Old Dec 06, 2006, 08:24 PM
XarvoX is offline
Find More Posts by XarvoX
smaland, sweden
Joined Dec 2005
using ccpm mix on tail rudder surface on airplane?
The basic idea: using 120° angled tailplane surfaces mixed with ccpm mixer for elevator and rudder, but also to control aileron.
if you take a look at the tail on the F-4 Phantom you should get the idea
Ive been planning a long-term balsa project, and would like something technicly different..
i figured i could try a 3-wing zagi prehaps or some sort of canard-type craft, but the basic functionality has to be at least ok..
it could also be extended to a X-wing ie the famous starfighter
So i wonder, has anybody done something like this previously?
the mixing shouldnt be a problem, just got a futaba 9c.
but how are the flight-tendencies?
i will be building from scratch for the first time, so any helpful links/hints/suggestions would be great
Just got a Futaba 9C and a dedicated hobby-room with huge build-potential and i just MUST use it
XarvoX is offline Find More Posts by XarvoX
Old Dec 06, 2006, 09:49 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
CCPM involves 3 servos.. there's aileron, elevator, and throttle.
Moving the throttle moves the aileron and elevator at the -same- time.
You're better off using rudder-vator mixing for the horizontal, with aileron seperate.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 07, 2006, 05:37 AM
yoyoML is offline
Find More Posts by yoyoML
Taipei Shek, Taiwan
Joined Aug 2004
3-wing Zagi? You mean Lambda Shuttle, don't you? Give me a B-Wing, too!!!
yoyoML is offline Find More Posts by yoyoML
Old Dec 07, 2006, 06:35 AM
XarvoX is offline
smaland, sweden
Joined Dec 2005
with normal pitch-ajustment on standard ccpm, every servo goes the same direction.
Meaning, if you mount 3 servos for 3 surfaces and change pitch, you get aileron (screwing)
but since i dont want to change pitch with throttle-stick, i will still have to make my own mixers.
what im thinking of is a fully articulated flight behaviour with only 3 rudder surfaces, witch i think is the smaller of problems compaired to the tx mix..
and sparky, have a look at the align trex with ccpm, there´s 3 servos for cyclic plus throttle.. (left/right aileron+elevator)
Old Dec 07, 2006, 10:48 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
Here's another unconventional airplane.
This is Tim's "Thing"... Cute but...
I can see using a CCPM transmitter on a vee-tail or elevon -glider-.. no motor.
I've set one up just to see if it would work.
The collective mixing screws things up.
Old Dec 07, 2006, 11:41 AM
Ledbetter is offline
Find More Posts by Ledbetter
Central California
Joined Aug 2003
It's 4 channels isn't it?
Throttle, pitch, roll and elevator.
You could make that work using pitch to control main wing reflex, for example.
Ledbetter is offline Find More Posts by Ledbetter
Old Dec 07, 2006, 12:18 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Throttle and pitch on one stick.. the collective, in helicopter parlance.
Any movement of the collective moves the aileron (lateral cyclic) and elevator (pitch cyclic) in one direction at the same time in a CCPM system.
Moving the cyclic would move the elevons/ruddervators as well.
That's why I specified a glider. 2 channels.
Rudder (pedal) changes the tail rotor speed for yawing.
Old Dec 07, 2006, 12:50 PM
XarvoX is offline
smaland, sweden
Joined Dec 2005
im sorry if im not clear enough in my description, i dont intend to use a stock ccpm mix, but to emulate one with a few free mixes. the result will move the Y-shaped tail-surfaces in much same fasion as a eccpm swashplate.
the idea is to attatch the servos in the same way on all surfaces so when all servos push/pull, i get aileron effect, when two move up/down i get elevator, and when 3 working together forms rudder.
i hope this straightens your questionmarks
the Lambda Shuttle seems like a good candidate
Question Twister cp v2 TAIL BOOM MOTOR ONLY WORKS ON RIGHT RUDDER??? Nipperdog Electric Heli Talk 2 May 24, 2006 05:23 AM
Is it normal to have to constantly retrim tail (rudder) on an FP Micro (esky)? Johnny B Micro Helis 11 Nov 07, 2005 03:00 PM
Update on the fully CNC tail rudder system for ZOOM -mH Mini Helis 18 Nov 27, 2004 08:21 PM
Question how to adjust rudder surface throw on superstar ep md2b1dy Beginner Training Area (Aircraft-Electric) 8 Jan 12, 2004 10:01 AM
Why rudder/elevator on two servos? Fred Bronk Electric Plane Talk 30 May 15, 2001 01:56 AM
