Old Dec 06, 2012, 09:36 PM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Randy...Happy B-Day Brother!!!
Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Dec 07, 2012, 10:06 AM
D.Yoder is offline
Find More Posts by D.Yoder
United States, CA, Manteca
Joined Sep 2012
So I installed a couple new items last night and I'm not sure if something is wrong. I did the lower rotors head and there is a gold metal what looks like a retainer ring that has now come.lose. Also the rotors linkage arms seem to be extremely tight and not quite long enough. And the only other complaint is that it seems like the lower swash plate is going to touch the motor.
D.Yoder is offline Find More Posts by D.Yoder
Old Dec 07, 2012, 10:52 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
That collar is what keeps the outer shaft in place and from slipping down. There should be a screw (or two) to hold it in place. Also, on that collar there will be a lip that goes on (or positioned towards the bearing) facing down.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Dec 07, 2012, 02:33 PM
Luvmyhelis is offline
Find More Posts by Luvmyhelis
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Lee
Thanks Lee, feelin my age this year for sure.
Really feeling glad in a way. My own CX project is just running fantastic. No complaints at all. Thanks to all who helped me on this.
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Dec 07, 2012, 03:40 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Birthdays? You still havin them?
lol
Happy birthday!
jrjr is offline Find More Posts by jrjr
Old Dec 07, 2012, 05:05 PM
flyeraroo is offline
Find More Posts by flyeraroo
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
With the links being tight could mean the lower rotor hub is not all the way together. Also pull out one of the top setscrews for the lower hub to make sure they are lining up with the holes in the outer shaft. That brass ring must be from the swashplate, but it should not be floating loosely. I haven't seen that before, but I have heard of others that it has happened to. It could be the swashplate is defective.
flyeraroo is offline Find More Posts by flyeraroo
Old Dec 07, 2012, 09:01 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Ah, so you are the birthday boy Lee has been spreading around. 55 huh? Happy birthday!
Mike.
Old Dec 07, 2012, 09:03 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
My wife keeps telling me I need new glasses. I think she's right
Mike.
Old Dec 07, 2012, 11:00 PM
D.Yoder is offline
Joined Sep 2012
Well I'm in the middle of doing my cx3 conversion and I see what you are saying about the battery tray... Also the bearing ring was popped out of place I seated it and it seems well but we will see... Also noticed the the top rotor seat where the flybar goes is a little uneven... Will this cause any issues?
Old Dec 08, 2012, 10:00 AM
sonnier00 is offline
Find More Posts by sonnier00
sonnier00's Avatar
United States, TX, Huntsville
Joined Oct 2011
Well I'm in the middle of doing my cx3 conversion and I see what you are saying about the battery tray... Also the bearing shin was popped out of place I seated it and it seems well but we will see... Also noticed the the top rotor seat where the flybar goes is a little uneven... Will this cause any issues?
hi there,
bearing shin? are you talking about the bearing seal or the brass shim on the bottom outer shaft bearing.
the fly bar sits on saddles 2 on each side of the upper rotor inside just under the 2 bigger holes
each one of the issues you will fined out that the inhalant nature of the heli will amplify even the smallest misalignment to the biggest headache
sonnier00 is offline Find More Posts by sonnier00
Old Dec 08, 2012, 07:23 PM
D.Yoder is offline
Joined Sep 2012
So i got everything done today and got the heli put back together. since it was nice outside and not windy at all i decided to take it out and actually get some stick time. I have one really big problem. inside in the living room if i push the right stick forward the heli dips and wants to fly forward but i always need to stop before it crashes into something. Outside it seems like i cant get the heli to move forward. it will go left right and backward but does not dip forward and go like it should. Can someone please tell me if there is some sort of adjustment i should be making to something. i have tried searching but cant find anything.
Here are some pictures with the new swash plate outer shaft bearing and the lower rotor head along with the new body.
You guys were right with the statement that i needed to add the multi million dollar cnc battery tray to the parts bin for now.
Old Dec 08, 2012, 08:47 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
I doubt ANY CX2/3 will fly decently outside with the ELE servo in the 1st hole. I would claim that even with no wind you will need to go out at least one or two holes on the ELE to get it flying forward outdoors ...
Old Dec 08, 2012, 08:51 PM
D.Yoder is offline
Joined Sep 2012
I was thinking the holes on the servo can you please explain a bit in laymen terms which one
Old Dec 08, 2012, 10:48 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Sorry this is the V4 but, I think you'll get the idea.
When you have your push rods in the first hole, there is not much authority. So, you move the push rod out a hole or two. The further out you go on the servo arm, it gives you more throw. More throw = more authority.
Yeah, you will have to re-level swash...
Mike.
Old Dec 08, 2012, 11:48 PM
D.Yoder is offline
Joined Sep 2012
What would you say is the best way to re-level the swash. Ie is there a proportion way.. also the guys at the hobby shop told me to not ever move those. I trust you guys more though. Would you say my choice to do the cx3 upgrade was a good idea or would you go another route
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 09, 2009 11:01 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
