![]() When I read what you said about an electrical noise, I too thought of a servo twitching. |
Latest blog entry: UM Stryker
United States, NJ, Phillipsburg
Joined Mar 2012
Thanks KJ, I trimmed it initially with the Tx but as I do with my fixed wings once I had it trimmed with the radio and landed it I trimmed it mechanically by adjusting the pushrods.
This is going to be as addicting as my planes. Happy Flying Tom |
Hi, I'm new to the CX2 and have purchased one that has the Boomtown hobbies Stage 3 kit.
I got it with no TX and have managed to bind with it using a Devo 10 on Deviation firmware. I had to reverse the servo travel in the TX to match what the manual says. I put training gear on it and tried it out and it wants to go forward and to the right almost at a 40°. I tried the trims with little to no success. I can hold the stick to counter and it seems to have an effect but not much. It has new gears and shafts. Could this be a Servo/Swash linkage adjustment need? Thanks |
=================================== Swash Plate Info: The swash plate should be level when trims are set to neutral. If it’s not just adjust the length of the push rods as needed. Assuming the heli is put together correctly and the center hub is located in the correct spot there is nothing else to it. The esc will not change these settings, only the trims will. • The left push rod (looking from the rear) controls front to back. o If you make it longer it will give it more forward authority o If you make it shorter it will give it more reverse authority. • The right servo controls left and right. o If you make it longer it will give it more left authority. o If you make it shorter it will give it more right authority. reading =================================== I have another though...... In my travels I read of the proportional adjustment and my nose on the smooth kitchen floor with training gear its a right hand twister. The rudder trim will not take it out. So I look at the proportional and give it some CCW and it gets better. But thinking I need to put it back until I level the swash I decide to go past where it was in the other direction just to see where it is in its travel. Where it was is full lock CW. ?? This is a used unit so........ but is that normal? |
The pots are one turn pots = you can turn them until you're blue in the face but all of the adjustment is in one turn. pots also have hysteresis which means you can't go back exactly to a certain spot and get the exact same setting. It takes a LOT of playing around to get them right. Remember, the GAIN is used to hold the tail steady. That too must be done in small steps.
Thanks Guys,
I am still not happy. Its now the initial setup that's not right because I have to use massive amounts of trim and still no stability and cannot hover without tons of stick and then its not what you would call a hover. I have never set one of these up. I purchased it used and have replaced the shafts. Its the Boomtown Stage 3 kit. I have the rotor head set screws on the outer shaft lined up with the holes and feel I have it assembled right. I leveled the servo horns in their home positions. I leveled the swash as best I could. Am I missing something? |
Latest blog entry: The WLToys V912
Thanks |
Well, I have been working with trying to get the swash dead on level and it and its getting better.
I now have the E-flite LP5DSM TX. I got one to make sure the Walkera Devo-10 on Deviation firmware is not the issue. I got it for 40 shipped off eBay and it still had the clear stickers all over it. Nice! That said, if the trims center points are say, 50, I have the ELE @ 75, the ALE @ 70 and its trying to allow a kind of hover. Allot of it is me getting used to it. I do MUCH better with one on Phoenix RC. ![]() Its coming around. |
I would center all the trim levers (except for the throttle trim) and adjust the pushrod lengths until the helicopter will hover in one spot without much drift. If you are using the stock swashplate squeeze the top and bottom together. They have a tendency to separate after a crash or hard landing. A separated swashplate makes the helicopter hard to handle, and it wants to fly sporadic.
| Thread Tools | |
| Discussion to buy or not to buy the blade cx2 | airhead225 | Coaxial Helicopters | 36 | Jul 09, 2009 11:01 PM |
| Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers | Sirion | Electric Plane Talk | 11 | Apr 19, 2009 07:52 PM |
| Question How to program my dx7 to fly blade cx2? | topforce | Coaxial Helicopters | 4 | Sep 23, 2007 09:13 AM |
| Discussion How do I use my ICE to charge my batterys for blade CX2??? | webejpn01 | Electric Heli Talk | 2 | Jan 26, 2007 01:02 PM |
| Discussion How to learn to fly inverted with the Blade CP? | Crazyrcer | Micro Helis | 4 | Apr 05, 2006 12:59 PM |
