Old Dec 07, 2006, 01:28 AM
alfabeta is offline
Find More Posts by alfabeta
East coast, Australia
Joined Jun 2005
Which EPP park flyer query???
Hi,
I would like to get into smaller flying R/C.
Currently I have a larger scale delta wing pusher, but would like to move to smaller planes.: ie 20-40cm.
After surfing the forum I bought the Silverlit X-twin Sports which has been fun, but I would like to have little more control over the plane.
The type of setup I would like in the plane is:
- small single brushless prop (pull or push),
- EPP constructed plane (similar to the “x-twin sports”)with the delta wing or traditional rudder setup?
- Appropriate Li-po and speed controller
Is there a model out there?
Cheers
Alf
alfabeta is offline Find More Posts by alfabeta
Old Dec 07, 2006, 03:01 AM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I just maidened a small EPP Boomer (pusher) in 10mph winds, gusting.
Its a 2.5ozs flying weight, 18.5" wing, LPS motor and 210mah lipo. Its a semi copy of it big brother the Wild-Cat boomer, a 31" wing, 6.5oz Boomer.
Its easy to build, using a EPP pocket wing cores.
Butch
Butch777 is offline Find More Posts by Butch777
Old Dec 07, 2006, 09:07 AM
IWC is offline
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
hobby lobby Gull (I have zero experience with this plane)
IWC is offline Find More Posts by IWC
Old Dec 07, 2006, 04:44 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
There are a few 'pocket' flying wings, but they tend to be fairly fast.
Why do you want to go that small? Once you go under about 7oz and 24" span it gets quite hard to build something with standard gear, and it gets knocked around by light winds (compared to a larger version) so it's normally only of interest to indoor fliers.
RobinBennett is offline Find More Posts by RobinBennett
Old Dec 18, 2006, 07:13 AM
alfabeta is offline
Joined Jun 2005
Hi Robin,
Thanks for your reply, I was hoping to get into something that small as a 900mah (or smaller) pack is less expensive than a 2100mah pack. Unfortunatly money for modelling is not as abundant as it was 12 months ago.
I also liked the idea of a smaller plane to fly in the park near my home (early in the morning to avoid wind).
Old Dec 18, 2006, 07:43 AM
alfabeta is offline
Joined Jun 2005
Butch
Hi Butch,
I would like to find out more about your EPP Boomer. Where do you get your EPP Pocket wing cores from?
Old Dec 18, 2006, 12:35 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
There are several EPP flying wing suppliers. What size Boomer did you want?
Also what power system, batt and how windy is it when you fly.
I took out the pocket Boomer yesterday after Church and the wind was gusting a bit over 10mph. I had no problems flying the 2.5oz Pocket-Cat Boomer. Butch
Old Dec 18, 2006, 02:01 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
You may consider the Wild-Cat, or a simular size Boomer. I have several in the 30" range, about 6-7ozs, that fly in the street and bounce off trees, poles and cars, etc. I have a lot of the cores and parts to build them, Butch
http://www.rcgroups.com/forums/showthread.php?t=586942
Old Dec 18, 2006, 02:40 PM
Sussex, UK
Joined Jun 2004
That size battery would be suitable for a 30" wing - a 18" wing would use a 2s300mAh (which isn't any cheaper).
I've just build a 32" wing for a 2s1100 and cdrom motor for a friend who is learning ailerons - it flies fast enough to handle 15mph winds but slow enough to fly in a football field, gentle enough for learning but powerful enough for loops and rolling circles. This was the cheapest power system I could find.
Butch's Boomers look like a good mod to a standard wing, but I would still suggest you would do better with cheap motor and battery on a 30" wing than overloading a small wing with the same power system.
Old Dec 18, 2006, 04:27 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Your right Robin, a 900mah batt is large for a small plane. The Beginners Wild-Cat Boomer I have is a 31" IPS powered. It flys on a 3 cell 340mah batt and will fly at 50% power. At 75% power it will fly for over 20 minutes. It can be flown in the wind(if you have quick thumbs) and it can be flown indoors, like in half a basket ball court. I fly in in a small street. Butch
Discussion EPP Cutlass Park Flyer tomcor Foamies (Scratchbuilt) 443 May 10, 2015 03:13 PM
Video EPP Cutlass Park Flyer tomcor Electric Plane Talk 2 Jun 23, 2008 04:58 PM
Which park flyer for my son. brewer65 Parkflyers 16 Mar 03, 2004 07:32 AM
Which wing for e park flyer and sloper? duganderson Foamies (Kits) 5 Apr 12, 2003 07:43 PM
Which park flyer is recommended for newbie? gixxer Parkflyers 45 Feb 28, 2003 07:29 AM
