Old Dec 06, 2006, 08:43 PM
wrangler is offline
Find More Posts by wrangler
Joined Nov 2006
Help me build GWS pico tiger moth or bigger 400 tiger moth
Ok there's got to be a easy way on the cheap to get one in the air. Could i install cheap china servos,receivers,crystals,radio $19. Ive seen these fly and looks way easy than my FD beginings.
wrangler is offline Find More Posts by wrangler
Old Dec 06, 2006, 10:48 PM
U2Steve is offline
Find More Posts by U2Steve
Now with more COWBELL!
U2Steve's Avatar
United States, KY, Lexington
Joined Mar 2001
If you buy cheap gear and it fails, you'll have to buy a new plane as well as new gear. Where's the savings?
At the least, save up and get GWS's radio gear. It's some of the least expensive around anyway, but I've bought a ton and it all works when it's used appropriately.
U2Steve is offline Find More Posts by U2Steve
Old Dec 06, 2006, 11:28 PM
GD5015 is offline
Find More Posts by GD5015
Watch out for that TREE!
Houston, Tx
Joined Oct 2006
Wrangler, the TM 400 is a 4 channel plane. Not sure I would recommend it after your first experience. You can spend as much or as little as you want, but if you continue on with RC flying, having equipment the will move up with your next plane(s) is cost effective. There are a lot of RTF pkgs. out there that use cheap components and they fly well. I think you would be better served to start with an Easystar RTF, apparently they are very durable and easy to fly. It is a pusher prop so, breaking props. is one less thing to worry about. Shop a bit and you can find one on sale for a bit over $150. It is a complete kit.
http://www2.towerhobbies.com/cgi-bin...p?&I=LXFXV0&P=
And don't forget to use the $15 off coupon.
GD5015 is offline Find More Posts by GD5015
NIB GWS Pico Tiger Moth Justin Jackson Aircraft - Electric - Airplanes (FS/W) 7 Jul 13, 2004 12:58 AM
Ready to fly GWS Pico Tiger Moth, White, Brushless Trikster Aircraft - Electric - Airplanes (FS/W) 6 Jul 05, 2004 12:21 AM
gws pico tiger moth w/350 c? BLAZE242 Parkflyers 1 Jun 08, 2004 01:08 AM
the "NEW" GWS PICO Tiger Moth "3D"....? omni99 Parkflyers 3 Apr 14, 2004 08:04 PM
Help me with CG of Protech Tiger Moth! icebear Parkflyers 25 Sep 03, 2003 10:23 AM
