Old Apr 16, 2007, 03:20 PM
Rob Hair is offline
Find More Posts by Rob Hair
Michigan
Joined Apr 2001
jimras:
You are smart to be careful about over discharging your batteries and your method is a good one. You may be aware that most of the more sophisticated (and more expensive) transmitters include a count down time for this purpose. Do remember that the voltage under load will be lower than the voltage that you measure after you land.
Rob Hair is offline Find More Posts by Rob Hair
Old Apr 16, 2007, 11:58 PM
jimras is offline
Find More Posts by jimras
West-Central Wisconsin
Joined Mar 2007
Rob--
Yes, I know that voltage under load is lower than voltage "at rest"
And, the transmitter that came with the CX2 doesn't have any kind of
timer built into it so that's why I use my watch.
That's why I stop at 10 minutes with this heli
I find that the packs are down to about 7.4 or 7.3 at rest and I think that's probably a safe level to discharge to.
I have three packs so I don't have to squeak every minute out of the pack to fly.
Better to be safe and have the battery last longer, too.
jim
jimras is offline Find More Posts by jimras
Old Apr 17, 2007, 12:33 AM
Butters is offline
Find More Posts by Butters
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Can someone please point me in the direction of the blade mod where once done they fold?
thanks.
Butters is offline Find More Posts by Butters
Old Apr 17, 2007, 02:02 AM
Numb Thumbs is online now
Find More Posts by Numb Thumbs
Does it come in Flouro??
Numb Thumbs's Avatar
Melbourne, Australia
Joined Sep 2004
Xtreme Motors
I just installed the Xtreme "Stock 180" motors in my Blade CX2.
Must say I was very disappointed! Chopper seemed sluggish and kept turning clockwise, even with full left trim. Before the upgrade it flew well. Is there anything I could have stuffed up??
The upper blades seemed to rotate much slower than the lower ones.
Help!
Cheers
Numb Thumbs
Numb Thumbs is online now Find More Posts by Numb Thumbs
Old Apr 17, 2007, 06:13 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
Hummm? My Extreme motors were fine. No problems. Much more Quiet. Haven't flown it enough to know if I get longer flights yet.
Maybe the upper blade motor is a dud. Maybe the pinion is not contacting the gear the right way. Bearings OK?
Double check everything since you lut it back together.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Apr 17, 2007, 09:11 AM
Blackjack52 is offline
Find More Posts by Blackjack52
38.4mph 12cell SV27
Blackjack52's Avatar
Madison, AL
Joined Sep 2006
First thing I'd check would be the gap b/w pinion/gear.
Blackjack52 is offline Find More Posts by Blackjack52
Old Apr 17, 2007, 10:05 AM
mobius879 is offline
Find More Posts by mobius879
Edgewater
Joined Mar 2007
Help!
Cheers
Numb Thumbs
Xtreme "Stock 180" motors were installed just 2 days ago, and I experienced the same as Numb Thumbs. The heli now doesnt have the quick power response Im used to using when flaring for a landing. And contrary to other posts, I find that these motors run rather hot.
Durning My second flight on these motors, I found them to perform slightly better. They may need to be broken in. Im curious if there would be a performance improvement when the silver brushes are installed in place of the stock copper brushes. Has anyone flown the Xtreme Stock 180's on silver brushes?
mobius879 is offline Find More Posts by mobius879
Old Apr 17, 2007, 10:26 AM
yzfr6drw is offline
Find More Posts by yzfr6drw
Joined Feb 2007
Installed the motors a while back, defintely longer flight times, the motors gets hot, but the battery doesn't seem to get as hot. It did take some time for the motors to get run in and it's less noisy now, but it's still louder than the stock motors.
yzfr6drw is offline Find More Posts by yzfr6drw
Old Apr 17, 2007, 10:36 AM
Rob Hair is offline
Michigan
Joined Apr 2001
I'd make sure there is no mechanical binding or other similar problem (did you remove the screws for the lower hub or press the lower main gear too tightly against the upper main gear?)
If you are sure all is right mechanically, you may have a bad motor. These motors should, and on my CX2, do work very nicely. I'm not sure its necessary, but I did break in the brushes by running the motors no load with about 1 to 2 volts applied for a half hour. This was standard procedure in the past with brushed motors - whether it was really needed or not I'm not sure.
Old Apr 17, 2007, 12:58 PM
38.4mph 12cell SV27
Madison, AL
Joined Sep 2006
Just some helpful info on Brushed Motor break-in.
http://www.rcuniverse.com/forum/m_5628228/tm.htm
Old Apr 17, 2007, 01:26 PM
Edgewater
Joined Mar 2007
Brushed Motor Break In
After reading Blackjack's link to "Brushed Motor break-in", I can now understand why my first flight on the Extreme 180 Motors was not what I expected. Its logical, the brushes were new and had not been "formed" to the round shape of the commutator, resulting in less-than-optimal electrical contact.
Ive had 4 flights on these motors, and can confirm that the throttle response is indeed improving with each flight.
On another note, did anyone else installing these motors have problems with the canopy? It seems that the connectors on the harnessess are much longer than the stock motor connectors, and is now in contact with the canopy. I cant center the canopy.
Old Apr 17, 2007, 02:38 PM
Butters is offline
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Can't you remove the stock wires from the stock motor and solder them to the new motors?
Old Apr 17, 2007, 02:41 PM
Butters is offline
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Never mind about my request earlier about the blade mod.
I went ahead and purchased the aluminum upper and lower blade holders with blades that will fold.
I also purchsed the rest of the aluminum needed to complete the job. I only want to take the heli apart once, I even have the Vortex motors waiting for install!
Pics to come.
Old Apr 17, 2007, 03:20 PM
yzfr6drw is offline
Joined Feb 2007
mobius, i just bend them carefully. The Canopy is centered on mine after I bend the wires.
Old Apr 17, 2007, 10:35 PM
Joined Mar 2007
Pics to come.
Good luck on those blade holders. Allot of people have had bad luck with those & the CX2. If it works well & you have no problems then your next purchase should be Extreme Blades.
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 10, 2009 12:01 AM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 08:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 10:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 02:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 01:59 PM
