Espritmodel.com Heli Air
Old Aug 24, 2012, 11:00 AM
sonnier00's Avatar
United States, TX, La Porte
Joined Oct 2011
parts list
the motors http://www.wowhobbies.com/turboace92...ama3lama4.aspx
the motor flange is drilled and taped for cx and lama you can find cheaper but you will need to drill and tap your self http://www.hobbyking.com/hobbyking/s...er_2900kv.html
the converters
http://www.wowhobbies.com/thestevebl...erter-1-1.aspx
the esc
http://www.wowhobbies.com/fg-blesc-1...aesc-2-4s.aspx
sonnier00 is offline Find More Posts by sonnier00
Old Aug 24, 2012, 11:16 AM
it was just a bumpy landing...
jlcamp7's Avatar
USA, OH, Milford
Joined Jan 2010
Nice work sonnier00. Not only does it look awesome, but I get it performs great. I am a little jealous of all the white xtreme stuff. I hope when I have some money to blow I can pick up all the xtreme stuff in white and then add the airbrushed white with black window canopy from boomtown and use black foldable blades. I think that would look really clean and sharp.
jlcamp7 is offline Find More Posts by jlcamp7
Old Aug 24, 2012, 11:34 AM
Memorial Day. Never forget.
Chap1012's Avatar
USA, MA, Malden
Joined Mar 2008
the converters
the esc
These are all dead links
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Aug 24, 2012, 11:37 AM
sonnier00's Avatar
Joined Oct 2011
Originally Posted by kodak_jack View Post
Looks great. What did you have to do to get it flying?
What was wrong was the outer shaft gear (top) was rubbing the main frame (bottom). I used 2 thrust washers at the bottom outer bearing and reset the pinons to the gears and all fell into place. I'm using http://flyrcrivesud.com/bladecx2.htm shafts now the extra long shafts is great not more falling from the sky be cause of blade strikes
I did have to replace the converter it was damage in a collation with a fence. I did not like the way they had the esc and converters was stacked in the shrink rap so I used a piece of credit card and double face tape to mount them so they would not be in such a bind.
She flying great now. I have been using 3c battery's but the motor seems to run hot, not sure how hot I can hold my finger on them so maybe their OK I'm going to run 2c the next time the wind dies down and see what happens
Old Aug 24, 2012, 11:47 AM
sonnier00's Avatar
Joined Oct 2011
try these links
Mike.
ops don't know what happen I'll try again
http://www.wowhobbies.com/brushless-...ama-v4-v3.aspx
the hobbyking will need to dilled and taped
http://www.wowhobbies.com/fg-blesc-1...sc-2-4s-1.aspx
Old Aug 24, 2012, 11:55 AM
sonnier00's Avatar
Joined Oct 2011
did the new links work
they worked for me
Old Aug 24, 2012, 02:13 PM
jlcamp7's Avatar
USA, OH, Milford
Joined Jan 2010
Yep all working now.
Old Aug 24, 2012, 02:25 PM
United States, TN, Knoxville
Joined Dec 2007
Saw a video on youtube. Someone was making blade grips out of the stock blades. Just wanted to know if anyone here as tried them.
CX2 (CHEAP) UPGRADE (3 min 35 sec)
randyc159 is offline Find More Posts by randyc159
Old Aug 24, 2012, 04:25 PM
Chap1012's Avatar
USA, MA, Malden
Joined Mar 2008
Thanks. Much better. Sounds too rich for me. Don't you have to double up on some of those parts other than the motor? Good luck with the build. Keep us up to date
Mike.
Old Aug 25, 2012, 08:08 AM
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
I tried them and they have to be just about perfect to work well. The hole you drill has to be perfectly centered. For the $10+ each piece, I went to the Xtreme composite grips.
kodak_jack is offline Find More Posts by kodak_jack
Latest blog entry: UM Stryker
Old Aug 25, 2012, 01:27 PM
sonnier00's Avatar
Joined Oct 2011
thats the ones i'm using on my cx and have had no problems
Old Aug 27, 2012, 11:03 AM
Joined Jul 2009
Hi,where can I get a complete set of screws and hex screws for a cx2.got extra parts to build another one but no screws.
fred2048 is offline Find More Posts by fred2048
Old Aug 27, 2012, 11:34 AM
erdnuckel2's Avatar
Joined Mar 2009
http://www.ebay.com/itm/E-Flite-EFLH...item3f1adab2bc
Latest blog entry: The WLToys V912
Old Aug 29, 2012, 10:14 AM
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Actually if a guy was to make his own swivelling grips it is much better if you either go with the actual lama system, or make your own out of Rcrvds thicker grips by drilling them and tapping them with the correct size balls. However, by the time you get done with either your costs are stacking up to the point where you might as well have bought the xtremes. Plus, on the lama conversion you need the new hub, swash, grips and links. And they still cone unless you pick up the (dunno why they call it this) blade stiffeners? From E2, as they are actually little plastic plates that stiffen up the grips themselves. And on the modding of the grips, if you have the mechanical aptitude and mic set, go for it. Even with all this mine were still slightly off where the balls were seated due to core shift in the plastic. Plus, no one here will buy anything from Rcrvd as he is permanently banned from RC groups. A few of us actually did a parts comparison from him early on, and all his stuff was way out of spec. Or sloppy. Especially the inner shaft, you need a 2mm and his mic'd out at .077. so lots of guys complained the inner shaft wobbled around in the bearings. Turns out his blades are identical to the china blacks in performance also. You can get 10 sets of them for something like $5 shipped. I don't want to get too detailed here. But in the end the only thing worth buying from him were his grips, but now the Xtremes are only a few $$ more and ten times better.
Yeah, the made at home swivelling grip mod using stockers has been out for almost 3 years now. Again though, there are problems with the stock blades. One, you have to have a matched pair on the lower set, or your heli will fly with a life of its own. And I have gone through 15 or 20 sets to get one pair that was identical. It is just alot easier to buy the $2.50 xtremes.
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Aug 30, 2012, 06:43 AM
kodak_jack's Avatar
Joined Mar 2008
Yes, we sort of let the RC rivisud part of it slip by and I was going to comment on that today. Run, do not walk, away from them.
Well, boys, for most of us, the season will be over before you know it. I'll be putting the plane and bigger heli's away and reverting to the MCX-2. Have you guys gotten into any new indoor stuff lately? There are palm size quads out.
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 09, 2009 11:01 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
