10:39 PM
I Just Need This One Part
Jchas26's Avatar
Cartersville, Georgia
Joined Jun 2002
Here is one I did a while back. Man I love this plane. Runs On A GWS Dual Drive IPS. And 8 NIMH. Pretty Much just scaled up the micro Pitts with minor mods to the LG and battery hatch. It is all peeled sturdy board with clear vinyl laminate. Yeah that is a real pic of it hanging on the prop too.
Jchas26 is offline Find More Posts by Jchas26
Old Apr 16, 2004, 11:31 PM
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
I have been planning on doing a J250 version of both the Pitts and the Moth from Chris Riley. I am running into roadblocks with DepronUSA and FoamFly.com... They don't return my emails...
Trikster is offline Find More Posts by Trikster
Old Apr 17, 2004, 09:51 PM
New Paltz, Ny
Joined Jan 2004
Dan (www.foamfly.com) is a VERY busy guy, always halfway across the country somewhere or other. Just be persistent, try sending him some pm's and he'll respond eventually.
-Brian
Old Apr 19, 2004, 06:55 PM
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
Pierre, I went to a profile Pitts too, but smaller than Chris´Pitts, mine is 11" WS and weigh is 25 gms. is the smaller RC plane in Mexico!!!!!! I confirmed it is the JMP red one, the smaller is a plastic model 1:72 scale in the old Brian lecombr´s Pitts from England.
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Old May 12, 2004, 09:57 PM
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
finished my lazer cut kit.
I left it unpainted to see what the weight would be.
27 g RTF + 5 g weight to achieve CG
Thanks Chris
frankenfoamy is offline Find More Posts by frankenfoamy
Old May 12, 2004, 10:21 PM
Zoom, zoom...
Trikster's Avatar
Joined May 2003
Looks real good. Is this the DWE kit?
Old May 12, 2004, 10:37 PM
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Ouch! Nose weight! That's why I like the remote actuators...
You could run the the next larger size LiPoly cell and make some of that weight do some good... You get a little more power (or so it seems).
Mike Taylor is offline Find More Posts by Mike Taylor
Old May 12, 2004, 11:24 PM
Moderador.
Joined Sep 2002
Nice plane...as the Pitts must to be Please tell us your flight experience.
Cheers
Alfredo Rubio
Free plans are going away Bengtson Scale Electric Planes 65 Oct 01, 2002 10:39 PM
G10 Frames for the Piccolo are here! Mario Electric Heli Talk 32 Aug 07, 2002 09:01 PM
My CP 8 x 1700's are here. (Yeah!!!) hmhoshi Electric Sailplanes 16 Oct 31, 2001 04:10 PM
Slim Gyms are here! (NSP) sal Parkflyers 13 Apr 26, 2001 04:55 PM
Sanyo CP-1300SCR are here! Ralph Weaver Electric Plane Talk 8 Apr 24, 2001 09:18 PM
